Question about Uniden 5.8GHz Dual Cordless Phone
I have had my Tru 885-2 for a few years and have recently started having problems with static on both the handsets and the answering machine. It is located by my DSL modem and I have tried turning it off with no improvement. Ideas?
4 Suggested Answers
SOURCE: Tru 9496
SOLUTION:
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
Posted on Sep 29, 2008
SOURCE: two sets Uniden phones with base, second handset: incompatible?
I had the same problem with a Uniden 3355 handset and 2355 base. With the new handset I pressed "Menu" and selected "System Reset". I then Selected "Deregister HS" and followed the prompts.
Once this was complete, I returned to "System Reset" and selected "Replacing Base". Following the prompts, when it said "Register Handset" I put it in the base of the 2355, and within a minute it had registered, so both handsets used the base of the 2355!
S.
Posted on Jan 09, 2009
SOURCE: Static interference on Uniden 5.8Ghz phone
i have a uniden 5.8 ghz cordeless and thought it was a piece of junk as well. I had static or lapse of audio near the router, the kitchen sink, the microwave (even when off) and in the doorway. I switched the frequency on the router and changed the channels on the phones all with no luck. Short of steering clear of my entire downstairs nothing worked.
Just about ready to buy a new phone and hit up google. Saw a posting that said to keep the base away from even the tv. . .hmmm this is exactly where mine was located. So I swapped the digital answering machine base and moved it downstairs and put the additional base near my flat screen. Guess what? Problem SOLVED! I still cannot believe it.
Hope this helps
Posted on Aug 07, 2009
How do I leave a message for my answering machine
Ask the service provider
Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual
www.fixya.com/.../p3148769-panasonic_kx_tg6531b_digital_dect_6_0...
Recent Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual Voltage Cordless Phones Integrated Answering Machine 110-220 Volts questions, problems & answers. ... Model KX-TG4021 - How do I put in a new answering message? ... Why won't my answering machine, Panasonic Easa-Phone KX-T1460 allow the ...
change amount rings panasonic kx tg7643 Answering ...
Jan 12, 2016 | Panasonic KX-TG6531B Digital DECT 6.0 1X...
So much static I can not hear properly
The line that stays lit for line 2 is just the way it is.. not a problem. If you only have one phone line and a two line phone you will always have the one (non working line 2 ) lit.
Have you replaced the cord to the handset? Many times it is a bad cord that causes static.
May 11, 2010 | RCA ViSYS 2-Line Speakerphone
Uniden TRU 8885 - "Welcome, Please Wait" message on base
Try leaving the unit unplugged for a few minutes and power it up. There can be power surges during an outage that can damage the chips holding the software that loads.
Aug 23, 2009 | Uniden TRU8885 Digital Answering Machine
Possible battery going bad???
The signs of a bad battery are: going to static while talking on it, going dead after a short period of time, or needing constat charging.
Apr 13, 2009 | Panasonic KX-TGA552M Cordless Expansion...
Two sets Uniden phones with base, second handset: incompatible?
S.
Jan 09, 2009 | Uniden Cordless Phone
UF-885 Panafax
Unplug the power cord in the rear of the machine
Open the document feeder by pulling it straight up
hold down the pointed switch by the scanner glass while plugging the machine back in until you hear a beep
close the document feeder
scroll down to SHIPMENT SET
press SET or START
press 2
wait for the machine to reboot.
Dec 30, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Needing a manuel !!!
You may download a copy of the manual here.
Nov 10, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
If there are two RJ-11 jacks on the fax machine you need to make sure that the line from the wall is plugged into the LINE jack not the TEL jack. If that is not it let me know and I will provide you some troubleshooting instructions from the factory service manual.
Sep 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Adding speed dial nos to uniden waterproof handset
I found the model no, on the Uniden website DSS 7805WP and down loaded the manual.. there were no instructions .. but i showed where the phone book icon was .. and once inside the phone book the process was the same as the handset that came with the answering machine.
Jun 19, 2008 | Uniden Tru-Digital Expansion Waterproof...
Phone problem
I lost my manual for my GE 5.8 cordless gigahertz phone, and don't know how to program numbers in it. Can you please help me out?
Nov 30, 2007 | GE 25952 Cordless Phone
Uniden 5.8GHz Dual Cordless Phone Logo
53 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
