Question about Ovens
Need wire diagram for ge wall oven control,part # wb27t10063 getting f7 error would like to replace with new one I have.
Powerman
  • 68 Answers
SOURCE: Ge wall oven display says F7
Your problem is most likely caused by a short between sections of the ribbon cable between the touchpanel and the electronic control. The solution is to insert a slip of paper between the sections where it exits the touch panel. See the attached photo. If you have a metal touchpanel, insert slips of paper on either side of the ribbon cable as well. CAUTION: Be certain to turn off the power to the oven before you poke your fingers in and around the touchpanel. My solution has worked for hundreds of folks. Don't worry about the paper burning. If you have questions, contact me at hutchipop@yahoo.com.
Posted on May 30, 2007
Master_Tech
  • 770 Answers
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
Please post the Model # from the units tag and i will see what I can do for you
Posted on Jan 26, 2008
SOURCE: Kenmore oven clock control installation instructions
powerman's solution worked great. It took me about 10 minutes. Just needed a sheet of paper, scissors and a philips screwdriver!
Posted on Jul 06, 2008
Powerman
  • 68 Answers
SOURCE: F1 Error Code
According to the GE website, F1 usually means a problem with the keypad. You might try my solution for the F7 problem which is similar in nature. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my solution with more than 1900 folks and most report success.
Please let me know if it works for you at:
hutchipop@yahoo.com
Good Luck,
Powerman
Posted on Jul 17, 2008
SOURCE: F0 error code on GE wall oven
I had the same FO error. It turned out that the ribbon cable from the front panel was not making good contact where it mated with the circuit board. Remove ribbon cable and clean contacts on ribbon cable. Replace cable and problem should resolve.
Posted on Aug 11, 2009
Control panel flashes F7
The F7 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F7 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Oct 02, 2011 | GE 30" Built-In Single Electric Wall Oven...
Tip
I get error F7 on GE oven.
Hi.
F7 on GE ovens means that there is a poor contact to keypad detected. When this happens the problem is either keypad or control panel.
Problem is fixed testing keypad and control assembly and replacing the faulty part.
Here the procedure to test the parts:
Hold down the CLEAR/OFF button on pad.
Disconnect the ribbon cable connecting control panel to pad and wait about one or two minutes to see if the code comes back.
If the code comes back, then you likely need to replace control assembly.
If the code does not re-appear on display, then the problem is with the key pad. In that case replace the key pad.
The procedure is only indicative. In case of faulty control assembly procedure may not be a definitive test. In that case replace the control pad first.
To find parts and diagrams for your appliance, enter the model number in the links listed below:
Where do I find parts and diagrams?
Regards.
on Aug 10, 2010 | GE Profile JTP18 Electric Single Oven
My oven beeps and show error code F7 on the panel. Help!!!
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | GE 27" Built-In Double Electric Convection...
My GE Model JCTP18WA5WW IS FLASHING F7 AND THE TIMER CANOT BE SET,ALSO THE OVEN CANNOT BE TURNED ON.
Hi
Thanks for using FixYa. Error F7 on your GE oven means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC).Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 17, 2010 | GE 24" Built-in Single Electric Wall Oven...
My oven has an error code of F7. what is the problem?
Hello there
Any time that you get the f7 error this means
F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
repair or replace keypad switxh or erc circuit
Mar 23, 2010 | GE PT956CMCC Profile 30" Built-In Double...
F7 CODE
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
F9 Program w/ door circuit Check wiring
Mar 21, 2010 | GE Built-In 24" Double Electric Wall Oven
What is error message F7 mean in GE Wall Oven?
Jan 31, 2010 | GE Ovens
I got an F7 error code and now the display is blanked out. JTP20 series wall oven
F7 Stuck Button
1. Function pad button stuck or
2. Bad clock. Try to free stuck button or
3. Replace Electronic Range Control (ERC).
Nov 25, 2009 | GE JTP20 Electric Single Oven
GE wall oven display say F7, Bake and alarm sounds
F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
Aug 06, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
F1 Error Code
hutchipop@yahoo.com
Good Luck,
Powerman
Jul 16, 2008 | Ovens
Ovens Logo
116 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
