Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer is about 11 years old. Agitator is a 2-piece unit, and it recently developed a problem. It seems that the upper half of the agitator "ratchets," when there's a heavy load in it. Never did it before. Bottom of agitator works fine, but it won't wash up to capacity anymore. Is something loose that needs tobe tightened? Is this a simple fix, or am I looking at major repair costs? Can I fix this myself, as I'm mechanically inclined. Just never worked on appliances before.
    President:
  • 1,218 Answers
Good day,
Not a serious problem. The agitator is a split model. The parts that failed are called by Whirlpool "dogs". They come 4 to a kit and are quite inexpensive. Ordinary hand tools with a ratchet with a long extension are all that are needed.
A picture is worth a thousand words, so here it is.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Posted on Sep 01, 2010
Agitator won't move
Thes units have litlle plastic dogs that make the agitator agitate, and when they break it will stop.
Remove the agitator and inside there are 3 to 4 plastic dogs or ears and these are more than likely bad.
Pry the agitator cap off by inserting a screwdriver into the cap's notch
2) Pull the inner cap (if present) off - many Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator (earlier models used a 7/16" hex-head steel bolt)
On older models, grasp the bottom portion of the agitator and pull the entire assembly out of the washer. (Some recent models allow just the top portion's removal to access these 'dogs')
5) Older models - place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once just the ratchet ***'y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All '4-dog' versions use the 285770 (or #80040) kit, regardless of the cam ***'y style. (Really old agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***'y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***'y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap's rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap's o-ring too - makes it easier to snap into place)dcramer531_112.jpg
Apr 18, 2011 | Kenmore 24042 Top Load Washer
Upper portion of Whirlpool agitator not turning
Your agitator dogs are worn out. Remove the agitator and seperate the upper section from the lower section. There are 4 small teardrop shaped pieces that are the agitator dogs. They have either come apart over time or at least the teeth have worn off them.
Post back with any questions. Please verify the model number. I couldn't pull up a parts list for it. I know the last digit should be a 0 (zero) instead of an o.
Thanks/Mike
Jan 07, 2008 | Washing Machines
Estate by whirlpool/agitator will not turn
under the top half of the agitator there are 4 agitator dogs. these pieces have edges to them that catch the inside of the upper agitator and if they are worn down, and they do wear, it will not move the agitator for you. hope this helps.
Oct 14, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Agitator not working
Hi, This agitator is a 2 piece agitator. Can you see if the lower half on the agitator is working properly? If the lower part is working and the top is not, you will need to change the agitator dogs. If neither half are working, you might be having transmission issues.
To change the dog kit, re,ove the top cap on the agitator and locate a 7/16" bolt. Remove the bolt and the agitator will lift out. Pull the agitator apart and the dogs are 4 small plastic pieces inside the top half of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Model RTW4340SQ0 clothes waster leaves oil-type stains on clothes
Remove agitator cap. Remove bolt underneath. lift off upper agitator and lower. Look for grease under agitator and on splined shaft and clean. Re-assemble be sure to put plastic thrust piece in between upper and lower agitator.
Jun 13, 2009 | Roper RAX4233PQ Top Load Washer
Maytag washer will not agitate.
needs transmisson replaced cheaper to buy new machine
May 20, 2009 | Maytag LAT3600A Top Load Washer
Agitator wont work, quiet hum and smell
Noises
Often something works it's way into the pump and makes a clicking or scraping noise. Another bad spot on this washer is the snubber ring that sits between the base and the drive unit.
1) Whirlpool, Inglis, (some) Kenmore washer..... Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1picture2.
(2) Whirlpool, Inglis, (some) Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator.
Apr 03, 2009 | Kenmore Washing Machines
Agitator gear is stripped
just place both feet on the agitator as it sits on the floor and lift up on the top half. there are plastic tabs on the bottom half that hold the two pieces together. you will need to remove the 2 tabs before putting the 2 pieces together. the bolt that you screw the agitator down with will hold the 2 pieces together. Joe
Dec 03, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore Top Load Washer Series 70
NO,your transmission is probably ok!! Inside your top end of agitator are these 4 plastic parts called "dogs" they need to be replaced.To be 100% sure ,do this first,Fill upthe machine on small load and while its washing look to see if the bottom end of agitator is moving back and forth ,if it is replace the dogs.In some machines you have to change the upper part of agitator.If the agitator is not turning at the bottom than,remove the top of agitator cover so you can get a extended half inch socket in to it and pull the agitator up and check the transmission splines.If they are smooth and cannot grab the agitator than your trans, is bad.
May 15, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
