Question about Crosley Refrigerators
Leaks water inside fridge when door is opened. Also leaks water under fridge when closed for long periods of time.
    President:
  • 1,891 Answers
If this is a top mount freezer / the drain needs to be cleaned . it could be iced over or pluged with algi . hope this helps mm
Posted on Sep 01, 2010
LG FRIDGE model FR-S392GC periodically leaks water onto the floor
If you leave the fridge door open the fridge will condense water from the air and after a few hours a puddle will form. Make sure the door stays shut. Also it may have a defrost cycle which can cause this.
Jul 09, 2016 | LG Refrigerators
Refrigerator leaks water
Could provide brand and model number of your appliance?
Apr 11, 2008 | Refrigerators
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
Fridge constantly leaks water. The freezer has no issues at all, but the bottom half is always covered in water/ice, I can't keep anything on the top shelf or it freezes, and of course all the drawers...
i haven't worked on a roper but i'm sure it's the same as any other machine,first tilt the machine back by raising the front legs so the doors close with a gentle push,then remove the freezer inside wall,melt out any ice and under the evap coil check the drain hole,pour hot water into the hole to make sure it's draining,usually if water is leaking into the fridge section it's a blocked drain.let me know what you find and i'll help you as much as i can
May 14, 2011 | Roper RT18HDXKQ Top Freezer Refrigerator
Water leakage thru the freezer door - GE side by side fridge
I believe your defrost condensate drain has a blockage of ice and will need to be defrosted and and clean the condensate line from the freezer to the condensate collection plate below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie that makes the repair look more simple. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Refrigerators Logo
382 people viewed this question
Top Crosley Refrigerators Experts
Charles T Nevin
Charles T Nevin
fta777
Colin Stickland
Colin Stickland
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
