Question about EliteGroup ECS Motherboard MB K7VTA3 Socket A AMD XP DURON SEMPRON (796791550175)
Will my ECS RS480-M(V1.0) [socket 939] run an Opteron socket 939 CPU? With an updated BIOS?
4 Suggested Answers
ardmax
  • 155 Answers
SOURCE: help
It will be ok if you are going to be sure that the ordering part# correspond to this table: http://products.amd.com/en-us/downloads/AMD_Opteron_First_Generation_Reference_100707.pdf
Your motherboard maximum Front System Bus is 1000MHz.
Posted on Oct 01, 2008
  • 905 Answers
SOURCE: GeForce6100SM-M Intermitently Shutsdown
if there is a problem with one of the devices connections , or one of the devices chips are failing it will cause a shut down to protect the rest of the circutry.
try disconnecting all but cd/dvd drive to see if this happens , then only plug the sata or other ide including the power.
if a virus is in bios , resetting the clr bios and removing the battery on the motherboard can remove it
if the local area network is causing the shut down you would have data transfer problems or slow communications,
and there could also be a problem on the board
Posted on Oct 15, 2008
  • 59 Answers
SOURCE: ecs 945 GCT-NM motherboard may
check elitegroup site for bios update? sometimes gateway doesn't get the latest updates! and also
download manuel for motherboard from elites site and drivers! I hope this helps1
Posted on Jun 02, 2011
Ecs 945 GCT-NM motherboard may be defective (?). Booting soemtimes hangs up. When in BIOS, notice that cpu temp shows -negative 35 deg C and +95 F (numbers are correct - signs are wrong!). If it get to run...
Jun 02, 2011 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
I have an amd athlon x2 3800+ cpu and I can't seem to enable virtualization. My motherboard is an ECS A740GM-M and I can't find the command in the BIOS to enable virtualization. AMD Hypercompatibility...
The CPU itself does not support communication with virtual addresses. the processor wasnt designed to do it. almost everything from 2009 on has the capability minus sempron and celeron processors.
Mar 23, 2011 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
Can I use a Amd athlon 64x2 dual core processor 4200+ 2.2 ghz on my A8V deluxe motherboard . socket 939
Yes, according to the Asus website specifications on the A8V Deluxe you are able to run the CPU. You just have to make sure that the CPU you buy is for Socket 939 and not AM2.
Please rate!
Cheers
Oct 04, 2009 | ASUS A8V Deluxe Motherboard
Can I use DDR2 800 MHz RAM on GA-K8NS-Ultra-939-Socket-939 MBoard
I don't think that that motherboard will accomodate the DDR800 you probably need a DDR333 or DDR400.
Calling the manufacturer support will render better information because they made the board. The memory you refer to may not fit the slot for this particular motherboard.
Aug 13, 2009 | Computers & Internet
Installed Intel P4 630 CPU on ECS P4M800-M7 V3.1 mobo. Cannot do POST. The mobo runs fine with Intel Celeron 326 fine.
Hello Mafatbhai, What beeps are you getting at POST?
Here is a list of BIOS beep codes.
http://www.computerhope.com/beep.htm
Well the mobo should not have any problems with the new CPU. Please ensure though that you have removed the CMOS battery to reset it. I have included a link to ECS for your specific board. Download and install all of the available updates starting with the drivers and then the BIOS updates.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailID=548&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Jul 11, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Help
Aug 17, 2008 | Jetway 939GT4-SLI-G Motherboard
EliteGroup ECS Motherboard MB K7VTA3 Socket A AMD XP DURON SEMPRON (796791550175) Logo
69 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
