Question about Refrigerators
We have a side by side refrig. and the ice maker is not working? Any thoughts?
    President:
  • 1,891 Answers
I do have some thoughts . freezer must be 15 deg cold to make ice mker go . ck tempt . also clean cond coils and ck both fans inside and under . they must be working . if you need more help i need the brand and model # thaks mm
Posted on Sep 02, 2010
Ge 26.6 cu. ft. side by side refrig- TFX27R- the ice maker just stopped working.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 23, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker not working since i moved refrig
heatman101
fs45
Aug 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is not working
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have cold water but the ice maker is not working, there is no water in the ice maker
The refrig has 2 coils on 1 valve . 1 coil is for water dispensor and the other is for the ice maker . You need to replace the water valve behind the refrig . This is the piece that the wall water line connects to on the refrig .
Oct 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
G e refrig. ice maker not working Model #pss26msrdss
heatman101
kk
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker won't work
Check your wiring to the timer motor. UNPLUG IT
Take off the cover look for any loose wiring. If all the wiring is in place you may have a bad timer motor.
Jun 28, 2009 | Samsung RS2630WW Side by Side Refrigerator
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Ice maker will not make ice
the ice maker is not making ice but the water is still working
Jan 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
