Question about Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive
Problem with acomdata hybirddrive 80 gb
I have a acomdata hybriddrive 80 gb and does'nt work anymore my pc does'nt recongnize it and i can't access to the information when i conect it to the pc starts spinning but just stops
    Genius:
  • 3,587 Answers
You may need to reinstall the drivers..
Posted on May 10, 2008
Trying to figure out if my acomdata 80 GB Hard Drive still works, its been along time since I"ve used it, was wondering if I got the fire wire connections right, Are you supposed to use two fire...
just one firewire cable will work.
if the unit doesn't power on you can pull the hard drive out and put it in another external hard drive case usb/firewire/sata.
if it doesn't work then the only option to recover the data is to send it to a 3rd party hard drive recovery.
Mar 04, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
I have an acomdata external HD enclosure with an 80 gig seagate HD. I plug it in to my dell inspiron 1300 laptop running windows xp pro and it recognized the hardware the first time I hooked it up but I...
Have you been able to access the drive in the past? If so it might have become corrupt so do a reformat of the drive and format it to NTFS. You can also uninstall and reinstall the drive for your HD before doing this. Pretty much a last resort.
Dec 15, 2009 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
My new 500 G external hard drive seems to limit the file size under 5 G. Is there somewhere I can reset this to larger file size?
A disk may be formatted using different file systems. The ones used by Windows PCs are FAT32 (an extension of the old MS-DOS FAT) and the newer NTFS.
If the drive is formatted as FAT32, the maximum file size is 4.294 million bytes (some systems report this as 4.294 GB; it is actually 4 GB minus one byte).
If this is the case (Start -> Run Command -> DISKMGMT.MSC and look for your external drive, it will say something like 489 GB NTFS or 489 GB FAT32), my suggestion is to back it up somewhere else and reformat it as NTFS. There also are utilities to convert FAT32 into NTFS, but if anything goes wrong during the conversion, you can say goodbye to all your data.
Note that you won't be able to access a NTFS formatted external drive except from Windows PCs (and most Linux, usually read only), while FAT32 disks are readable from Mac OS X too.
Nov 03, 2009 | Acomdata HybridDrive E5 Hard Drive
ACOMDATA 160g E5 compatability
By default, the disk is formatted as FAT32, a format that bothe the MAC and PC understand.
Dec 13, 2008 | Acomdata HybridDrive E5 Hard Drive
Need user manual where can i find online
User’s Guides - English
HybridDrive User’s Guide (PDF: 3.1 MB)
PushButton Backup User’s Guide (PDF: 800 KB)
or go to the Acomdata web site, download in Adobe
http://acomdata.com/hdp/fs.htmlManuels des utilisateurs – Français
HybridDrive (PS-HDxxxUHE5-72) (PDF: 3.2 MB)
PushButton (Sauvegarde à bouton-poussoir) (PDF: 1.2 MB)
Aug 08, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
A red light among other things
I did some research, because I get the same error, and i found that if your hard drive is formatted in FAT32 it will only transfer about 4 Gb at a time. The answer I found, was to re-format your drive in the newer and more secure, NTFS file system. This, would increase your transfer rate to about 480 Mb/s, if your using a USB 2.0 port. The course of action that I'm currently taking, is to little by little, move folders on to my hard drive, and then reformat, and then transfer the files back.
Jul 17, 2008 | Acomdata HybridDrive E5 Hard Drive
Using acomdata hybriddrive on multiple os
If you're not going to use the included software then you should partition the drive for both of your os' (it is a fat32 drive).
Jul 11, 2008 | Acomdata HybridDrive E5 Hard Drive
External drive recognized as CD drive
You need to do a firmware flash. It worked for me. Here's the link to the fix.
http://www.techsupportlive.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=29
Mar 13, 2008 | Acomdata HybridDrive E5 Hard Drive
Acomdata no longer recognized
Check your USB Cable connected possible lost contact problem or the power supply of your optical drive.
Hope this will be helpful to you.
Oct 25, 2007 | Acomdata E5 (HD080FE5-72) 80 GB FireWire...
Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive Logo
156 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
