Question about Nokia 1100
Not charging hi i have nokia 1100 mobi phone if i connect with charger its show not charging
    Genius:
  • 1,224 Answers
Plug is bad or the battery is bad one of these 2 things need to be replaced if you have a car charger try that it will let you know if your battery or charger needs to be replaced
car charger will start chargin battery
Posted on May 10, 2008
Nokia 1100 not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 01, 2010 | Nokia 1100
My 1100 mobile phone showa not charging
There are several reasons, like bad battery, bad charging connector, bad charger, charging pin problem, charging ic, etc..
You need to try with another charger and with another battery. If changing the charger and battery don't help, follow the instructions below;
First, remove the battery, clean the contact points on the battery and also clean the battery interfaces on the mobile. You also need to check the charging connector and clean whatever is possible. Use soft brush or cotton with Ipa solution or alcohol/spirit/acetone to clean all the metal contacts. Try charging again.
If the above method don't help, you need to change the charging pin;
Still the problem persists, then check the charging ic. Perhaps jumpering will be necessary.
If you are not sure what you gonna do with ic, I don't recommend to play around with it, rather take it to a mobile repairing shop or nokia service center and get it fixed. You may damage another components.
I wish you good luck.
Thanks for using FixYa.
Jul 24, 2010 | Nokia 1100
Not charging for nokia 1100
when u conect charger if its shows NOT CHARGING,, its uem fault and u cant change uem. its better to use universal charger
Aug 11, 2008 | Nokia 1100
NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Feb 16, 2008 | Nokia 6630 Cellular Phone
Not charging
your battery is a dead cell or your battery is not working any more, change your  battery for new one
Oct 30, 2007 | Nokia 1100
Charging problem
Change it...
Oct 25, 2007 | Nokia 1100
Charging
not charging
Oct 04, 2006 | Nokia 1100
Nokia 1100 Logo
96 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
