Question about Acer AL1916W 19" LCD Monitor
My computer won't project to my monitor and i try unpluging everything numorous times and it still doesnt work plz help i need quickly
  • 11,361 Answers
More likely to have bad DC filter caps problem in the power supply or problems in the backlight inverter circuits.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 01, 2010
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
Problem: no image, black everything, it doesnt turn on, there is no red light and no green light either, previously sometimes turn off and than went on again... it did it several times... I can buy a...
Unplug the cabels and plug it back in,Have you tried this already?
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 10, 2011 | ViewSonic VP2030b 20.1" LCD Monitor
Why when i startup my computer auto shutdown
Hey for this problem most of the times user thinks that motherboard got corrupt.
but try this first. use your Operating system CD and repair it
use command chkdsk for repairing.
If not then format the system
Nov 16, 2009 | Abit NF-M2S Motherboard
My computer screen is unstable and the picture keeps"slipping' what canI do?
  • check the connections, make sure everything is in tight and right
  • if you can unplug the monitor cable, and try it with a different computer, if it doesnt work then you need to buy a new cable
  • this is most likely a connection problem so check and test all connections
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
My compaq is stuck on the compaq logo screen
hi there..
turn of your computer before you do anything ....
unplug all the cables.. i mean everything..
then we are going to a proceedure called as powercycle..
after unplugging all the cables..
press and hold the power button for 5 - 10 secs..
or you could leave the computer for 30 secs.. without connecting the cable..
connect only the basic cables. .such ... keyboard. mouse. monitor.. cpu and restart your computer..
this should work
if not please do let me know ..
Aug 20, 2009 | Computers & Internet
Monitor black screen prob
disconnect the monitor from the back of the system and see if u see the colour scheme or anything if u do see something that means monitor fine ... problem with system
Sep 19, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
Cornea flatscreen mp704 monitor
i have a similar problem i believe the power button on the monitor is faulty,sometimes it works sometimes it doesnt.what works for me is to hold the button until the monitor comes on and release the button quickly.
good luck.
Dec 26, 2007 | Cornea MP800 18.1 in. Flat Panel LCD...
Acer AL1916W 19" LCD Monitor Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
