Question about Panasonic PT-53WX42 53" Rear Projection Television
PWRB LT BLINKS 3 TIMES THEN SHUT OFF - Panasonic PT-53WX42 53" Rear Projection Television
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
3 BLINKS IS SHORT PROTECTION, 98% of the time it means one of the protect resistors around the convergence chips is gone.
I can tell you what and where to look to confirm this--if this is the case I also have start to finish, step by step instructions for this repair in your set.
Let me know and if this information told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Sep 01, 2010
Need fuel system diagram for 1997 Dodge Grand Caravan.3.8L
Check fuel pressure check spark .cycle key 3 times and count check eng lite blinks 12 is starting code rest
Eng codes 55 end codes
g Lt.Blinks
Apr 21, 2017 | Dodge Grand Caravan Cars & Trucks
W KDS-R50XBR1 50 in. HDTV Television standby light blinks red 3 times
Something you might want to look at:http://sites.google.com/site/sonylcdrptvproblems/lamp-overheating-issue
Apr 06, 2012 | Sony KDS-R50XBR1 50" HDTV
Epson Powerlite 82c over temperature sensor shut down projector. Filter & interior blown out but it still won't light up lamp - confirmed good bulb. Any suggestions? Is there a hardware reset button s
MP82, OPTICAL ENGINE <>>1431299
Discontinued (no longer available)
red_dot.gif 0120 1439509 EMPS4, CASE, LOWER <<> 1412071
Discontinued (no longer available) red_dot.gif 0140 1451875 EMP1715, FRAME,AIR FILTER <<> 1243486 red_dot.gif 0150 1434913 EMPS4, AIR FILTER;A<>>1454798
Discontinued (no longer available) red_dot.gif 0150 1454798 EMPS4, AIR FILTER;A<<>1434913 $ green_dot.gif
9 0251 2118172 EMP1815, FAN, INTAKE;B <>>2119429
Copy and paste from dealer info (with some parts deleted) and Example of Ballast,
Id say the ballast is blown or its power supply (PSU), Sorry I'm not confortable giving you testing procedures for the power supply or ballast as it involves very high voltage, even present when unit is powered down, and is too much of a safety risk to be operated on outside of the workshop without proper systems in place. (ie we are all trained in procedures, and use current limiting devices on our work benches), these things can pack a punch and are not something to be playing inside of. 11_2_2011_8_34_03_am.jpg
Nov 01, 2011 | Office Equipment & Supplies
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
My picture shut off. Power lite clicks, blinks,no picture
how many times is the power light blinking as thats a error code. 3 blinks is the most famous which means convergence circuit failure.
Oct 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
No Picture or sound
The lamp cover door was not secured tightly. Door does not "push" shut easily. Got a little rough with it and latched it shut, then the tv worked fine.
Jan 27, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
PT53WX54J Shut Off LED blinks 3 times
3 blinks LED shows problem with convergence out ICs that either bad or not getting supplied volts from supply board to function properly.
Sep 08, 2008 | Panasonic PT-53X54 53" Rear Projection...
Panasonic PT-47WX54J shut off - LED blinks 3x
Your convergence ICs need to be changed. 3 Blinks is a convergence error. I can post a link where you can get new ICs and they include free instructions with pictures so you can do the repair yourself, they also offer instant messaging with a tech while your doing the repair thats a free service when you but their replacement parts. Let me know if you would like the link.
Apr 04, 2008 | Televison & Video
Panasonic PT-53WX42 53" Rear Projection Television Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
