Question about Samsung RS2630WW Side by Side Refrigerator
My SAMSUNG SRL626EV has the air flow system that does not work anymore. What can I do? Many thanks for your support
  • Samsung Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 01, 2010
If the fan does not work does this effect the cooling system?
YES AS IT WILL NOT CIRCULATE THE COLD AIR , CHECK UR AIR FLOW DAMPER VENT AS WELL
Jul 05, 2014 | Samsung RF267ABRS Side by Side Bottom...
I have a 1999 chevy silvarado my heater\AC vents do not work properly anymore. Everything comes out on the floor.
I would suggest to check the selector switch. If there is a loose connection there you will not be able to select the direction where the air should flow.
Jul 26, 2008 | Chevrolet Silverado Cars & Trucks
I have a samsung side by side and the freezer side is not freezing but the fridge side is
Not detailed description of your Refrigerator Problem?
1) Frost free system (Heater, Timer, Drain heater) properly not functioning.
2) Evaporative Fan not working (Check Air flow satisfied or not)
3) Compressor properly not working.
4) Thermostat (1,2,3 ) problem. (Rotate high and check)
Mar 23, 2011 | Samsung Refrigerators
Heat stops working. No heat from heater on my 1999 S10 V6.. I have "burped the cooling system after which I get plenty of heat but eventually it stop working after driving 2-3 days. Should the heater...
Air is getting into the system. Tighten all hoses and do not overlook the hose going to the expansion tank. When car cools that hose sucks water back into system but if not tight it will suck in air. Could be why you constantly have to "burp" the system.
Jun 13, 2017 | 1999 Chevrolet S-10 Pickup
Samsung RSA1DTWP
Check the fan units for freezing up. Its just a matter of clearing and removing the units. Ice may make it a bit of a tight problem. Defrost with a hairdryer and make sure the drains are clear. It worked for me. Paul.
Jul 11, 2010 | Samsung RS2630SH Side by Side Refrigerator
Im getting no heat in my 1999 Pontiac Grand Am, I just replaced the lower and upper in take gaskets due to them leaking and the thermostat, I have bleed the system numerous times and I was told that I have...
Put your heater temperature control in the max position on(this opens the valve for coolant flow through the heater core). Top off the radiator and the coolant resevoir. Make sure the cap is on tight and bring the engine up to operating temperature. Shut off engine, allow to cool, and top off the radiator again. Repeat these steps until you are sure it will not take anymore coolant. Drive the car at speed for 5 or 10 miles and recheck again when cool. It takes awhile to work air out of the system with multiple openings of the thermostat.
Jan 04, 2010 | 1999 Pontiac Grand Am GT
Protection...Good Bye!
well after taking apart my unit, i found that fan is not moving the air flow, so i turned it around and for 3 days now it has been working like new
Sep 05, 2009 | Samsung HT-TX72 Theater System
My Samsung side-by-side refrigerator is not cooling.
your condenser is not working you likely had the fan go out or not enough air flow.
these units have a problem and Samsung refuses to recall them. get a different brand
Jul 20, 2009 | Samsung RS2630WW Side by Side Refrigerator
My havc is working outside and the blower is working inside
If the evaporator has ice build up over coils it will block air flow but that obviously would occur after the system has run a while.Shut the system down and allow it to thaw completey which could take some time,start it back up and see if air is passing through evap coils
Jun 25, 2009 | Dometic Rooftop RV Air Conditioner
Samsung MP0402H
This trick is the proverbial 100 to 1 long shot but is worth trying with any drive that suddenly stops working - put it in a freezer bag, squeeze out as much air as you can an the put inside another freezer bag and then place in a freezer for an hour. Fair dinkum, this sometimes works but the drive may only work for an short time if quickly re-installed. If it does work, unload critcal data IMMEDIATELY.
Oct 07, 2008 | Samsung Spinpoint MP0402H 40 GB Hard Drive
Samsung RS2630WW Side by Side Refrigerator Logo
113 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
