Question about Dell PowerEdge 2650 (PE2650BB) Server
Turn on and no video and it does not boot up - Dell PowerEdge 2650 (PE2650BB) Server
  • 3 Answers
Bad power supply but check power source first
Posted on Sep 02, 2010
Scrambled screen
could be any number of things... Bad cable, intermittent connection, bad video card. . . not enough info here to diagnose the problem
Aug 31, 2014 | Dell OptiPlex GX620 PC Desktop
My laptops cant open when you turn it on, but if you put in a cold place it will open when you push the on/off button
Usually the problem is with the video card. You might need to have it serviced/replaced. Try booting in Enable Basic video driver:
1. Turn the computer on 2. Tap on F8 as the computer boots up 3. you will get the advanced boot option 4. Choose enable basic video driver
Once you have booted the computer, you will notice all the icons will be larger. Go to support.dell.com and try to look for the driver list for the model type of computer that you have. Download the latest chipset and the latest video card driver.
Things to take a note of:
1. Check the driver that is compatible with your operating system 2. Make sure you know if your OS is 32 bit or 64 bit. Download the appropriate driver.
To check on the type of operating system
1. press on the windows button + R 2. type msinfo32
check on the Operating system
if it says x86, it means that it is a 32 bit OS if it says 64 then it is 64 bits
Jun 28, 2011 | Computers & Internet
After installing new video card it takes a long
Without more info it's hard to say for sure but here's a few suggestions.
Turn your power completely off, unplug your computer, double check all your connections, memory, cards, cables, the works. Any loose connections can cause multiple rechecks.
Check your BIOS for quick memory test and set it to "yes" or "enable".
Look to see if you can skip some of the memory tests, if so, skip them, you don't need them unless your having problems.
Set your boot sequence to check only the drives you normally boot from. If you usually only boot from your hard drive set it to only check your hard drive, you can change it latter if you need to boot from a different drive, this is faster and more secure.
Turn off "floppy seek at boot" unless you use a floppy drive.
Turn off your serial ports if you don't use them.
If your computer has unused IDE controllers you can turn them off too.
Be sure to make notes of everything you turn off, it can be a real pain to trouble shoot a problem for something you turned off and forgot about.
May 24, 2010 | Biostar P4M900-M4 Motherboard
My monitor won't turn on, when boot up it goes
the problem is not the monitor. the video card itself. replace it or before you do that, try reinserting the video card or clean the contact before you reinsert it..
Oct 29, 2009 | Dell SE198WFP LCD Monitor
Acer netbook wont turn on
You must be facing any of these four issues:
1) power issue
2) No POST
3) NO Boot
4) No video
Power issue - the system does not turn on at all. In this case check the AC adapter and the battery.
No POST - You may have to check the Memory, Hard drive and the optical drive. Can also be an issue with the video card2.gif/ key board/ mouse/main board which can prevent the system from turning on.
try reseating all the components above except the motherboard.
No Boot - Issue with the Operating system2.gif. Try booting into safe mode and check whether the system turns on perfectly. If so try to uninstall all the software you do not use. and may also consider a system restore2.gif. else consider a Dell Complete factory restore.
No video - Try flashing light on the screen and look for the desktop. If you see the icons then probably the back light needs to be changed else the issue is with the display itself or the video card.
Kindly comment.
Sep 16, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Turn on Pc and I get 3 beeps and it shuts off
make a clean the memory or replace the memory
May 23, 2009 | DFI AK74-SC Motherboard
Videocard not working
Try removing the new card, booting into BIOS, change your video setting the slot of your card: I believe your card is PCI-E, save changes and exit. When it starts to reboot, turn the computer off, install the new card and then try rebooting again. You may also have to boot into Safe Mode\Uninstall the original video driver or disable that video component and then try rebooting your system.
Mar 29, 2009 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
IBM A31 2652 Video garbled video at boot
This is very possibly a hardware problem, namely a crack in the motherboard. Sorry, no easy or cheap fix for it if that's the case.
Feb 18, 2009 | IBM ThinkPad T42 Notebook
ASUS P450-VX -How to diasable on board video
The onboard video should be disabled in bios.
Dec 11, 2008 | ASUS Terminator P4 PC Desktop
Hp compaq dc5000 small form factor
Hi, uninstalling the onboard video will only be reinstalled by Windows next time you boot up. Disabling it in the Device Manager might and mght not do the trick if your mb is set on using the onboard. You might want to try and disable the onboard video in the CMOS/BIOS set-up. In some instances, you are asked in the BIOS what video will be used such as onboard, AGP or PCI or a selection of something like that. Also you can try and not allocating any memory to the onboard video. Hope this be of some help. Pls post again how things turn up. Good luck.
Apr 28, 2007 | HP Compaq dc5000 PC Desktop
Dell PowerEdge 2650 (PE2650BB) Server Logo
119 people viewed this question
Alun Cox
