Question about Cabela's Genesis IV Folding PortaBote Accessories
I have a 10 foot porta bote. Has developed a leak where folding transom meets center seam on bottom of boat. What sealant is best to use?
Outboard johnson modele # J15R4SR serial number S 23030015 do he fit on princecraft springbok 2013 because the transom height is 20 inch.
Set the motor on the transom and make sure the cavitation plate is below the bottom of the boat.
Jun 02, 2017 | Johnson Boating
Y cant i mount my structure scan transducer on the bottom of the boat
This is what the manual says:
The StructureScan transducer can be mounted on the transom,
jackplate, step or directly to your boat's hull.
When mounting it directly to the hull, you must purchase a high-
quality, marine grade above- or below-waterline sealant/adhesive
compound.
Jul 20, 2014 | Lowrance LSS-2 Structure Scan HD Black Box...
Sears 1965 14ft v bottom instructions book boat
3 people and 10 hp motor unless 1 person is really large ,there should be a tag on the inside of transom telling you this info.
May 21, 2014 | Boating
Where is serial number
The serial number on the boat is located on the back (transom) right hand side near where the hull meets the deck. On the outboard motor it's on the bracket that attaches the motor to the transom and usually on the engine block as well.
May 21, 2013 | Nitro Boating
Wheres my bilge pump
It's located in the rear compartment centered on the bottom of the boat in front of the transom.
Jun 22, 2012 | Nitro Collectable Fishing Boat...
I have an 2002 XG350 Hyundai that I have moister developing in the head light. Is the only answere to correct it is to replace the entire assembly?
that is the easiest and maybe the fastest way but it is possible to remove the lens and find the leak first you have to fill it with water and look for the leak usually in the seams is where you will find it then apply some form of sealant i like to sue black RTV silicone base sealant
Dec 19, 2010 | 2002 Hyundai XG350
Radiator is leaking from the top piece. Looks like between the seam of the top piece and the base section, where the two meet. They look to be held by small clamps. It's a slow leak. Is it worth using...
The sealants don't really work and you don't want a problem out on the road. You can take it to a radiator shop or buy a new/ rebuilt one and do it yourself.
Aug 13, 2010 | 1999 Isuzu Rodeo
How to manually raise 200 hp 1995 johnson motor
Mate.Have a look at the bolt holes on the transom.If there is some that are lower than the holes used,no problem.Lower your trailer at the front all the way to the ground.Loosen the transom bolts.2 should be in holes,2 should be in a slide hole.Chock the motor under the skeg.Remove the 2 bolts that are in the holes and very slowly raise the front of the trailer.The motor being 'chocked'.will then rise as you lift the trailer.If you run a line from the bottom of the boat through to the middle of the g/box a cleaver prop should be about 2.5 inches and a chopper prop can run up to 5 inches on a really quick boat.This is for 3 blade props.Make sure when the bolts go back in,plenty of sealant.Hope this helps
Jul 13, 2009 | Boating
Leaking basement foundation
It sounds like the ground has settled around the area where the leak is, hence the traveling water. The right way to fix the problem would be to remove the porch, dig up around the basement wall, apply a sealant to the outside of the wall, install weeping tile and re-grade the soil to drain away from the house. Your best bet to begin with may be to try to re-grade the soil so it is sloping away from the house, however this is only a temporary patch, if temperatures get below freezing there is a possibility that moisture in any crack in the wall could cause further cracking and leaks.
May 25, 2009 | Hand Tools
When it rains we have water coming for under the glove compartement. please help
Hi first you will need to remove the wiper cowl on the right side there will be a water deflector that may have fallen off (that is like a rubber flap that sits over the heater box check that
if it is ok then the winshield is leaking and will need to be resealed hope this helps you
May 09, 2009 | Chevrolet Impala Cars & Trucks
Cabela's Genesis IV Folding PortaBote Accessories Logo
698 people viewed this question
Top Cabela's Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Cabela's Boating Expert? Answer questions, earn points and help others
