Question about Danby DDW497W 22 in. Countertop Dishwasher
My baumatic bfd62w dishwasher starts off ok then trips the fuses on the main electric circuit. Moving the cycle on it does the same thing after a couple of minutes, whats causing this please?
Dishwasher trips out after running for a while
When you say "trips out" do you mean the circuit breaker trips? If so the breaker in the electrical box may be bad. Also do you have anything on that circuit pulling high amps when the dishwasher is running? Also when does it "trip out" during a pump cycle or when the heating element cycle starts?
If the pump does not work at all then the pump may have went out. If it happens when the heating element cycle starts then it may be the circuit is overloading or the breaker is bad.
Oct 14, 2014 | Smeg Dishwashers
Its tripping the electrics
too much power on one circuit will trip the breaker.
Jan 04, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Baumatic bdw45.1 integrated dishwasher
sorry i have no knowledge of this "baumatic" product line. please repost with another expert
Jan 28, 2009 | Baumatic 18 in. BHD45 Slim-Line Built-in...
MAINS ELECTRICITY FUSE TRIPS WHEN DISHWASHER TURNED ON
Hi, I think you will need to check the heater or the wash pump, as these are the first things to energised. IOf yo could give me some more information then i could tell you where to after these things have been tested ok!
Get back to me......
Jan 10, 2009 | Tricity Bendix 24 in. DH102 Free-standing...
Dishwasher
its quite common for the interferance filter to fail on these models its situated in the base of the dishwasher connected to the mains block usually when they fail you can see black dust around it,
Nov 15, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Oct 21, 2008 | Dishwashers
Dishwasher tripping fuse box
Has the door got any heavier, as mine started tripping the electrics when a spring broke and short circuited the connections.
f so you will have to get the spring out, from the underneath is best and replace it if you want the door to work correctly again. On mine the second one went a month later.
Sep 14, 2006 | Hoover 24 in. HD96M Free-standing...
Danby DDW497W 22 in. Countertop Dishwasher Logo
46 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
