Question about Acer Aspire One PC Notebook
Won't load up..shows a blue screen and keeps restarting..safe mode,last config.,and normal startup don't work.
    Scholar:
  • 183 Answers
Blue screen is usually a 'windows accessing RAM memory' problem, so try removing your ram one at a time.
Failing that, boot from a ubuntu disk (download from here and burn to disk) and run a test on your ram.
Finally, if it's not the ram, do a system restore, or a windows reinstall from disk.
Posted on Sep 02, 2010
Aspire 5475 freezes on startup
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
Mar 19, 2013 | Computers & Internet
Restarts after blue screen
reload windows its the initial config, you may loose all your work, i presume you tried safe mode which is normally f8 or f10 during startup. happened to my mums. would only accept a basic windows 7, not a fuller version,
Feb 13, 2013 | Gateway NV55C26u Notebook
I updated my toshiba l300 pslgbe's bios from the 1.80 to the 2.2, now everytime i turn my laptop on, it shows a blue screen with an error. my laptop is now completely useless
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 18, 2011 | Toshiba Satellite Pro L300 Notebook
My PC acer 5542G, win 7, laptop, after an upgrade programm on the ACER site for the driver sound (realtek), the screen become all black. But some fonction as light on the board and the cd-dvd driver are...
AFTER YOU ON THE SYSTEM BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE. IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
May 15, 2011 | Computers & Internet
My dell inspiron 2200 wont start up..Well it starts up but then it sais "Windows start up has failed." and it gives me options to start up in safe mode with command promt and safe mode with networking...
Boot your PC with the windows OS disk and choose to repair your computer when asked. Run the chkdsk program in DOS on the recover mode to correct disk errors.
On completion, restart your computer normally and check it it works.
If it does not work, you may need to format your pc & reinstall windows again.
Aug 02, 2010 | Dell Inspiron 2200 Notebook
Spontaneous Rebooting
Hi ,
Which anti-virus have you tried to install and reinstall as it can happen if its not properly installed.Please check if its manually uninstalled. Try rebooting the system in safe mode . Go to Run type msconfig and select Normal Startup save and reboot.
Jan 28, 2010 | Microsoft Windows XP Professional for PC
My cumpaq laptop is powred on . The screen is on but no icons
before windows loads up...
hold F8 key.. will show menu for windows
select safe mode
once in safe mode if icons show up.. restart and let it
load as normal.
If no icons in safe modeyou will have to do a restore from
windows.. what version is it?
if icons in safe mode but no icons in normal windows then
you have something in startup causing the problem
we can check this from registry or msconfig..
keep me posted
May 21, 2009 | Star Logic 17" LCD Monitor
Computer will not start past safe mode screen
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Oct 08, 2008 | Sony VAIO PCV-V210P PC Desktop
Acer Aspire One  PC Notebook Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
