Question about Microsoft SideWinder Precision Pro Joystick
Microsoft SideWinder Precision Pro - wiring
I have a Microsoft SindeWinder Precision Pro Part No. X03-57540, Product I.D. 85791-579-3326194-10000, which the cable got cut off.
Could anyone tell me how to rewire from the ciruit board to the gameport connector.
There are approx 10 wires - that includes the one for ground.
The colours are:
Black
Red
Light Blue
possibly Brown or Purple
Blue
Green
Yellow
White
Bare wire in Heat shrink tubing - ground ?
Grey
  • 1 more comment
  • au_chadl May 15, 2008
    You need to open your joystick and from the circuit board use a multimeter from the cable wire to the joystick (game port) to find this wiring detail out.
  • au_chadl May 17, 2008
    I do not have the original cable which had the gameport connector.
  • au_chadl May 20, 2008
    I have had a look at the link.
    I do have some knowledge about electronics.
    The Joystick circuit board does say "64-5851B"
    I think it is this one
    This part copied from the link
    Precision Pro 1995
    Learning from their past mistakes, Microsoft came up with the SideWinder Precision Pro, correcting the ergonomic issues while fixing some of the electrical issues from the 3D Pro and adding some new features. Ditching the geometric design, the Precision Pro dumped the 3D Pro's stick for one far more ergonomic, correcting the biggest complaint about the original 3D Pro. Microsoft also gave the rest of the Precision Pro a more rounded design, replacing the rectangular base buttons with more rounded buttons, the slider-based throttle with a wheel-based throttle, and the base itself was made more rounded. The Precision Pro also added a shift button to the base, doubling the number of possible button combinations.
    For its electronics, the Precision Pro featured a refined hybrid system, resolving some of the hardware compatibility issues with the 3D Pro. However, with the widespread introduction of USB in consumer computers shortly after the Precision Pro was released, Microsoft soon re-released the joystick in a USB-compatible form. The revised joystick still featured a gameport connector but had additional circuitry for interfacing with USB, and was bundled with a USB converter (original Precision Pros remain incompatible with this converter[30]. A user made converter exists though[1]). The creation of the USB converter bypassed the problems with the analog gameport entirely, and as a result became the true solution to the electrical problems. However, due to a flaw in the design of the Precision Pro, in rare cases the stick would build up a static charge in its electronics and require either a complex process to discharge that was not always successful, or simply needed to stay unpowered for a number of hours to slowly discharge on its own[31].
    New Friend:
This is the color code:
DB-15, Male, missing pins: 5,6,8,9,13,15
Wires color code
Red: Pin 1 Pin 1: Red Yellow: Pin 14 Pin 2: Purple Green: Pin 10 Pin 3: Grey Black: Pin 4 Pin 4: Black Purple: Pin 2 Pin 7: Dark blue Dark Blue: Pin 7 Pin 10: Green Light Blue: Pin 12 Pin 11: White Grey: Pin 3 Pin 12: Light Blue White: Pin 11 Pin 14: Yellow
source: Microsoft Sidewinder FFB game port disassembled
Posted on Jun 29, 2017
    Sergeant:
    Champion:
  • 304 Answers
Try to lok at this LINK, i'll get back to you while arrange this thing for you
`jack
Posted on May 18, 2008
    President:
  • 1,257 Answers
Since its very risky and very tough for a person who is not having a knowledge of electronics....to be able to repair it you should know soldering ..a elecronic device know as soldering machine comes through which you can solder all the braked wires.....if you remember where the wires were before, you can do it..just buy a soldering machine ,flux ,and soder wire to fix the wire ..
a flux is a chemical cleaning agent which facilitates soldering, brazing, and welding by removing oxidation from the metals to be joined.
Soldering is a process in which two or more metal items are joined together by melting and flowing a filler metal into the joint, the filler metal having a relatively low melting point. Soft soldering is characterized by the melting point of the filler metal, which is below 400 °C.[1] The filler metal used in the process is called solder.
Soldering is distinguished from brazing by use of a lower melting-temperature filler metal; it is distinguished from welding by the base metals not being melted during the joining process. In a soldering process, heat is applied to the parts to be joined, causing the solder to melt and be drawn into the joint by capillary action and to bond to the materials to be joined by wetting action. After the metal cools, the resulting joints are not as strong as the base metal, but have adequate strength, electrical conductivity, and water-tightness for many use
Microsoft SideWinder Precision Pro - wiring - moz-screenshot.jpg--------------------------------------------------------------------------------------------
It will be highly appreciated if you could take a minute and provide your feedback..
Posted on May 17, 2008
    Brigadier General:
  • 3,614 Answers
May i know on what kind of circuit board you want to connect the wiring..
thank you
  • Microsoft Master
  • 19,396 Answers
Wiring color are not always the same they may change even within same model.
You need to buy a tester, like this Handheld Mini Digital Multimeter,
and find out functions for each cable.
A mistake at this point can result in damage to the computer power supply or the game card. The controller cable must have a 15-pin male connector on one end and bare wire ends on the other. A male plug is one with a hollow indentation filled with small pins. The outer jacket of the cable must be stripped sufficiently so that the wires can reach across the required span. A VOM or continuity checker is used to trace the wires out to the corresponding pin of the connector. The wires are color coded so one probe of the VOM is connected to a wire and the other is touched to a pin until continuity is achieved. The following list should be printed and the wire color noted in the appropriate column as it is found. The plug should have very small numbers imprinted adjacent to each pin. If it does not, the diagram below can be used to determine the pin number.
PIN ASSIGNMENT ON CONTROLLER CONNECTOR
(Only the pins shown in boldface italics are required in this project)
PIN # DESCRIPTION WIRE COLOR 1 +5 Volts>
2 Button 1
3 X-Axis, Stick 1
4 Ground
5 Ground
6 Y-Axis, Stick 1
7 Button 2
8 +5 Volts
9 +5 Volts
10 Button 3
11 X-Axis, Stick 2
12 Ground
13 Y-Axis, Stick 2
14 Button 4
15 +5 Volts
After the correct wires are determined, wiring can begin. The first thing that must be done is to isolate the unused ground (pin 5) and +5 volt wires (pins 8, 9 and 15). If the wires can be exposed at the male connector end, they can be cut off at the connector. Otherwise, any method possible must be used to isolate the ends of the wires to ensure that a ground and +5 volt wire can contact each other and short. Shorting ground to +5 volts can destroy the computer power supply. The wire end of the cable can be routed through the antenna hole or any other point the seems convenient. The +5 volt wire from pin one can be routed through the master switch to allow the power to be turned off to the controller while it is not in use. The use of the trainer switch as a select or fire button is optional. There are three wires on the trainer switch. The VOM is used to find the two wires that have continuity when the trainer switch is pressed and the other wire is removed. The ground (pin 4) is connected to one of the remaining wires of the trainer switch and the wire from pin 2 on the plug is connected to the other. These connections should be taped to avoid having them touch a +5 volt wire. The +5 volt line will be connected the pots so efforts must be taken to assure that no ground wire can make contact with a pot. Any wires that are not used must be removed or isolated.
Posted on May 15, 2008
  • Microsoft Master
  • 13,433 Answers
Damn i think you need another sidewinder to find out the coloring / connections.
il open my controller and see if its similiar or not.
Posted on May 13, 2008
  • 5 more comments
  • Ekse May 13, 2008
    Sorry for the slow reply
    I decided not to break my old joystick open even if i don't / cant use it.
    This is a general pinout
    +5V
    OUT
    +5 VDC
    /B1
    IN
    Button 1
    X1
    IN
    Joystick 1 - X
    GND
    Ground
    5
    GND
    Ground
    6
    Y1
    IN
    Joystick 1 - Y
    7
    /B2
    IN
    Button 2
    8
    +5V
    OUT
    +5 VDC
    9
    +5V
    OUT
    +5 VDC
    10
    /B3
    IN
    Button 3
    11
    X2
    IN
    Joystick 2 - X
    12
    GND
    Ground
    13
    Y2
    IN
    Joystick 2 - Y
    14
    /B4
    IN
    Button 4
    15
    +5V
    OUT
    +5 VDC
    more info can be found here
    http://www.allpinouts.org/index.php/PC_G...
  • Ekse May 13, 2008
    PIN NAME DIR DESCRIPTION
    1 +5V OUT +5 VDC
    2 /B1 IN Button 1
    3 X1 IN Joystick 1 - X
    4 GND - Ground
    5 GND - Ground
    6 Y1 IN Joystick 1 - Y
    7 /B2 IN Button 2
    8 +5V OUT +5 VDC
    9 +5V OUT +5 VDC
    10 /B3 In Button 3
    11 X2 IN Joystick 2 - X
    12 GND - Ground
    13 Y2 IN Joystick 2 - Y
    14 /B4 IN Button 4
    15 +5v OUT +5 VDC
  • Ekse May 13, 2008
    Basicly thats the basic pinout
    all you need to figure out what wire is what.
    And connect them accordingly.
  • Ekse May 13, 2008
  • Ekse May 13, 2008
    If your cable was cut from the middle, then you just need to connect the same color to the same color.
  • Ekse May 15, 2008
    After haveing a look inside mine, I don't have that many wires connected to the circuitboard. Go with ginkos solution I don't have a similiar model to find the wireing from.
    well I can tell you a few things maybe they might be some use.
    pin 1 - +5vdc connected to circuitboard, x and y. ground?
    pin 2 - red, circuitboard
    pin 3 - joystick x
    pin 4 - Yellow circuitboard
    pin 5 - seems to be not used
    pin 6 - joystick y
    pin 7 - Blue circuitboard
    Our joystick again are most likely difrent I would recommend agains following my advice before makeing sure .
    Go with ginkos advice. Good luck. IF you really want to know the rest about my old gravis pinout let me know. But they are most likely difrent.
  • Ekse May 15, 2008
    x and y might be reversed.
I cannot control my vehicle in my microsoft sidewinder precision pro. do i need a driver for my joy stick? tnx..
No, you don't have to install additional drivers or software.
Check the Joystick settings in the control panel.
Mar 01, 2011 | Microsoft SideWinder Precision Pro 2.0...
Is Microsoft sideWinder Precision Pro 2.0 compatible with Windows Vista
In essence it is but here are no drivers available for it under Vista
Nov 24, 2009 | Microsoft SideWinder Precision Pro 2.0...
My Sidewinder Precision Pro on FS2004 with Windows XP has occasional (once in 6-12 months or so) partial failure. I usually get it to work by uninstalling and reinstalling the driver. But this time it...
This time all it took was updating Pete Dowsons FSUIP.
I have discovered that I need to be online to save the FSUIP Certificates in a "Storage area".
I have no idea what that's all about but it worked.
Maybe these Certificates are like Emission Trading Schemes... they keep someone in a job.
Nov 15, 2009 | Microsoft SideWinder Precision Pro 2.0...
Instructions on how to connect
THis device appears quite old, try HERE for the required program download but be aware that it appears to be supported for win 95 and win 98.
Jul 02, 2008 | Microsoft SideWinder Force Feedback Pro...
Combat flight simulator wont recognize my sidewinder precision 2 joystick on vista but it did on xp?
I am farmiliar with most flight simulators and know that you have to go to settings on the main menu the controls and select joystick, enable joystick and/or calibrate joystick. If this doesn't wok then in gameplay push "alt" on your keyboard if the task bar for flight simulator isn't at the top. Once or if it is allready there select settings and then enable joystick. If this doesn't work then call or contact or google microsoft flight simulator.
Jun 25, 2008 | Microsoft SideWinder Precision Pro 2.0...
Sidewinder precision pro 2.0 install on windows xp
i think it is xp compatible.
plug it to your pc
go to control pannel and clik on game controllers
click on add and choose it from the list
Jun 06, 2008 | Microsoft SideWinder Precision Pro 2.0...
Not connected
Download the correct drivers for it that fit your operating system. Install them and away you go. Type into Google "Microsoft sidewinder drivers"..download and follow on-screen instructions to install them
Dec 09, 2007 | Microsoft SideWinder Precision Pro 2.0...
Device driver required
here are the drivers, I have the same gamepad, and CD drivers is like new
link here http://www.megaupload.com/?d=OZ6SJ6XX
sorry for my bad inglish, I'm from argentina
Dec 08, 2007 | Video Game Consoles & Games
Microsoft SideWinder Precision Pro Joystick Logo
2,165 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
