Pilot will not stay on I have replaced thermacoupler and control valve
  • 1,606 Answers
The problem may still be in the thermocouple. Not really the thermocouple but the setup.
You can have the wrong thermocouple type. Each type is meant for a different heat range and generates differant output levels.
Loose connections - We are talking about millivolts being generated by the thermocouple in some cases so every little bit can count. Check for cleanliness and secure/good connections.
Thermocouple is in the wrong position. Put it in the wrong spot and it doesn't see enough heat or too much heat.
Needs to be zeroed or calibrated.
Those are the basics to check. If you got replacement parts and they are right then I'd be looking at connections and placement. There is always a slight chance of defective parts but usually the problem comes back to those two things.
Posted on Sep 01, 2010
I have a Jandy Milavolt. The Thermacouple will not keep the gas valve open when the pilot is lit. As soon as I release the pilot valve the flame go out. I am assuming the thermacouple is bad but I...
You're probably right about the thermocouple, though the size of the pilot flame is also influential, as it generates the electricity to keep the valve open. So you have two options, first I'd try increasing the size of the pilot (there's typically an allen hole for that on the gas valve). If that fails replace the thermocouple. Remove the pilot apparatus, then yank on the thermocouple until it comes out (or bash the top of it), I haven't yet seen one with a locking device. the new thermocouple will slip in right in the same place as the old one. Be sure that the pilot flame will engulf as much of the thermocouple as it can. The new one will also plug in the same way at the gas valve.
One thing to be careful of when removing the apparatus is the pilot gas supply, it's a stiff tube, it will bend but be careful, it will also break if you bend it too far. Best of luck to you.
Jun 16, 2011 | Jandy Heating & Cooling
Pilot won't stay lit - will eventually light after holding pilot starter button down for 20 minutes but is getting worse.
you need to replace the thermacouple it looks like a thin long copper tube next to the pilot light it should cost no more then £5.00
May 19, 2010 | Rta International Patio Heater
N90 EHLtype C 11 Pilot gas wont stay alight.
Your problem is probably with the thermacouple. Contact a service company.
Apr 13, 2010 | Thetford Refrigerators
I have a williams wall furnace model 5009622,and the pilot will not stay lit ,i cleaned the thermacouple,still no luck,i also then replaced thermal couple still wont stay lit,any other ideas thanx ,i was...
Assuming the pilot is clean and sharp. Before replacing the valve, clean any spade connections, those going up to the spill switch in particular. Clean and tighten all 4 connections. Good luck.
Jan 11, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Pilot light won`t stay burning on my hot water tank. I replaced the thermacoupler;no difference. It is a Rheem Gauardian system ''Fury''. 40 gal in a wellsite skid trailer. Thanks
The thermocouple is a screw in type or 2 wire. You can check the dc MILI volt output with a multimeter. It should probably make 500-750miliVDC when heated. Be sure no plastic from the thermocouple wrapper was on the threads, will not work like that. To light did you push and hold the valve for 30 sec after lighting the pilot then turn to run after the pilot was burning? There is a slight chance the gas valve is bad but not likely. Check the wireing on the thermocouple to the gas valve.
Oct 19, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot and Burner shut off at same time at various run times.
sounds like your pilot saftey is working.the pilot flame heats a device called a thermacoupler which gives a signal to the gas valve letting it know its ok to open main valve. you may need a new thermacouple , might have a dirty pilot orfice or a problem with gas pressure or worse case a cracked heat exchanger in any case in less you have some type of training you should call a pro
Feb 05, 2009 | Coleman Propane Forced Air Heater...
DynaGlo Heater S05-010271
check the thermacoupler on the unit its that small(looks solid)tube next to the pilot light it tell unit to turn on when pilot is lite
Jan 14, 2009 | Dyna-Glo RMC-8001SS Heater
Patio heater tip switch doesn't let gas through
it sounds like what you are describing is a bad pilot saftey device there is a device called a thermacouple when heated it creates a small electric current which lets main valve know its ok to open we have a pilot flame.the thermacouple normally screws onto gas valve it is 2 spade connectors it is a powerpyle system
Nov 23, 2008 | Coleman 5040-751 BackHome Open Flame Patio...
Pilot light will not stay lit
is it full of dust my hot water used to do the same till i blew the dust and fluff out
Nov 18, 2007 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
