Question about IBM Wheelwriter 30 Typewriter
I have been messing around with our IBM WheelWriter 30 Series II (6787) all day and I can't resolve the issue, being: Code 215. I read thru the listings and followed the advise given in regards to the printwheel, I removed it....blew off the dust ( wasn't much in there, but blew it off anyway) reseated it and that did not resolve the problem. So.....I thought perhaps that the printwheel itself was bad...so I swapped out another from an identical machine that we have to see if that was it...it wasn't...still has code 215 ( the other machine is operational).....so.....whats next??? I am hoping there is a "next" ! : ) thank you. A. Ramsey
  • IBM Master
  • 3,594 Answers
You have done all the easy stuff so probably the LED that shines thru the P/W is bad. You most likely need a tech.
DickyO
Posted on Sep 01, 2010
  • StephanK May 17, 2011
    Hey there,
    have the manual in front of me. Trying to sell this machine for my mother.
    The manual says (error code 215):
    1. Check if type wheel is correctly installed
    2. Press 'code'
    3. Error still exists? Turn off
    4. Check type wheel
    5. Turn on
    Greetings
How do we replace the correction ribbon to the typewriter?
there is a lever in the center front of the black ribbon cartridge to release the lift off tape
Sep 11, 2014 | IBM 6787 - 6787 Wheelwriter 30 Series Ii
The bottom half of the letters typed dont show up
Press down firmly on both ends of the platen (black rubber roll) it should snap into place, if it comes back out one of the latches is broken and will need replaced.
DickyO
Feb 17, 2014 | IBM 6787 - 6787 Wheelwriter 30 Series Ii
IBM Wheelwriter 30 Series II is showing an error code of 215 with a box with a slash through it and am unable to type on it
215 is a Print Wheel error. Remove the print wheel, look for debris in the P/W area, if you have a compressed air source blow the P/W area out. If these don't work the P/W sensor is probably bad.
DickyO
Sep 07, 2011 | IBM Wheelwriter 30 Typewriter
I have an IMB Wheelwriter 30 Series II. When I turned on the machine this morning it made a couple of ringing sounds and then on the display it reads a square with the number 215. Nothing else works on...
215 is a printwheel error. Remove the P/W, look for dirt or debris in that area, if you have a compressed air source blow out the P/W area. If these fail the P/W led sensor is probably bad.
and you most likely need a tech.
DiclyO
Sep 06, 2011 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Series II Since changing
The ribbon may not be fully seated on the ribbon deck. The blue latch has to hol it in place.
DickyO
Jun 30, 2011 | Lexmark Wheelwriter 30 Series II...
My IBM Wheelwriter 30 Series II has a message of a box and an X in it and then the numbers 215 can someone tell me how can fix this?
Check to be sure the printwheel to be sure it is properly installed, check for debris in the P/W area, If these are OK then the sensor is probably bad.
DickyO
May 28, 2010 | IBM Wheelwriter 30 Typewriter
Our ibm 6787 types the wrong letters. we took out
Hi:
Make sure that the Lang function is not on.
Andrew
Jul 16, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Series II issue...
This is automatic return, it can be turned off with code "R".
You can download a manual at lexmark.com click on publications.
DickyO
Jul 03, 2009 | IBM Wheelwriter 30 Typewriter
IBM WHEELWRITER 30 SERIES II
I believe a 215 code is a bad printwheel sensor. You need a tech.
DickyO
Mar 05, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Series II Typewriter 6787
The book says turn the T/W off wait 30 seconds and restart, if condition returns call for service. However you might try removing the batteries and unplugging the machine waiting a few minutes and restarting. CAUTION ALL THE MEMORY WILL BE LOST!
DicktO
Jul 16, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
99 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
