Question about HP OfficeJet T45xi All-In-One InkJet Printer
Appears align a6 after putting black ink - HP OfficeJet T45xi All-In-One InkJet Printer
3 Suggested Answers
SOURCE: Will not print black , HP PSC 1610 All-in-One
Here was the solution. You MUST use HP brand black cartridge. Originally I purchased a #94 Office Max brand black cartridge. After it did not work I took it back and they gave me a second Office Max brand and that did not work either. So I took it back and they sold me an HP brand (I only needed to pay the difference in price so Office Max was good to work with). I installed the HP #94 black cartridge and everything now works.
Posted on May 11, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: i just put in a
    It could be that one of the cartridges is not seated properly in the cartridge carrier. Try to re-seat the cartridges in the cartridge carrier.
    Posted on Sep 04, 2011
    Lexmark X4650 InkJet Printer black prints fuzzy. Color is fine, but the black appears out of focus.
    Try to check and make sure your black ink level is still good and not about to go empty. On the printer operator panel, press the Setup button > Maintenance > Ink Levels.
    If the black ink level is still good, make sure the cartridges are aligned. Try this approach. On the printer operator panel, press the Setup button > Maintenance > Align Cartridges. Your printer will then print a page forcing ink through the cartridge nozzles and clean them as well as align the cartridges.
    Try to print a document again to verify that the print quality has improved.
    Oct 11, 2011 | Lexmark X4650 InkJet Printer
    I just put in a brand new black ink cartridge. The alignment page doesn't show the black ink and the printer kept saying alignment error
    Aug 09, 2011 | Lexmark X5470 All-In-One InkJet Printer
    I want to use a black only cartridge, it prints an alignment page that is black only, obviously. When I put it in then to scan it (and yes i have it placed correctly in the scanner) it gives me an error...
    The diagnostic setup program assumes all the parts are loaded, including color ink cartridge.
    In normal printing you can set the preferences for black ink only, no color in the Lexmark control panel software.
    Apr 15, 2011 | Lexmark X2600 InkJet Printer
    Why is my printer only printing color and not black ink while there is a black ink cartridge installed? When I looked at the printer after printing the alignment page, it said alignment problem but there...
    This happened to me as well. Take your alignment page (or print another one) and put it in your scanner. The AIO printer will use the scanned alignment page to reconfigure your alignment.
    Oct 15, 2010 | Dell 926 All-In-One InkJet Printer
    4110 officejet series all-in-one error message saying i installed incorrect ink cartridge? what do i do? it is the correct one
    Supported HP Inkjet cartridge part numbers The HP Officejet 4100 all-in-one series products use the ink cartridges listed in the table below. HP Inkjet cartridges HP 56 black cartridge (19 ml) HP 57 tri-color cartridge (17 ml) HP 28 tri-color cartridge (8 ml) Replacing the ink cartridgesThe power must be turned ON to the all-in-one or the print carriage will not move to the right.
    1. Locate and open the print cartridge access door on the right side of the all-in-one. The print cartridge carriage will move to the right for access. Figure 1: Opening the HP Officejet 4100 seriesc00121089.jpg
    2. Press down gently on the top of the old ink cartridge to release it from the print carriage. Figure 2: Removing an ink cartridgec00121090.jpg
    3. Remove the new print cartridge from its packaging and remove the protective tape from the cartridge as shown in Figure 3. Do not touch the gold-colored contacts. Figure 3: Removing the cartridge tapec00121091.jpg
    4. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage and press them into position as shown in Figure 4. If the cartridge does not snap easily into position, it is not aligned correctly. Remove the cartridge and reposition it. Do not try to force the cartridge into position. The black ink cartridge (HP #56) goes on the right side and the color cartridge (HP #57 or HP #28) goes on the left side. Close the ink cartridge access door when the ink cartridge has been installed. Figure 4: Installing the ink cartridgesc00121092.jpg
    5. A message will appear on the front panel requesting that the ink cartridges be aligned. Follow the steps below to align the ink cartridges:
      1. Press Enter on the all-in-one front panel to start the ink cartridge alignment process.
      2. After the Alignment page prints, place the page into the ADF upside down and with the printed side down as is shown in Figure 5.
      3. Press Enter. The all-in-one will scan the alignment page and finish aligning the cartridges.
      Figure 5: Aligning the ink cartridgesc00121093.jpg
    Correcting error messages that appear after changing a cartridgeAfter inserting the cartridge, the Check Print Cartridge light flashes or one of the following messages appears on the computer monitor:
    • Check the black (or color) cartridge
    • Replace the black (or color) cartridge
    • The wrong black (or color) cartridge is installed
    These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
    1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
    2. Remove the ink cartridge and inspect it.
    3. Verify that it is the correct part number and if it is, reinsert it.
    4. Close the lid to see if the problem is corrected.
    5. If the message is still displayed after a few seconds, remove the ink cartridge again.
    6. Unplug the power cord from the back of the unit.
    7. Clean the electrical contacts on the ink cartridge with a soft clean cloth slightly dampened (not wet) with clean water. (See Figure 6) Each contact is very small and shaped like a rounded square. Figure 6: Cleaning the cartridge contactsc00121094.jpg
    8. Allow the ink cartridge to dry for a few minutes before reinserting the cartridge(s) and turning on the printer.
    9. If the problem remains, replace the ink cartridge.
    10. If the problem still exists after trying all of the steps above, the unit may need to be serviced. Contact HP for further troubleshooting or to arrange to have the unit serviced.
    Make sure what ur using isn't a refilled cartridge and if it is check the expiration date, if nothing is wrong then you need to get urself a new printer or an upgrade so call up hp at 1800-474-6836 and get help of them,they'll guide you to a new /upgrade printer.
    it's not a nice way of saying it but someone has to give you the bad news
    Feb 01, 2010 | HP Office Equipment & Supplies
    Put in a new black ink cartridge #32 in my lexmark X5470
    Try arrowing down on your screen to maintenance press the tick to select maintenance and then scroll down to align catridges. see if this works
    Jun 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
    Alignment
    I had this problem before as well. I took my ink into the refill store and she steamed it for me and cleaned it up. It then worked great. It had dried ink and wasn't printing proper.
    Sep 07, 2008 | Dell 924 All-in-One InkJet Printer
    Ink cartridge alignment problem
    well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
    Oct 26, 2007 | HP PhotoSmart C4180 All-in-One Color...
    HP OfficeJet T45xi All-In-One InkJet Printer Logo
    75 people viewed this question
    Seeker5211
    Seeker5211
