Water not getting into washing machine miele novotronic w830
Washing machine (miele novotronic w830) as of yesterday will not work.
The water does not seem to be getting into the machine. It is only dribbling through.
Tap works, pipe clear at both ends.
I lifted the top cover of the washing machine and disconected the black pipes leading into the area we place our detergent. But only at that end. The other ends are still conected. I then turned on the machine and the only pipe to have a little water come through it was the K 5 inlet pipe. If that makes sense.
Kind Regards,
  • sarah714 Mar 02, 2009
    Amazing - I really do have the same problem! I haven't taken the top off the machine but have checked the pipes - The water pressure seem fine through the hose to the machine but only a trickle of water goes into the soap powder dispenser.
    I have an engineer booked for Thursday but would love a solution before!!!
Thank you for advice! My Miele Novotronic W830 is 17y old, been working well, until yesterday. When taking water, much started spilling on floor under the left lower corner of the machine.
I opened the cover, found a loose hose under the detergent tray, did set it back in place and tightened the band.
First you better loosen the band, it slips more easily on the funnel.
In my photos you can see the screw is pointing to wrong direction to be able to use a screwdriver, but I did manage it with bare hands.
Be sure there is no power connected when opening the cover!
And don't drop anything inside, when opened the cover, it is a nasty place to get it back...water not getting into washing machine miele novot - 8_26_2012_3_23_27_pm.jpg8_26_2012_water not getting into washing machine miele novot - 8_26_2012_3_24_47_pm.jpg_mi8_26_2012_3_24_47_pm.jpg
Posted on Aug 26, 2012
  • 106 Answers
Change your inlet valve, it would solve your problem.
Sites for spares:
Posted on Mar 14, 2009
  • 3,587 Answers
K5? which pipe is that..let's assume you have pressure to the back of the unit, yes? then you have a valve sticking or something obstructing the channels inside that unit..
does this work regardless of temperature setting.
Posted on May 10, 2008
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Miele W830
Yes your diagnosis is correct. We had the same on a machine that had done 12,400 washes on a life expectancy of 8,000 washes. Great machines. Airport lounge washing dozens and dozens of towels every day, 7 days a week.
Our machine had a sensor that doesn't let the machine spin at full speed if the drum is out of balance. It was something like a WS3120. We swapped it out for a much larger Miele.
Dec 04, 2017 | Miele Novotronic Premier 500 Front Load...
Miele novitronic w830. Drain wont work. I've cleaned the outlet of dirt and the wheel inside the outlet is spinning freely. Reggadles, red light comes up.
Have you tried checking the drain spigot under the sink where the waste hose connects as it can be blocked at this end?
Try draining the unit into a bucket instead of the sink this will eliminate the washing machine as being the problem if it works ok.
is the drain pump actually turning? select drain or drain spin and have the fluff filter (outlet) removed so you can see if it is turning. if it isn't turning there maybe a broken wire to the drain pump causing it not to turn or the drain pump is jammed with something although you mentioned you could spin it freely.
hope this helps
Jun 01, 2010 | Miele Novotronic Premier 500 Front Load...
How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Jan 10, 2010 | Miele Novotronic W1918A Front Load Washer
We have a Miele W830 Novotronic washing machine. Water started pouring out the bottom l.h. door from drain pump area when we tried to do a load of washing tonight. We've taken it out and cleaned it...
Although this answer is obviously not current any more I thought it may help others. We recently had the same problem with our machine. The clamp holding the hose to the detergent drawer became loose and the hose came off, allowing water to pour right down to the drain pump area. By undoing the 3 screws behind the detergent drawer + the 3 bolts around the door, I was able to open the front of the machine and tighten the hose clamp.
Oct 18, 2009 | Washing Machines
W830 washing machine stops before end of cycle.
could be something to do with the drain pump, the machine gives itself 3 mins to get bellow a water level before it spins, if it cant make the water level in 3 mins it stops because the weight of the water and clothes would be too much for the machine that would start to dance the tango, check the pump and sump for minor blockages first.
Jul 23, 2009 | Miele Novotronic Premier 500 Front Load...
When I use cold wash on my Miele W830 the water heats. Any solutions?
check the water connections going to the back of the machine, you may have the hot and cold mixed or reversed. if you turn it on hot water will it dispense cold water?
Jun 30, 2008 | Miele Washing Machines
Miele W830
I have exactly the same problem - what was the answer ?
Mar 15, 2008 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
1,374 people viewed this question
Top Washing Machines Experts
