Does the monitor need to be hooked up through VGA when booting for the first time?
    President:
  • 2,571 Answers
You can hook it up via VGA or DVI, you may get it working if you use HDMI. If this is the only monitor that is hooked up, it should pick it up, but if you cant get it to detect the HDMI you may need to set the video output first using VGA
Posted on Sep 01, 2010
    Guru:
  • 1,082 Answers
With XP or Win7 you can hook up either digital or analogue and the OS should be OK. Do you have a specific problem?
I GOT THIS MONITOR/TV FROM DAUGHTER, I DON'T HAVE MANUAL. HOW DO I HOOK IT TO MY COMPUTER TO USE AS MONITOR. WHAT CABLES AND WHAT PORTS? THANK YOU
Tries Element website itself if ur LCD tv model still in the market u can download manual for free not look for their phone number like 1-800..call them pay them a fee they'll send out a copy of the manual to u.U have a LCD monitor now hook up to ur computer right now to used as a monitor now wright?Yes.Take that VGA cable out from ur computer and ur old LCD monitor VGA cable out of the VGA ports just take ur hand and unscrew the VGA cable.Used ur old LCD monitor VGA cable and hook up to the LCD tv VGA port and to ur computer VGA computer graphic card port or computer monitor port hook up the other end.Turn on ur Computer and tv on used the sides button of the tv find one that said INPUT push it a few times should find ur tv mode 1,2.3 ur computer is on as a monitor.
Aug 19, 2011 | Element Electronics FLX3210 32 in. LCD TV
I want to connect my dell inspiron 1525 to my lcd hd ready tv but have no idea how to? Does anyone have any advice?
The 1525has a a hdmi port which you can plug a hdmi cord into. This may not support the audio. the tv and pc should detect the new monitor automatically or you may have to toggle it by hitting F4 key.
Apr 22, 2011 | Dell Computers & Internet
I have a Dell e1705; I had an external monitor hooked up when the LCD display died. I continued to use it with ext. monitor. However, now on re-boot it won't boot with external monitor unless I go the...
I think now problem is from Monitor side,Check with another monitor and also possibility of VGA driver problem,so reinstall driver for VGA.I think it helps. Let me know.
Jan 08, 2011 | Dell Inspiron E1705, Intel Core 2 Duo...
No input signal flashing, but computer is booting
We need to narrow down the problem first. Let make sure that it is not the problem with the monitor by hooking it up the other PC, or hook up PC to another monitor to see if you still get the same problem with new monitor attached to it. The VGA cable can be bad also.
Mar 20, 2010 | Kogi l4ax 14.1" Flat Panel LCD Monitor
Does the acer aspire r1600 work through the hdmi at boot up? I just received it and can't get my 42'' sanyo LCD to display anything. I have it hooked thru the HDMI connection. Do I have to have a...
No, it should boot with booth, you have only onboard video and as long as the drivers
are installed you should be able to use both VGA and your hd port.
At boot it uses generic drivers so both should work.
Check your screen and make sure that is set to run with the port you used on it.
So check your manual to see if you need to switch from VGA to HD port,then check the monitor for settings.
Feb 04, 2010 | Acer Computers & Internet
I have this monitor hooked to my PC ATI 7500 graphics card with a DVI cable. When the PC initially boots up, the monitor display is blank - it does not display the boot-up messages until the MS Windows...
This is normal. Your monitor has a VGA hook in for regular definition. What it is doing, the monitor always by default looks for the VGA hook first. On my desktop it does the same thing until it finds a signal on the DVI.
Dec 29, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
L1975NW Monitor will eventually light up a boot up
your cold cathodes (tiny fluoresent lamps) and, the inverter (ballast) board in the monitor's screen; need to be replaced
Jul 01, 2009 | Westinghouse L1975NW Monitor
I want to use my laptop as a monitor for my desktop
Check VGA cord connection, possibly try another, shorter VGA cord, plugging in cords BEFORE booting up computer, with monitor power on also. No signal is just computer telling you that it is not connecting.
You may have to go into Setup when computer boots up and turn on or select external monitor as some laptops may require this. Good Luck!
This is a great place for solutions that will save you lots of $$$$. I love it and it is my first contact with FixYA! jaballou
Nov 15, 2008 | CMB T43 750 Notebook
Princeton VL1715 startup problem
Have you disabled your onboard video in the BIOS? Boot your machine with the vga cord to the motherboard. You need to get into the BIOS. Depending on the make of your machine you need you will need to hit the del key, f2, or even f1. Go to the periphrial setup and disable your onboard video. Save the BIOS turnoff the computer and plug the monitor into you vga card. That should do it. To change it back to your motherboards vga just reverse the instructions. Let me know what happens. Good Luck, Tim
Feb 15, 2007 | Princeton Digital VL17151 17" Flat Panel...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
