Question about Tally Intelliprint 9035 Printer
Printer is coming up with a fuser failure - Tally Intelliprint 9035 Printer
  • Tally Contributor
  • 185 Answers
The fuser is not reading its temperature correctly.  Unfortunately, you will need to buy another one. The maintenance kit is PN 086515
The fuser is sold alone as 604K19433 (same as XEROX 45000)
http://tally.com/ipl/genie/realvision/lookup/partlook.cfm@pn=086515.htm
Whit
Item, Inc.
Posted on Sep 01, 2010
Printer fuser failure
replace the fuser. Fusers have a life span based on the number of prints and not the age.
If you dont print alot on the unit, consider contacting the retail store or manufacturer
Feb 12, 2014 | Samsung Office Equipment & Supplies
SVC F5 error
I think the F5 error is a fuser failure error. Check that the fuser is seated correctly in the printer.
If the error does not come up all the time perhaps you can check the fuser is getting hot.
If available perhaps try substituting the fuser for a replacement known good fuser to fully identify the fuser as the cause of the error
Nov 10, 2013 | TallyGenicom 8008 Laser Printer
Fuser unit failure
Yes you can fix the same fuser but you will need advanced skills, this problem can be because you need to replace the upper fuser roller usually is the part that first come damaged, in case this part is ok, check the lower pressure roller, if both are fine, check the heating element, it will be one of this 3 parts.
Aug 16, 2013 | Brother HL 5250DN Laser Printer
I got the error 50.9 on my hp colorlaser jet 3600 and i've what it said on the screen of the printer and the error it still there. please help me, i need this, my job is in the line. what can i do to make...
Hi hope this helps
the error looks to be low temperature on the fuser
as a repairer of machine I would normally recommend a new fuser unit if you use the machine a lot don't go for a refurbished unit as they just dint last as long but they cost more
hope this helps Ian
50.X FUSER ERROR
alternates with
For help press
A fuser error has occurred.
X Description
1 - low fuser temperature
2 - fuser warmup service
3 - high fuser temperature
4 - faulty fuser
8 - low fuser temperature
(subthermistor
9 - high fuser temperature
(subthermistor)
WARNING: The fuser is HOT. Turn the
printer off and allow it to cool for
approximately 10 minutes before removing
the fuser.
50.1 error - Fuser failure (Abnormally Low
Temperature Main Thermistor), perform the
following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
printer off and remove the fuser. Measure
the resistance between the fuser
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Faulty DC controller PCB. Replace the
DC controller PCB.
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
it if damaged.
3. Break in the fuser heater. Measure the
resistance between the fuser connectors
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
Table 7-3. Numerical printer messages (continued)
338
Mar 24, 2011 | HP LaserJet 3600n Printer
I have Xerox Phaser 7400 with an error 928 we changed the fuser 2 weeks ago now the error has come back
Error 928 refers to the fuser motor failing. Problem could be with fuser motor, motor drive board or engine board.
One other possible cause would be if you are sending too thick a card stock through the machine, this can cause drag on the fuser which the machine interprets as a motor failure.
Hope this helps.
Jan 05, 2011 | Xerox Phaser 7400/DXF Laser Printer
We are getting an error message on our printer "Fuser Failure". If we turn off the printer and turn it on again it will print. But the error keep happening. What is fuser failure
Fuser Failure, means that the fuser should be replaced.
If the problem persists, access PhaserSMART®. PhaserSMART is a powerful Internet-based diagnostic tool that automatically delivers the latest support solutions with a few mouse clicks. (English only)
http://www.office.support.xerox.com/SRVS/cgi-bin/webcgi.exe
The above is a form for ordering the fuser part for your model #.
Aug 09, 2010 | Xerox Phaser 4500 Printer
Paper jams just before it comes out. Complete image has printed but the page doesn't "come out", gets jammed. If doing 2 page print usually only half of the second page will print as it backs up behind 1st...
This sounds like a classic fuser failure. Take the printer to a qualified repair facility and they can replace the fuser and check all of the fuser and exit drives for proper operation.
Jun 16, 2010 | Brother HL-5240 Laser Printer
DP 2500 displaying E04-01
You have a failure in the Fusing Unit:
E4- 01 Fuser warm-up temperature
1. Fuser Thermistor is dirty.
2. Thermistor position is incorrect.
3. Fuser temperature is low.
4. Thermistor is defective.
5. Fuser Lamp connector is disconnected.
6. Fuser Thermostat is defective.
7. Fuser Lamp is defective.
8. HTC PCB connector (CN716) is disconnected
You can try resetting the error by using this key sequence:
enter simulation mode by pressing keys ''Function + Original Size + 3 ''
go to f9 mode ,06 (ram initialize ) sub code 04 to reset fuser error.
If the code comes back you will need a service technician to diagnose which part is bad.
Oct 20, 2009 | Panasonic Office Equipment & Supplies
Fuser error on the hp 3700dn printer
You need to replace the fuser since it is most likely caused by a bad fuser. The 50.1 error indicates a low fuser temperature which can be caused by a fuser failure or a DC controller failure. The HP part number for the fuser is Q3655-69001 for a 120V printer. You can also get the fuser as a replacement supply from your toner supplier the item number is Q3655A. Depending on how long you have owned your printer, the fuser needs to be replaced at 50 months or 75,000 pages which ever comes first.
Apr 13, 2009 | Office Equipment & Supplies
Tally Intelliprint 9035 Printer Logo
350 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
