Question about Maytag MDB9750AWS Built-in Dishwasher
Upper rack dishes do not get clean - Maytag MDB9750AWS Built-in Dishwasher
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Posted on Sep 01, 2010
  • 105 Answers
SOURCE: dishes not washing clean
check water level in machine
may be not filling enough and the wash pump is starved from water thus not pushing water to upper arm
drain water from machine dismantle and clean out air tube to pressure switch take off air tube at pressure switch and blow back into sump then pinch air tube with fingers to stop air from flowing back up tube then refit to p/s
run and see if that solves problem
Posted on Feb 24, 2008
aborcass
  • 2651 Answers
SOURCE: Upper Rack not cleaning
id try removing hte lower filter plate . 5 torx 15 screws will gain oyou acess to lower sump and 2 more torx screws that will acess you the chopper assy, prhaps filled with debris not allowing good water flow,
Posted on Mar 25, 2008
  • 161 Answers
SOURCE: upper rack dishes dirty
Is it filling with enough water. Look or if you don't know how much water is supposed to be there , Just add a gallon of hot water to the machine after it fills. If this solves the problem check the filter in the fill valve or replace the valve.
Posted on Jul 05, 2008
  • 10865 Answers
SOURCE: Whirlpool GU3200XTP dishwasher - No spray on upper rack
Sounds like the hose assembly that attaches to the rear of the upper rack has come undone. just pull out the upper rack and reconnect it.
please rate my answer as a fixya! thanks.
Posted on Feb 14, 2009
  • 38 Answers
SOURCE: Whirlpool Dishwasher Model GU1200XT
Check the upper spray arm for debris plugging the spray holes, if clean then pull off lower spray arm and filter screen, and clean and remove any debris found in the sump, check the disposal blades as well. You will need a torx style screwdriver to remove the sump screen on this unit. You can buy a set for under $10 at your local hardware store.
Posted on Feb 23, 2009
Glasses do not come clean in the upper rack but do in the lower. Is there someplace that should be cleaned out to make the upper rack work again
Not knowing what dish washer you have I would check on the sprayer make sure it turns or is not blocked in any way. If the water can't spray up you will not get clean dishes.
Apr 28, 2017 | Dishwashers
Top dish rack dishes don't get clean model 8575637
Most dishwashers have a rotating spray bar underneath the upper rack. Over time bits of food can clog up the holes and then dishes won't get clean in the upper rack. Check to make sure all the holes in the spray bar are clear and that it is rotating freely.
Mar 22, 2017 | Dishwashers
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
Sep 13, 2014 | GE Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
Mar 15, 2012 | Kenmore Dishwashers
Dishes not clean?
Check all the water jet orfices in the moving arm. Try cleaning without loading the top rack.
If cleans well, mostly the upper rack dishes not arranged properly.
I hope you are using the main wash detergents. Rinse aid is just to remove the stains after the main wash rinse.
Apr 01, 2010 | Dishwashers
Dishes bottom rack are marginally clean. upper rack is never clean anymore. The dish washer cycles through NORMAL and Dries dishes OK. Motor is running, and rinsing can be heard as well as washing cycles....
Just fixed my Frigidaire. The outboard o-ring on the main pump became distorted and stretched. Check your local hardware store as Frigidaire wants $17.50 + shipping. Good luck
Dec 25, 2009 | Dishwashers
Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Nov 13, 2009 | KitchenAid Dishwashers
Feb 14, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Maytag MDB9750AWS Built-in Dishwasher Logo
142 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
