Question about Kyocera Mita Kyocera-Mita SCANNER RACK Copier
Keep getting a c6 error message - Kyocera Mita Kyocera-Mita SCANNER RACK Copier
  • 40 Answers
CHECK THE FUSER UNIT
Posted on Sep 01, 2010
Error code C6
On a later model, 6800, C6 indicates hardware error. Not user fixable. http://www.manualowl.com/m/Konica%20Minolta/Fujitsu-fi-6800/Manual/284852?page=149
Jun 07, 2014 | Fujitsu fi-6130 Flatbed Scanner
Why isn't my clickfree C6 backing up my files on the second time I needed to backup my files it just keep saying that it is backing up but all colums saying 0
It would appear that your Clickfree C6 is stuck on searching when attempting to backup. If you find that the backup is stuck at this phase, where 0 files are backed up and the status reads "searching for files": you should be able to resolve this issue by applying an update from Clickfree's website.
Pre-requisites:
-Administrator rights
-A computer using Windows XP SP3, Windows Vista, or Windows 7 (32-bit, or 64-bit is okay)
-The C6 must be detected correctly by the computer (where both CF_Storage and Clickfree_System appear in Computer/My Computer)
Try the following to resolve the Stuck on Searching issue:
1. Ensure that your Clickfree device is plugged into USB
2. Close any open applications that may be running
3. Using a web browser, navigate to the following address: http://www.storage-corp.com/customerservice/C6_Updater_search_issue.exe
• The website will prompt for a username, use: cssupport
• The website will prompt for a password, use: cssupport
4. When prompted, save the file to your desktop
5. Double click on the file named "C6_Updater_search_issue.exe"
6. The update will take place automatically. Do not close the update application until completion.
7. When the update is complete, click on the OK button
8. Disconnect your Clickfree from USB
9. Plug the Clickfree back into USB
Attempt another backup to see if the issue persists.
Jul 29, 2012 | Click Free Automatic Backup C6 1 TB USB...
Unlock nokia C6 Australia
You can get the unlock code from any reliable online site. For example you can choose www.Wickedunlock.com You can get the restriction code for NOKIA C6 from here. This is one of the most trustworthy sites to rely on unlocking. The unlock codes provided here are very accurate and affordable. The unlocking process here is very simple. You will get total guidance on unlocking process. Here are the steps for unlocking a NOKIA C6,1 - Switch on your Nokia C6 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C6.
3 - Compose #pw+CODE+1#.
4 - The Nokia C6 would then display the message "SIM Restriction Off" and will be unlocked!
Apr 02, 2012 | Nokia Cell Phones
CAN WE SAVE THE SMS MESSAGE IN MEMORY CARD IN NOKIA C6-00
How i can transfer messages in phone to memory card in Nokia C6-00
Aug 05, 2011 | Nokia C6 Smartphone
I forget my Nokia C6 phone lock code. please help meeeee :((
Hello and Welcome on FixYa!
The Default phone lock code of Nokia is 12345 or
00000.
If you have changed then to get your Master code. Type *#06# at the mobile screen to know IMEI no of your mobile or you can also see the IMEI no after pulling out the battery, It is mention at back side of the mobile Then Go Here.
Give your IMEI No there and calculate your master code and try it.
It will work as your security code If it doesn't work too then you can get online paid security code for your cell. If you want to then you can Go Here.
After getting your Cell info and charges, they will send you code.
If you don't want to then you can contact to NOKIA SERVICE PROVIDER to get your phone lock code
Anymore help, I am here to help
If it is HELPFUL, Your Rating as FOUR THUMBS (Given below to this solution) and testimonial will be esteemed.
THANKS and Keep Visiting FixYa
Mar 28, 2011 | Nokia C6 Smartphone
C6 error
Error C-6 appears on photocopier
Nov 06, 2008 | Copystar CS-1500 Copier
Kyocera Mita KM 1500
Still sounds like there is a problem with the fuser unit. The technician that replaced the parts should be able to troubleshoot the problem.
C6 = Fuser error. The unit is not heating up due to a bad Fuser lamp, fuse, or thermostat, or bad thermistor.
The circuit is open, and the machine won't work til the problem is repaired. Once open circuit is repaired/closed, the machine should reset on it's own after you power the machine down and back up.
Does the machine flash the C6 right away as soon as you turn it on OR, does the C6 show up after about 3-5 minutes?
If you get the C6 right away, then the circuit is open, and that needs to be fixed.
If you get a c6 after 3-5 minutes, then there is a good chance the lamp is bad.
Hope this helps.
Good luck
Feb 08, 2008 | Video Cameras
Lg invertor air con "neo plasma"
i have the same, only way to get goin is turn off at mains. ive now tried running on fan low .... got this tip from another problem and seems to work.
good luck
Nov 04, 2007 | Computers & Internet
Nested IF functions in excel
Your first IF condition is “=IF(C6>6000,0.15%*(C6-6000),0)”
Where:
C6>6000 is your logical condition
0.15%*(C6-6000) would be the value if your logical condition is TRUE, and
0 would be the value if your logical condition is FALSE.
Your 2nd IF condition is “(IF(C6>30000,0.3%*(C6-30000)))”
Where:
C6>30000 is your logical condition
0.3%*(C6-30000) would be the value if your logical condition is TRUE, and
? would be the value if your logical condition is FALSE.
You are missing the value if it is FALSE.
Hope this be of some help/idea. Post back how things turns up or should you need additional information.
Good luck and kind regards.
Oct 26, 2007 | Excel (SS8SATAS5128400R)
103 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
