Question about True Refrigerators
The interior light is off and the refrigerator is warm. But the upper light (lighting up the "Pepsi" sign) is on, indicating that the unit has power. It is a True single glass door refrigerator, 6 1/2 ft tall by 2 1/2 wide
    Genius:
  • 1,478 Answers
You need to see if the refrigerator is plugged in properly. Also check for a blown fuse or tripped circuit breaker. See if there is any damage to the electrical cord and check the outlet voltage. Troubleshoot the problem and if you do not find any of the above reasons as the cause of refrigerator not working, call the repairman.
Check for the temperature control. If it is off, turn it on. If not, then you need to check the compressor for overheating. You need to unplug the refrigerator and clean the condenser coils. If the compressor is bad, then you need to call the repair man.
Also, You need to check the temperature settings and see if there is enough air flow in the refrigerator and freezer. You need to check for air flow restrictions in the vents and clean the compressor coils. The door seals, door switch, defrost heater and timer has to be checked. Also clean the clogged drain tube and refrigerant leak.
Take care.
Posted on Sep 01, 2010
What size flourescent tubes are in the door of a dncb240 pepsi machine?
Measure the distance between the tube sockets to get the size tube that fits.
Oct 21, 2014 | Wine & Spirits
Lights Out and Door Open Indicator Flashes
The problem is above the doors at the switch, the unit can't see the switch opening (closing the door opens the switch). The linkage is where the problem is, the light go out to protect the fridge from getting too warm and the lights are remaining on after you close the door.
I hope this helped. Good Luck
Dec 22, 2013 | KitchenAid Refrigerators
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Hi - hearing a fan whirling sound when either of the upper doors are closed. Freezer is still freezing but warm up top. Pressing the close button instead of closing the door produces the same fan sound.
Make sure the lights are going off in the freshfood section. If lights staying on remove bulbs immediately and order new control board located on back of unit.
Mar 12, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerator not working blowing warm air
there is a control board located inside the lower left rear wall near the floor by the compressor end of unit,you will need to replace this board,a sign of this will be if you have heard a clicking sound from there and you have blown out light bulbs in the refrige section,and the temp indicators are out or dark,its easily replaced by unplugging old and plugging new board inside plastic box
Jan 09, 2010 | Refrigerators
Interior light wont turn off
tHE PROBLEM IS CAUSED BY A BAD MAIN CONTROL BOARD LOCATED ON THE BACK OF THE REF AND IS COVERED BY A PLATE WITH A BUNCH OF SCRREWS. ALSO, LG HAS EXTENDED THE WAR TO COVER UNITS PURCHASED IN THE LAST 3 YEARS TO CORRECT THIS PROBLEM. CONTACT A LG DEALER OR CALL THE COMPANY TO SEE IF YOU ARE COVERED BY THIS WARRANTTEE REPAIR
Dec 02, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Interior level indicator and interior lights not working on Whirlpool GD5RHAXNB00 Refrigerator.
The failed part on my unit was 2252189, the electric control board. This board is located on the left side of the refrigerator in the back next to the compressor. Its inside a plastic box on the side. That number has changed to a number WHIW10135090 and cost $84 from www.apdepot.com
A previous post listed a part number 2303805 as being the problem. That part number was the replacement number for the control board that is located in the control box inside the refrigerator. That part is NO LONGER AVAILABLE. It has been replaced by part 2255233 which is the entire control box. cost for that part is $161.00 from AP Depot. I purchased this part first and it was found to NOT be the problem.
I would suggest that anyone who has this problem start with the less expensive part 2252189 and them see if you need to spend more.
My unit worked fine with exception the the refigerator side interior lights and the digital display. Compressor and temperatures were fine. Just an FYI on my problem specifics.
Oct 25, 2008 | Whirlpool GS5SHAXN Side by Side...
The freezing and refrigerator compartments of my Whirlpool refrigerator began to warm up yesterday, and there is essentially no cooling today. The interior light works, and the fan on the lower par of the...
Greetings fjehlert,
Usually this is indicative of a freon or compressor problem. I would suggest contacting a repair center as soon as possible.
Thanks,
Dorothy
Go Ahead. Use Us.
Jun 24, 2008 | Refrigerators
Samsung Model RS2630SH
if fridge freezer sits down after power outage on a rs21dcns where interior lights are lighting but nothing else is working press power freeze and power cool buttons together for a few seconds should repower unit
Feb 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
87 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
