Question about Coleman Heating & Cooling
Blower runs on furnace, but not on outside unit.motor is not stuck, turns freely.
  • Coleman Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 01, 2010
Central a/c fan will not start after flood
replace the fan motor as the bushes are dry and seized up.
Jun 09, 2013 | Heating & Cooling
Cooling begins then indoor blower stops...outside unit continues to run
I had the same problem,if you do not monitor that you will make matters worst and burn the Compressor.your problem is the blower unit it has three speed sometimes four.it needs to be changed..
May 20, 2012 | Heating & Cooling
Air is not blowing out with any force
if "not blowing out with any force" is refering to the outside unit .. then make sure the fan is turning and up to speed .. if not then make sure it turns freely without power .. if not then lube the bearings or replace the fan motor ... if it doesnt start at all but turns freely by hand then replace the starrting capacitor (about 3 inch metalic rounded rectangle with wires going into the compressor and fan) .. make sure the condenser coil is not clogged with leaves (wash out) ... if you are refering to the inside unit not havinng much force .. then replace the furnace air filter .. check to make sure the blower turns freely ... check the evaporator coil for blockage with dust ..
Jul 25, 2010 | Goodman CKL24AR24 Air Conditioner
Outside heating unit runs all the time
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Feb 19, 2010 | Heating & Cooling
You can hear furnace running but the blower never comes on.
do you mean the inside blower or the outside unit blower ... actually the problem might be a similar part in either case ... the blower motor has a capacitor mounted on it or near it ... it will be marked something like 160 uf at 200vac or similar . it will have wires attached or plugged into it .. the capacitor is what gives the blower motor a signal to tell it which way to start turning ... once the blower is running then the capacitor is no longer needed ... its only used to get the motor started ... if its bad then the motor will hum but wont turn .. if you manually spin the fan then the motor will take off in the direction you spun it (dont get hit ) .. a new capacitor is not expensive .. you need the numbers off the old "starting" capacitor or just take it with you to the parts place to match it up .. you may be able to order it from Ruud ... a HVAC repair person would likely be able to bring one with him for repair if you give him the numbers off the part or the model number of the furnace .. make sure the blower turns freely by hand (with power off) .. if not it may need bearings lubed .. ..
Nov 05, 2009 | Ruud Central System Air Conditioner
Blower in attic & AC unit outside continuously run
Sorry to hear about your miss-fortune, you are right it is an wiring problem. Can you turn off the blower with the thermostat (cool-off-heat) or what happens when you switch the fan to (auto or on) When you say the outside unit is "rigged" is it mechanically being jammed or electrically? If its mechanically that should be removed (what a crappy thing to do) other wise it will run continuously as you may already know. That is what it sounds like, you should just be able to shut the entire system down by turning off the switch to the furnace. If it is electrically being held closed, he changed some of the wiring around in the attic unit, you better hope he was lazy and jammed a stick in the contactor in the outside unit or else you may need to learn more about HVAC wiring, none the less I would double check the thermostat wires going to the attic furnace there should be nomenclature on the unit or at least somewhat marked. This was probably disturbed when the new blower was installed, by the way that was your initial problem. Good luck and becarful
Aug 17, 2009 | Ruud Matching Split Air Conditioner
No forced air.... compressor unit and furnace do kick on
Bad blower motor/capicitor or relay. Check the fuse if it has one.
Aug 11, 2009 | Heating & Cooling
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
37 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
