Question about Sony Televison & Video
Hi I am having problems with my sony kds6a2000. When I turn the television on the picture comes up but then about 10 seconds later the picture goes out, there is sound though and the power light flashes green about 30 times and then the picture comes back for about 10 seconds and then the process repeats. I want to make sure I fix the correct problem before I spend a lot of money on a part in case it turns out to be something else. It took over half an hour for the picture to stay on, and I'm afraid to turn the tv off lol. Thanks Kristy
SOURCE: TV shuts down
Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
Posted on Jul 06, 2007
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
  • 489 Answers
SOURCE: When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
Posted on May 30, 2009
  • 1525 Answers
SOURCE: Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Posted on Oct 25, 2009
easyab
  • 132 Answers
SOURCE: The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Posted on Mar 14, 2010
I turn on my KDF-55WF655 Sony TV. The green power light flashes about 10 seconds and then the picture fades in to full intensity for about 305 seconds then goes blank. The green power led flashes about...
If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem.
Lamp is not dead or broke but weak so you get above said problem in tv.
Thanks.
Oct 05, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
When I turn the TV on, it has good picture, then 30 seconds the screen goes blank, then 30 seconds later it comes back on. Repeating this continuously. What do I need to do.
Its time to replace Lamp in tv as current lamp is near to an end of its life and causing this problem.
Lamp replacement is easy and user level job, procedure would be mentioned in user manual.
Please buy Sony original lamp for better picture quality.
Let me know if you have additional question.
Thanks.
Apr 12, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
65" projection tv will turn on and shut off before picture comes
the service light is blinking because you in fact need a new bulb also is why u have no picture
Oct 06, 2009 | Sony KP-53V75 53" Rear Projection...
Picture and sound first turn on before disappearing over and over again.
Symptom shows its weak Lamp problem in TV and you need to replace lamp. Replacement procedure is easy and written in instruction manual of TV.
Always buy Sony Original Lamp from Sony Accessories for longer life of TV.
Apr 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Blinking screen
ON THE 36 INCH SONY THE PROBLEM LIES ON THE PICTURE TUBE.THERE IS A LEAKAGE EITHER HEATER TO CATHODE OR G1 INSIDE THE CRT.THE ONLY WAY TO FIX IT IS REPLACE THE CRT OR HAVE THE CRT GUNS CLEANED THRU PICTURE TUBE TESTER/RESTORER/REJUVINATOR AVAILABLE ONLY FROM TV TECHNICIANS.GOOD LUCK.4TUNE.
Jan 09, 2008 | Sony KV-35S42 35" TV
Sony KP-51HW40 No Picture, only sound
to thus problem its very simple .! try to resolder at the back of the picture tube board.
Nov 26, 2006 | Sony KP-53V75 53" Rear Projection...
Tv picture blinks off and on
The on and off conditions is repairable and is not the tube,you should have it check out for loose conections and try not to use it or it will go bad for good and the repair will become expensive,Check power supply,horizontal driver transformer and crt board,If you are not familiar with tv service be safe and call for help.
Sep 24, 2006 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Televison & Video Logo
101 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
