I have a "space mate" washer dryer unit. The model # is illegible but it was built in 1987. The washer is leaking when it is used. Is this a logistically repairable problem that I can resolve myself?
  • davesintahoe Sep 01, 2010
    Thanks. I'll check hoses, etc. I was wondering if there is some kind of mystical seal to look for. If it is a hose issue, I'll sniff it out and replace per required.
    Dave
  • 10,515 Answers
To start with, the thumb rule is ' If the cost of repair is more than half the cost of the unit, it is not advisable to repair it '. Now, as the machine is made in 87 - it is a whole lot of time. So, calling someone to repair it would not be a wise option as there could be many other parts that would be worn out.
Now, Leak - There is no point of calling someone for repair. However, if this is a minor fault, you could try to repair about yourself. If the machine only leaks while you use it, check all the hose and make sure that there should not be any lose connection or there is no crack / damage. After this check, the location of the leak. Check the inlet valves. If you could find a leak, that good.Replace the faulty component unless better to go for a new one.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 01, 2010
  • taran_2005
    taran_2005 Sep 01, 2010
    Thanks for your response!!
    If we might have the exact model number, i would have been able to provide you with more information. As of now, check for the faults that you could see visually.
    Do not forget to accept the solution,if 100% satisfied from my response.
    Hope i helped you.
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
Can a stacked washer/dryer be separated for moving?
No they are erected as a unit, then the house is built around it.
May 14, 2014 | Kenmore Dryers
Washer wont operate a spin cycle
What is the model number of your unit?
Nov 24, 2012 | Washing Machines
How do you hook up drain hose to model HDN455 RB
Remove the bucket and remove the plastic cap on the bottom of the bucket. Then take the rubber insert out of the cap and save it. You will use it later. Using the hose that came with the unit, thread it through the cap opening and add the washer to the cap. Screw the cap to the mating connector on the bucket. Be sure to use the washer or the connection will leak. Now, thread the hose through the round hole and extend the hose to the back of the unit. And finally, replace the bucket in it's original position in the unit.
Hope this helped you. Please let me know. Thanks.
May 27, 2011 | Haier HDN455 Dehumidifier
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
I have a Kenmore washer model no.4174102000 that has broken and was advised it cannot be fixed. I have a Kenmore stackable dryer model no.41781042000 and am being told by Sears that I have to buy a new...
a stack unit is a very risky investment, altho it's understandable if you have limited space. if the hold downs on the washer are rusted out or broken thru you need to have someone weld them for you. That's how we used to do it where I worked but stacks are not usually easily worked on. I'm afraid you will probably have to get an entirely new unit or maybe a used one from a reputable used appl. dealer in your area. Check around, you might get lucky and find one relatively inexpensive
Aug 24, 2009 | Kenmore Washing Machines
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
