Question about Neovo F-419 19" LCD Monitor
Were can i get the driver for the F419 19" screen? Windows XP uses a plug and play monitor driver but this does not function very well
    President:
  • 2,571 Answers
Your driver and manual is here, your link is half way down the page http://www.neovo-usa.com/canada/support/download.htm
Posted on Sep 01, 2010
  • patjqm Sep 01, 2010
    thnx for the advice, i download it and save it but how to replace the driver ? tere is no exe file to do that
  • Roy
    Roy Sep 01, 2010
    The file you download is compressed file, you need a program like 7 zip, or windows built in compression program to extract the files.
    You will have folder with the files in, you will find the driver files and some readme files, showing how to install these files. the read me files are PDF, you will need adobe acrobat reader, or another reader like Foxit, to read these files.
    I just downloaded the file, extracted it, everything you need is there.
I lost my screen driver, I need a new one
Windows should work just fine without a special driver because of Plug-and-Play, unless your PC is older than Windows XP. If your PC is old enough to need a special driver, then post back what kind of monitor you have so we can assist you.
Jan 04, 2014 | Computers & Internet
My PC runs on an XP Pro x64 system and has installed Plug & Play Monitor instead of my Acer X193W ....!! How can i install my Monitor properly on XP x64.... Thank you...
Unfortunately Acer has chosen to not support Windows XP any longer. If you go to the Acer website as follows:
http://www.acer.ca/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3751&sp=page15e&ctx2.c2att1=27&miu10ekcond13.attN2B2F2EEF=3751&CountryISOCtxParam=CA&ctx1.att21k=1&CRC=719687231
Then look for the driver for your monitor. You will see that the driver only lists versions of the Vista O/S as those that will work with the driver. When XP is not able to load the correct driver the system will identify and load the driver as a Plug & Play Monitor. This means that you will be able to get some functionality out of your monitor. but you will not be able to get all of the resolutions that the monitor is capable of running. If you just purchased the monitor and were told that it will work correctly with XP, you may want to take it back to the dealer you bought it from. Failing that you will either have to upgrade your O/S, or give up some of the functionality of the monitor.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 16, 2011 | Acer X193W 19" Widescreen TFT Monitor
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
I am looking for a monitor driver for Windows Vista for LT1919
Windows XP and Vista should "auto-detect" the capabilities of this LCD screen.
If not, access http://WindowsUpdate.Microsoft.com
and scan for updates.
When the scan is done, look for "optional hardware" updates.
If Microsoft has a driver, it will be offered for download.
Nov 20, 2009 | Mag Innovision Computers & Internet
Display Problem with Scenic P300 i845GV
it seems that you have a corrputed operating system. try 2 repair it by using the operating system installer and do a repair just follow the steps.
Jan 28, 2009 | Fujitsu Siemens SCENIC P300 PC Desktop
Lost video driver for Scenic P300 i845GV
there are many options open to you.
Boot into safe mode and see if you get a good result. Then if you can, connect to internet and get the new drivers for the video card or built in video.
try this first and we can go from there.
Thanks!
let me know asap.
Drivers for the Acer LCD monitor X193W under Windows XP Pro.
The acer LCD monitor is plug and play.You don't need a driver.But unless you have a graphics card that supports at least 1440x900 you have problems. Also if your card has a div connection, use that instead of the analog connector, The monitor comes with that connector. Use the old one to connect a second CRT monitor if you want. Don't connect both to the lcd monitor and to the computer unless you are using a second monitor. Like everything these days, every purchase seems to need an upgrade of sorts, On board graphics **** anyway. Buy at least a 128 MB graphic card with a digital connector and more RAM never goes astray.....
Ron
Nov 09, 2008 | Acer X193W LCD Monitor
Cannot Find Drivers for Asus VW193T 19" LCD Monitor
there are no drivers for this monitor. you need to update or upgrade your video card.
Oct 31, 2008 | ASUS VW193T Monitor
Line of Discolored Pixels Down Center of Screen
are these lines visible in POST or boot up? if they are then your LCD is faulty.
Sep 14, 2007 | Planar CT1904Z 19" Flat Panel LCD Monitor
Neovo F-419 19" LCD Monitor Logo
144 people viewed this question
Top Neovo Computers & Internet Experts
Tom Chichester
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
