Question about Hobart SR24C-4 Dishwasher
Hobart SR24C-4 Dishwasher can't drain completely
Dear Sir,
why Hobart SR24C-4 Dishwasher can't drain completely? I checked the drain pipe system is ok, and even disconnect the drain flexible pipe from drain system, it still don't drain completely. why? thank you very much.
best regards!
simon
    Scholar:
  • 68 Answers
If this is a new occurance, and not "since it was installed", it may be the drain impellor. Little fins on top of the impellor sometimes get worn off. It is under the lower wash arm in the pump housing. The only trick to taking the pump apart is not loosing any of the shims.
Go to page 12.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/860F7951C087BD7F85256D36004978EA/$File/F43078.pdf
Also, (and most likely if the unit looses water during the wash cycle), any obstruction to the drain valve can cause it to not drain proper. The drain valve uses a little flapper valve to drain the unit. It has a rubber stopper that needs to properly close. The drain valve is at the front of the unit with a red coil and white plastic body. It needs to be closely inspected. (page 22)
If this is a problem since it has been installed, it is likely due to the running of the external drain line. (Too high)
Posted on May 10, 2008
I am working on a Hobart SR24H dishwasher. The cycle starts but the fill valves are not energized and no water is being allowed into the system. The hot water booster tank is heating up.
Hello Jim Richards,
I tried to pull down... any meaningful information
from the GARDEN VARIETY part houses...
It appears you can get replacement parts through grainger...
Manualslib.com does indeed show SR24H
a commercial grade unit...
(also SR24C... similar chem clean commercial grade)
Hobart SR24C Instruction Manual Page 4
Hoping to find valves, schematics & perhaps
even PART NUMBERS... (no luck).
Found some parts on the internet...
Parts list (Rev A, August 2009)
http://www.hobart.com.mx/pdf/CatPartes/F43078RevA_Lk.pdf
I don't know if you have tried to "activate" the valves
(power direct to... VALVES not responding = open coil)
Or you are having a control board failure
(test for voltage present)...
If you have power at the valves... and they are merely not responding... Some folks will tell you to clean the
(descale.... decalcify) your VALVES.
I'd say replace them... NOT CHEAP
(but it appears "KITS" might be available)
then play with the old ones at your leisure...
(obviously... if that I indeed your issue)
Grainger.com might help (but not obvious on the net)
Heritage parts, WhaleyFoodService and Partstown
(appliancepartspros was a COMPLETE BUST)
see below
https://www.bing.com/search?q=hobart+sr24h+parts&form=EDGEAR&qs=PF&cvid=dc8dfce20e70486cbcb3a4149b58c984&cc=US&setlang=en-US&PC=DCTE
Whaley
Parts Manual HOBART SR24H
Oct 12, 2017 | Hobart Dishwashers
Hobart sr24c is leaking water out the bottom of the door during operation.
You have a bad seal try replacing the gasket make sure your drain so not clogged up to ensure proper water drainage
Apr 21, 2016 | Hobart Dishwashers
Water level stays to high, everything else is working fine. just does not go down low enough and next cycle pushed water out over the lip at the front
two issues.
the first is a retricted drain . either the hose is kinked or a blockage at the drain valve, or where the hose joins the sink plumbing. disconnect it from the plumbing and let it run into a bucket to observe the flow.
The second is, the float protecting an over fill is not shutting off power to the fill solenoids in the event of over filling. Try raising the front feet and keeping the rear as low as possible to bias the water to the rear of the tank.
Dec 29, 2013 | Hobart SR24C-4 Undercounter Dishwasher
I have a 25 year old KA dishwasher (by Hobart) that is not draining properly. I ran it through a second time and the same thing happened. There is 2" of standing water right now on the floor of the...
The drain usually connects with a flexible plastic hose to the garbage disposal under your kitchen sink. Run the disposal for a minute to see if that unclogs anything.
Remove the hose and blow into it (use a straw and try to make a seal between hose and straw with your hand because old drain pipes taste really bad if you kiss them directly).
Otherwise, your pump may have gond bad - dishwashers do not drain on gravity alone. they all use pumps. Yours may not be worth replacing unless you are really handy and can do it yourself.
Pumps are available and located on the bottom of the unit. Disconnect drain hose. Disconnect circuit breaker. Remove panel by toe-kick and disconnect electical hard-wired connection. Disconnect water (under kitchen sink). Pull it out from under the counter. Order new pump, install and replace. Be careful with the electricity.
Good luck.
May 05, 2011 | KitchenAid Dishwashers
Not pumping at end of cycle
Cancell all the pre- set programs. refer user guide. Restart after switching OFF and try.
Still problem continues, only option to reset the system board. This procedure is known to the manufactures service provider. You have to get the sequence from them.
May 28, 2010 | Hobart SR24C-4 Dishwasher
Hobart dishwasher Am14, rinse cycle is too short. Can it be adjusted?
no rinse time can't be adjust on the am-14 modelit is built in main board non variable
Dec 01, 2009 | Hobart SR24C-4 Dishwasher
My fisher paykel DD S03SS dishwasher leaks from the top, & drain
The drawers should not leak unless there is a problem with the vacuum seal. Try cleaning the edges of the doors and operate. You should feel the vacuum is holding the doors. The seals could be faulty or vacuum system may be faulty.
About not draining completely - a possibility is the common drain hose after the U adapter being clogged. Remove the clamp and pass a flexible wire coat hanger towards the main drain pipe. If both drawers are not draining then it is unlikely the drain hose between the U clamp and the dishwasher is clogged. Also make sure the height of inlet water pipe and drain outlet is as specified in the installation manual
Nov 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dish washer beeps all the time
Are there there any codes displayed or a wrench icon on the display?Can you give more info of when the problem started?
Mar 19, 2009 | Hobart SR24C-4 Dishwasher
Hobart SR24C-4 Dishwasher Logo
353 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
