Question about GTCO Roll-Up Digitizer, 30/36" (RU3036)
Dead spots in the corners. In the center where it's working, repeated measurement of the same area comes up with different values each time.
    Genius:
  • 1,478 Answers
I will advice you reset your device, once you reset the device, it should function well as before and fix the problem.
Take care.
Posted on Sep 01, 2010
How can I set tappits when engine switched off. Thanks for the previous answer. It helped.
Top dead center cylinder 1 measure tappit gap loosen nut on adjuster use screwdriver to lessen or increase gap keeping driver in addition tighten nut making sure adjuster doesn't rotate check gap again readjust if necessary repeat for other tappet
top dead center cylinder 2 and repeat above same for each cylinder
if the engine is an overhead cam the above won't work
Feb 23, 2017 | Cars & Trucks
Calculate cubic feet of stone wall 120'long x 6'-6" high x 3" thick
your measurements are in different units, say feet and inches, you can first convert those values to feet, then multiply them together to get the square footage of the area. If you are measuring a square or rectangle area, multiply length times width; Length x Width = Area.
Aug 23, 2016 | Office Equipment & Supplies
The manual freewheel lever will not go into gear
hi, 7 flashes implies the throttle lever (speed pot etc) is not in the correct position, other words not dead center, (PGDrives S -Drive Controller)
Let me explain , the pot in question is a 5K value and the throttle lever rests in the center of that about 2.5k give and take
If you can see the bottom of the metal stem in with the throttle lever is mounted there should be a cross head slot now that should be dead center, the slot facing you as you sit on the scooter, slightly off center will cause the fault reported.
Regards
www.gewizrepairs.co.uk
Please rate my assistance.
Jan 01, 2013 | Pride Value Line Revo Scooter 3 Wheel
What are my options to deal w/ dead spots in my home - wrt310n
First, it is all about placement of your router. try to put your router in an open space, not too high up, not too low down. Keep objects away from it and keep it out of the corner.
Second, If these do not cut down on dead spots, you need to get a wireless repeater. A repeater repeats the wireless signal from farther away. Its like a second router that is closer, so you can get better signal.
Mar 06, 2011 | Linksys WRT310N Wireless Router
Iv put two of the same record on each deck and set them to 0% and I have to adjust them to keep them in sync
The problem is the "tolerance" of the electronic components that go into all electronic devices - your turntables included. Take a simple resistor. Buy 2 (or even 2 dozen) of the same value and measure them with the same meter. I bet you'll see to different values displayed. Next, use a different meter to measure the same resistors - I bet they display yet different values. You can do the same thing with 2 transistors, capacitors - you name it. It's not limited to just electronics, either.
Manufacturing processes have not managed to hit the 100% predictability mark yet. As a result, no two parts produced are exactly the same. No two loads of raw materials are the same - so it is going to be practically impossible for the finished output to be the same. Sure, they've come close - but I doubt we'll ever see the kind of similarity between supposed "identical" devices that you're looking to find.
You may find that "sweet spot" of pitch on 2, 3 or even 50 turntables where they play exactly in sync, but the indicator dials will not be in the same exact spot.
I hope this helps.
Dec 28, 2010 | Vestax Pdx2000 Direct Drive Turntable...
My ViewSonic va1930wm monitor has black spots.
How long have you owned it? Mine did the same thing. It was a dead spot which got worse. It was just past warranty (of course) but I took it back to Home Depot & they worked with me to get it replaced. Unfortunately, I think this is your only hope. The monitor dept. told me that once they get dead spots there is nothing you can do for them. Wish the news was better.
Feb 07, 2009 | ViewSonic VA1930WM LCD Monitor
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
How do I adjust date of my watch bought from GAP
I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
Nov 12, 2008 | Watches
What is the difference in metering among multi-segment, spot, and center-weighted?
Multi-segment metering uses 256 segments to measure luminance and color. This data is combined with distance information to calculate the camera exposure. This advanced metering system will accurate worry-free exposures in almost all situations including backlight condition. Spot metering uses a small circle area within the middle of image to calculate the exposure. The spot allows precise exposure measurements of a particular object without being influenced by extremely bright or dark areas within the scene. Center weighted measures light values over the entire image area with emphasis given in the central region. In backlight condition or when the subject is not in the center of image, exposure compensation will be required.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Metering modes
There are three metering modes: Digital ESP, Center Weighted Averaging and Spot. DIGITAL ESP - The camera meters and calculates the light levels or light level differences in the center and other areas of the image separately. CENTER WEIGHTED AVERAGING - The metering mode provides the average metering between the subject and the background lighting, placing more weight on the subject at the center. SPOT - The camera meters a very small area around the center of the subject, defined by the spot metering area mark in the viewfinder.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Computers & Internet Logo
43 people viewed this question
Top GTCO Computers & Internet Experts
David Payne
David Payne
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
