Question about Refrigerators
Have an almost new Sanyo Eclipse 4.4 Cubic Ft. refrigerator. Power turns on but does not get cold. Someone suggested the compressor might be locked up. Can I tap the compressor with a hammer to get it going. Any suggestions on what I can do. I lost my receipt so I cannot return it.
  • 4,070 Answers
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Sep 01, 2010
What is the cubic size of Sanyo SR361N Serial #970726485
I believe that the Sanyo SR361 refrigerators have a 3.6 cu. ft. capacity.
I hope this helps.
(the final character usually indicates the color of the unit.)
Aug 01, 2017 | Sanyo Refrigerators
Sanyo mini refrigerator continually runs
Check the door gasket to see if it seals correctly.
Aug 09, 2017 | Sanyo 4.4 Cu. Ft. Compact Refrigerator -...
Bought a new whirlpool refrigerator for the garage and was told by the salesman at Lowe's that it will still operate. Now I hear if the weather gets below 30 degree it will not operate. Is that true...
One thing that would concern me is the temperature that the compressor will go down to.
With a cold, or very cold, compressor the oil inside it will be sluggish possibly causing motor start up problems. There is also the fact that the refrigerant will have migrated to the coldest spot, namely the compressor, and this refrigerant will wash away any lubricant on start up.
The first thing I would suggest is that you fit a crankcase heater to the bottom half of the compressor and provide a permanent power supply to it.
Jul 21, 2011 | Frigidaire 20.6 cu. ft. Top Freezer...
The refrig motor starts but the refrig is not getting cold.
Hello,If the refrigerator is not getting cold, you need to answer some question.
1. check if the compressor is running.
2. Is the thermostat knob turn to the proper setting?if not reset it. then see if the compressor motor is running. The compressor is a football-sized case with no apparent moving parts,it's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of these components.
1. The compressor
2. Thermostat
3. The overload, relay, or Capacitor
4. The defrost timer
5. The condenser fan motor.
Thanks
Jun 21, 2010 | Sanyo 4.4 cu. ft Counter-High...
Refrigerator cool freezer not as cold as it should be
try turning of the frige and let it be of for 1day then put back on and see if will works usally does,if not next usally is the compressor does give enough cold.motherboards dont go bad usally very rare,check all the above before you buy motherboard.please leave comment,vote,note.thankyou
Sep 13, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
Sanyo 4.9cu.ft. compact refrigerator heats rather than cools
I'd already picked up a replacement (B&D 2.7cf) before I found the website and asked the question,,,, hoped for a quick fix answer and I'd be able to return the B&D.... oh well. With 'designed' obsolescence and 'disposable' appliances, Robert L's answer confirmed my 'fears'.
Now I'm trying to find someone locally (Conroe, TX) who would like to 'recycle' the Sanyo (everything but the compressor/motor is in great shape - door, glass shelves, etc. maybe even the coolant which I don't want to 'dump' in a landfill.
Jul 23, 2009 | Sanyo Refrigerators
Sanyo Eclipse refrigerator (Model# SR-4433S)Has puncture hole in Freon Tray for freezer. Does anybody sell replacement part?
HI thanks for the question. if theres a puncture in the coils . scrap it way too expensive. sorry.
Oct 15, 2008 | Sanyo Refrigerators
Not getting cold
if the rattle is coming from your compressor it would cost more to fix than the fridge is worth i'm sure. the compressor is the only moving part on the unit. the only other component is the thermostat. which you can bypass to see if it cools.
Oct 29, 2007 | Sanyo 4.4 cu. ft Counter-High...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
