Question about Napoleon Patioflame "Campfire Style" Log & Burner Set - Liquid Propane
I need an assembly manual for grass catcher model # 7060943, orginally manufactured by Snapper. I have the grass catcher, brand new, in a box, but no directions for assembly. Help! I'm a woman!!!
Is there a video of assembly Husqvarna grass catcher 5879604-01. This manual is not helping. I've had it for 6 months
There are no videos showing the installation. However, the owners manual should walk you through the install.
Nov 19, 2016 | Husqvarna Garden
Early this month I bought from Sears the 30" rear engine riding mower. At the time I did'nt want to pay the 299.00 for the grass catcher. Three weeks later at Sears outlet I found the catcher for...
without a model number what do you expect us to do go to where you bought the mower and ask them for the attachment manual. like make you a copy .
Feb 03, 2015 | Sears Garden
Where to buy
I would imagine their website would be a good place to start. Maybe then eBay or Amazon once you get the manufacturer part number
Sep 16, 2014 | Black & Decker Ba - 075 Side Bag Assembly
Grass catcher
What I would do Wayne is contact Ariens through the web site or at their dealership and see if one may be placed on your mower. Each manufacturer has their own set up for grass catchers, so I have not seen one the fits all. If you don't get anywhere Wayne, think about buying a lawn sweeper that is attached the the rear of you mower. If you purchase a good one, you will be very happy with it's performance. I hope that helps you out in some manner.
Jun 18, 2013 | Ariens 42" Riding Lawn Mower Blade ...
I need a grass box
WHAT IN THE H..... IS A "GRASS BOX" DO YOU MEAN A CATCHER BAG FOR CLIPPINGS????
#1 IT IS MUCH BETTER FOR YOUR LAWN TO LET THE CLIPPING FALL INTO THE GRASS, AS THEY DECOMPOSE...THEY FEED AND GIVE NUTRIENTS TO THE SOIL
Jul 30, 2012 | Garden
Wierd grass catcher problem
There are a couple of causes for this. Is the blade height the same on the new mower? Higher blade height could cause a lot of the grass to be blown out from under the deck, and not into the catcher chute.
On the trailing edge of the mower blades is a small 'wing' for lack of a better term. There are two types of blades, mulching blades that have a lower 'wing', while catcher blades that have a slightly higher 'wing' but it makes a difference.
If the season has been hot lately, the grass may not be growing as fast, hence less clippings, and less dense grass could also cause this.
Jun 16, 2012 | Mtd Garden
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How do I install the grass collector
Assuming that you have the correct grass catcher..... Install the discharge deflector at the deck discharge. This is the smaller piece that bends 90 degrees. It will slide into clips on the deck when you have the deck's plastic deflector raised up. Next, install the bagging assembly. It's pretty straightforward. Lastly, install the plastic chute (tube). Push it in the grass catcher (bagger) opening, and then pivot it over the deflector and down onto it to seat it. Connect the straps.
Best regards, --W/D--
Aug 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Napoleon Patioflame "Campfire Style" Log & Burner Set - Liquid Propane Logo
71 people viewed this question
Top Napoleon Pool & Spa Experts
Paul Carew
Gene Haynes
Dan Webster
Dan Webster
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
