Question about Garden
Looking for the part number for a carb in a Poulan XPWES0424CS EM, 1999 14" chainsaw.
  • 149 Answers
SOURCE: Replacing a fuel line for a Poulan 2175 type 2 chainsaw
the fuel line from the tank filter goes to the carby and the other tank one goes to the "out" on the primer bulb. the other one on the bulb goes to the carby.
Now If the primer isnt marked there is a long and short nipple, and I cant rememer which is which...If you press the the prime rwith the hoses off you can find which one is sucking(in) and the one that blows (out).
The "in" on the caby (tank filter hose) is usualy the pipe that is in the aprox middle position, out (return, primer) is usualy ont outer position.....
the primer basicaly pulls air and fuel out of the carby and back in to the tank, not pushing it into the carby like most ppl think.
if it wont prime swap the hoses around on the carby and try....if that still dont work the caby diaphram might be US.
Posted on Feb 01, 2009
joboo1
  • 257 Answers
SOURCE: i have a poulan 2050 chainsaw. hookup primer
hi, Yes it is and should go from tank to primer to carb. Good Luck!
Posted on Feb 09, 2009
rowdy45176
  • 2176 Answers
SOURCE: 36cc poulan chainsaw carb settings
Poulan does not give the settings but they do give a toll free number to contact if you need help and that is 1-800-554-6723. Sorry I couldnt get more but that is all I saw
Posted on Feb 18, 2009
  • 97 Answers
SOURCE: routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Posted on Mar 21, 2009
dontbother10
  • 2220 Answers
SOURCE: lost my manual for my poulan pro 255 chainsaw the
If looking for parts your OM is of little value. You can find an IPL (exploded parts list) here (only one PP255 listed):
http://www.ordertree.com/modelinfo/PWE/PP255-Gas-Saw/75.PP255-Gas-Saw.1.59.1.html
Rear vibration (isolation spring)s appear to be item 5 or 59 on the "Exterior Assembly" print.
Poulan replacement OM.
http://72.3.225.179/manuals/87722e.pdf
There is contact us number in the OM if you want to contact Poulan. HTH
Lou
Posted on Feb 15, 2010
Testimonial: "thank you very much for the information that you sent me. i spent two hours on a dial up modem trying to find the part and 20 seconds to read your rep"
Poulan pp4018 chainsaw starts and stays full thottle
Not a real common problem on this model, but I have seen this a few times. 1st if under warranty (take to have serviced). If you want to look at it your self I would start by removing Cover and looking at throttle control linkage (Key image # 38 in image of website below) to make sure that when you press trigger that linkage on carb is moving. Some timaes you can free it but sometimes it is actually the carb sticking.
POULAN Chain Saw Shield cylinder crankshaf Parts Model PP4018 TYPE 1
Sep 04, 2014 | Poulan Garden
Routing fuel lenes from carb.to primer bulb to tank and back to the carb.?
moz-screenshot.gif/www.ereplacementparts.com/poulan-2375-type-gas-chainsaw-parts-c-16962_17147_17263.html this will give you a good break down. select diagram B and you will be looking at figures 6, 12 and 14
Aug 04, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Woodshark 1950 14" Chainsaw Family: WPWES
Checked all the parts lists, they seem to use the same primer through all types no.s part no. 530047213.
Jun 24, 2011 | Poulan Garden
I have a small poulan micro chainsaw with a walbro wa19
I am going to close this. We can continue to converse as we have.
I present you with these parting gifts (look at the 1800 and 2000s):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Just in case
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Good Luck.
Lou
Feb 25, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Lost my manual for my poulan pro 255 chainsaw the model number seems to be missing on the machine. i have a balance spring underneath thats broken near the rear of the chainsaw. need a part number for the...
Lou
Feb 14, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a poulan pro 210 chainsaw both fuel lines has rotted off standing behind the saw to the right of the carb there is a large hole in the tank to the left there is a smaller hole, it has a primer bulb...
This should help:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
This too:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
Poulan.com
I think this is your saw please ensure I am correct.
http://www.ordertree.com/modelinfo/PWE/PP210-Gas-Saw/75.PP210-Gas-Saw.1.59.1.html
If not your saw it can be found here:
The dash number of your serial number is the type. HTH
Lou
Take some pics first then a small sample of the different fuel lines to your local chainsaw seller. A little extra is agood idea, I have not found a good fuel line stretcher and I have been looking. Probably a good idea to replace the fuel filter too.
Jan 16, 2010 | Poulan Garden
I need to know how to adjust carb on a Poulan chainsaw Model number 2050 Preditor
set both jets out 1 1/2 turns and then start it up and fine tune it from there. This will start you out right close to excellent. hope this helps you
Nov 02, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Routing of fuel lines from tank to primer bulb to carb
Mar 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Feb 17, 2009 | Poulan Garden
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
