Question about Adobe Acrobat 6.0 for PC
Adobe Acrobat 6.0 Standard
I have two users on windows xp. I am able to open up AA onone user but not the other. it freezes up and will not configure. Why would I be able to use it on one user but not the other. I have uninstalled and reinstalled twice with out any change.
  • 1 more comment
  • Rechabite May 10, 2008
    It was working fine prior to today. Why would it freeze up all of a sudden?
    It was working fine and now will not start up all of a sudden. I have been able to use on both users for the last two years. Why the change now?
    Wat is parametered?
    Genius:
  • 1,224 Answers
User 2 needs to have full program admin rights for that program so that it can be ran its just getting hung up in the system cause its not paremetered
Posted on May 10, 2008
  • Christophe Thompson
    Christophe Thompson May 11, 2008
    adobe runs more than just one file in comp and adobe has updated drivers to be downloadede
How can I: Enable document rights using Adobe 9...
When you select Advanced > Enable Usage Rights in Adobe Reader the Enable Usage Rights in Adobe Reader dialog box shown in Figure opens
Click Save Now and your file is enabled with the four items described above. You need Acrobat Professional for all enabling features. These commands are not available to Acrobat Standard users (Acrobat Standard available for Windows only in Acrobat 8). When you select the Enable Usage Rights for Adobe Reader menu command and click Save Now all enabling features are added to the PDF.
pleas say thank's
Apr 01, 2010 | Computers & Internet
Can't save Adobe Acrobat 9 fillable forms
Fill in an interactive pdf form After you fill in the form fields, do any of the following:
  • Click the submit form button. Clicking this button sends the form data to a database across the web or over your company intranet.
  • In Acrobat, choose File > Save As, and rename the file to save the form with the data you entered.
  • In Reader, choose File > Save A Copy, and specify a location for the copy. Note: If the form author gave Reader users extended rights, the saved copy will include the entries you made in the form. Otherwise, the saved copy will be blank.
Enable Adobe Acrobat Reader users to save form data Ordinarily, Reader users can’t save filled-in copies of forms that they complete. However, you can extend rights to users of Reader 8 and later so they can do so. In Acrobat Pro and Pro Extended, these rights also include the ability to add comments, use the Typewriter tool, and digitally sign the PDF.
  1. Open a single PDF, or preview a component PDF in a PDF Portfolio.
  2. If you are editing the form, click Close Form Editing in the upper-right corner of the form.
  3. Do one of the following:
    • (Acrobat Pro and Pro Extended) Choose Advanced > Extend Features In Adobe Reader.
    • (Acrobat Standard only) Choose Advanced > Extend Forms Fill-In & Save In Adobe Reader.
    These extended privileges are limited to the current PDF. When you create a different PDF form, you must perform this task again to enable Reader users to save their own filled-in copies of that PDF.
If you don’t want recipients to overwrite the blank form template by saving form data, do not extend rights in the copy you send to them.
Limitations on saving filled-in forms locally
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended each allow Adobe Reader 8 or later users to fill in and save PDF forms locally. The use of the Reader Extensions capability for local saving of PDF forms (called extended documents) is limited in two ways:
Number of deployed extended documents An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to an unlimited number of recipients for them to fill in. For example, an Acrobat customer can post an empty form template on a web page that allows users to fill in and save PDF forms locally. An unlimited number of people can access the template. However, the Acrobat customer can collect only 500 responses from the filled-in form. This limitation includes both hardcopy (paper form submission) and electronic representations of the filled-in form.
Number of recipients of the extended document An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to no more than 500 unique recipients. For example, an Acrobat customer belongs to an organization with 500 people or less. The Acrobat customer can send an unlimited number of copies of the extended document to those 500 recipients and collect unlimited responses from the filled-in form.
Both limitations apply per entity/company, and multiple users in an entity cannot abuse this feature. Obtaining additional licenses to use Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended does not increase the above restrictions. For example, five Acrobat Standard 9 users in a company cannot send out the same extended document to receive and extract data collectively more than 500 times.
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended include technology that can enable PDF documents with certain features by using a digital credential. This credential is located within the Software (“Key”). You agree not to access, attempt to access, control, disable, remove, distribute the Key for any purpose.
I hope it helps.
Regards
Mar 16, 2010 | HP Computers & Internet
Adobe 9.0 Touchup Test Tool Types Wrong Letters
I have not come across this my self, but are you editing from another pc ? as if you are using windows xp with say version 1.0 text, and the file is windows not xp version 3.0 they are not compatible. would need a compatible windows text. text has gone way up from xp with key icons etc so even if you are not using them the file will have the information it it. arabic and other countries key settings as you have said you have tried different key pads and still the same, the software adobe uses is what you are set as.but you could also have different keyboard settings installed into the pc and this can mix match as that is 5 different keyboard layouts. check your keyboard settings and make a default setting to your area. and see if this helps the problem but like i say the systems have change on from windows xp
Jul 02, 2017 | Adobe Acrobat 9 Standard Full Version for...
I cannot read the words
What version is the Adobe Acrobat Reader on your computer? If it is version 9 and you are trying to see the user guide from within a browser window (like Internet Explorer), you will have problems because of a known issue with Adobe Acrobat Reader2_bing.gif 9. If the above is true, you will need to uninstall Adobe Acrobat Reader 9 and install Adobe Acrobat Reader version 8.1.3
(Click Here) to download for version 8.1.3. If you are unsure how to uninstall version 9 and install version 8.1.3, please post a response to this an I will give you details based on your operating system.
Feb 08, 2010 | Microsoft Windows XP Professional for PC
Aobe won't let me use user guide
What version is the Adobe Acrobat Reader on your computer? If it is version 9 and you are trying to see the user guide from within a browser window (like Internet Explorer), you will have problems because of a known issue with Adobe Acrobat Reader 9. If the above is true, you will need to uninstall Adobe Acrobat Reader 9 and install Adobe Acrobat Reader version 8.1.3
(Click Here) to download for version 8.1.3. If you are unsure how th uninstall version 9 and install version 8.1.3, please post a response to this an I will give you details based on your operating system.
Feb 07, 2010 | Acer Computers & Internet
I am using Adobe Acrobat version 9, Windows Vista
Try downloading the latest version of Adobe Acrobat from the Adobe website and reinstall it.
Dec 11, 2009 | Adobe Computers & Internet
Can't click Accept in Software License Agreement dialog box in Ad
This is a simple work around, but it worked for me. Create a new user and make that account the Administrator. Log in with the new account an then run Adobe and click Accept. Some reason this worked for me. Good Luck.
May 17, 2009 | Adobe Acrobat 7.0 Professional
ACROBAT 9.1 WILL NOT INSTALL
“Error 1402: Could not open key [key name] .”
Your best bet here is to do a complete uninstall of all previous versions of reader before you try installation again.
  1. Choose Start > Control Panel (Windows XP), or Start > Settings > Control Panel (Windows 2000).
  2. Double-click Add Or Remove Programs.
  3. Select Adobe Acrobat [version] and click Remove.
  4. When prompted, confirm that you want to remove Reader.
  5. Repeat the above procedure for all installed versions of Reader.
  6. Restart the computer, and then reinstall Adobe Reader.
May 05, 2009 | Adobe Computers & Internet
User Manual
There is no user manual for Adobe Acrobat 9 Professional ,but there is the help that is included with the product and various help books available like Adobe Acrobat PDF Bible & Abobe Acrobat 9: 125 Essential Techniques and many more
Jan 19, 2009 | Adobe Acrobat 7.0 Professional
Adobe Acrobat 6.0 for PC Logo
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
