Question about Vivitar ViviCam 5024 Digital Camera
Please help!!! I pressed the mode button on my camera and instead on pressing exit i pressed format now i cant find the pictures of my sons first day of school
  • 6,831 Answers
Hello
Download THIS.
Download this free tool and run it on you card and it should be able to recover all pictures provided that you have not used the card since formatting. I recommend using a card reader for this.
After downloading and running (no installation required) , simply select deep scan and your memory card and it will start scanning, To recover a found file , right click it and select save.
Please note that the file names will probably not be available and also that some of the properties of the photo like date taken could be lost.
Please let me know when you have recovered your pictures safely or contact me if you need further assistance.
Regards
Andrea
Posted on Sep 02, 2010
Is there a way to delete all the pictures instead of one at a time on a nikon d70 camera
Yes there is, format the memory card as follows.
Format the memory card Memory cards must be for mat ted be fore ? rst use. Formatting Memory Cards Formatting memory cards permanently deletes any data they may contain. Be sure to copy any photographs and other data you wish to keep to a computer before proceeding ( 171-174). To format the card, turn the camera on and hold the format buttons (Shooting mode and LCD illumination) buttons down simultaneously for approximately two seconds. A blinking will appear in the shut ter-speed display and the frame count will blink. Pressing both buttons to gether a second time will format the memory card. Press any other button to exit without formatting
Shown on page 21 of the manual. The manual can be downloaded here http://www.nikonusa.com/pdf/manuals/dslr/D70_en.pdf
It is a great idea to format the card rather than deleting photos
Hope this helps
Jun 17, 2011 | Cameras
How do I delete all my pictures off of my samsung s760?
There are basically two ways to delete all the pictures on the card.
If you don't mind erasing all the data on the card, the best way to get rid of it is to format the card. Formatting flash cards (SD, SDHC, SDXC, MMC, CF, Memory Stick pro or duo, etc) actually helps the cards last longer. To format the card, enter review mode (usually a button with an arrow pointing to the right) and press menu, navigate to format card and press enter / ok.
To just delete all pictures, enter review mode and press the delete button (usually looks like a trashcan). That should open single delete mode. Press delete again to open multi-delete mode.
Both directions should work on most common camera models (Sony, Canon, Nikon, Olympus, etc).
Please leave feedback if this was helpful. Thanks.
Apr 16, 2011 | Samsung S760 Digital Camera
Trying for format my memory card - keep receiving error message will not let me format
Follow these steps to format your memory card. In any mode, press the Menu button. Press to highlight Setup , then press the OK button.Press to highlight the setting you wish to change, then press the OK button.Choose an option, then press the OK button. Press the Menu button to exit.You will be having a setting named as format. Click that and format your card. This will reformat your card.
Thank you !!
May 24, 2010 | Kodak EasyShare C330 Digital Camera
How do I format an SD card for a Vivicam 3785?
You can format the SD card in your ViviCam 3785.
This utility formats the internal memory (or memory card) and erases all stored images and data. Make sure your SD card is in the unlocked position.
1. Press the button to turn on your ViviCam 3785.
2. Press the MODE button twice to enter Playback mode. Then press
the button to enter the Playback menu.
3. Select [Delete] by using the up/down arrow buttons, and press the OK button.
4. Select [Format ] by using the up/down arrow buttons, and press the OK button.
5. If you want to format your SD memory card or the internal memory choose
[OK] by pressing up/down arrow buttons, then press the OK button to confirm.
 To cancel the action, select [Cancel] instead.
 [No Image] pops up after the SD memory card or internal memory
has been formatted.
If you need a manual for your camera you can download a free PDF at
http://www.retrevo.com/support/Vivitar-3785-Digital-Cameras-manual/id/200ag818/t/2/
Please rate this solution. Thanks.
Jan 15, 2010 | Vivitar ViviCam 3785 Digital Camera
Can card be reformatted
Use Setup to customize your camera settings.
1 In any mode, press the Menu button.
2 Press to highlight Setup , then press the OK button.
3 Press to highlight the setting you wish to change, then press the OK button.
4 Choose an option, then press the OK button.
5 Press the Menu button to exit.
goto the setting named format,
Regards
GeWiz.
Oct 29, 2009 | Kodak EasyShare C330 Digital Camera
Memory Error appears on screen
Just had this problem myself. What you do is press the Mode button twice until it shows a black background with the words Memory Error on top of it (this should be the picture preview mode). Then press the Menu button and press the 4-way button right to enter the Setup Menu. Go down and Format the camera and that will fix it.
Good luck.
May 05, 2009 | Sanyo VPC-S880 Digital Camera
How do I clear pictures out of memory?
The following is from the manual (shutter button is the OK button):
1. Press MODE key to enter the playback mode.
2. Press the MENU button and select Delete One/Delete All, press OK to confirm.
3. Press MENU to exit.
Apr 10, 2009 | Kobian CyberPix E-550V Digital Camera
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
DELETE
Good Day, thats correct, in play mode, select pictures by pressing L & R cursor you want to delete, then press garbage/pail, press the UP cursor to highlight the delete word, then press the button at the center of the 4 cursors buttons. then press garbage/pail again to exit. thanks
Sep 02, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Vivitar ViviCam 5024 Digital Camera Logo
54 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
