Question about JVC GD-V4211PCE 42 in. Plasma Television
Hi i have a JVC GD-V4210 PCE it has power but it has no picture or the fans has no power the led goes green when turned on then goes flashing red please could someone help
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • JVC Expert
  • 158 Answers
Your TV power supply board is damage and will soon cause your TV to not power on. Yes, cleaning the fan will only temporary fix the situation but eventually you will need to fix the power supply board. You can order one on ebay or amazon but make sure to have the correct serial/model number on the back of the TV before ordering and fixing it yourself. However, if you are not sure then have a certified tech to come see it.
Posted on Aug 14, 2015
Shuttle83
  • 1139 Answers
SOURCE: jvc AV42PD20ES 42INCH TV
Hello gladwin6,
You may have at least a blown fuse. However you may also have other damage to your power supply. This often happens due to the voltage spike caused by the power coming back on suddenly. You can check to see if the fuse is blown, however once you change the fuse and if this does not take care of the problem, I would suggest that if you do not have a background in electronics, that you have a qualified technician take a look at your TV set.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 25, 2007
SOURCE: GD-V425PZW powering off
Hi Boris,
I cleaned out the fans on top of the unit - all seemed OK
basically overheating i think
Posted on Aug 20, 2008
SOURCE: jvc gd-421pce stuckinstandby
Hi there, did you ever solve your problem as i have the same problem?
Posted on Oct 30, 2008
dsacco86
  • 1077 Answers
SOURCE: will not turn on
This might help you. Try starting on page 27 of this:
http://www.scribd.com/doc/6528782/Philips-42pf7320
Posted on Apr 05, 2009
SOURCE: GD-V425PZW Going in Standby Mode after few seconds. doesn't cm bk
Hi, basically it needs to be receiving a signal for it to operate.
eg. with my one i connect my decoder into it and once the decoder is on the tv turns on. good thing with this monitor is that i just need to turn the decoder off and the screen turns off shortly after. hope this helps.
Posted on Mar 26, 2010
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Sony kdf-37h1000. push power button and the green lite comes on steady and i can hear a fan. never gets to a picture or sound. it then sounds like it shuts power off but lite goes from flashing green to...
Hi catfishbob,
You're lamp came to its peak burning life and now its dead that's why you can't power up the unit and the led light keeps flashing. Once the lamp replace with new one your unit will back to normal again. Click this link for the replacement http://shop.ebay.com/i.html?_nkw=KDF-37H1000&_sacat=0&_odkw=sylvania+ld370sc8s&_osacat=0&_trksid=p3286.c0.m270.l1313.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 05, 2011 | Sony KDF-37H1000 37" HDTV
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
TV won't turn on - no picture or sound -and the 3rd of the 3 LED lights on front of TV is flashing red
HI, this is a failed power supply board. simply replacing the failed power board will fix this issue.
Jun 18, 2009 | LG RU-52SZ30 52" Rear Projection...
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Hi Boris,
Jun 13, 2007 | JVC GD-V425PZW Television
Flashing red power light
Hi WJeanne your tv needs a tech have one check your set for repairs the power supply is faulty or the related circuit.good luck.
Apr 25, 2007 | JVC GD-V4211PCE 42 in. Plasma Television
JVC GD-V4211PCE 42 in. Plasma Television Logo
113 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
