Question about Philips 42PF7320A 42 in. Plasma HDTV
Does not power up. led goes to green then goes back to red and blinks 7 times
  • 2,318 Answers
Check the link below to find info on how to DIY:
http://www.fixya.com/support/t5048641-easy_replace_capacitors
Posted on Sep 01, 2010
We have a 2007 Sony Bravia 46" KDL-46VL130. There is not sound or picture. When we power it on the green light comes on blinking once and then the red light blinking once and then the green light stays on....
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
Oct 09, 2013 | Sony Bravia KDL-46VL130 TV
My KDF-55WF655 power led blinking red six times.
It looks like your power module is on the blink. Do you get any picture?
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
I just replaced the projection lamp and i cannot see an image. green power light goes on for a few seconds then goes back and clicks back to red
HOW MANY TIMES IS THE RED LED BLINKING? IF IT IS BLINKING 3 TIMES MAKE SURE THAT THE LAMP DOOR YOU TOOK OFF TO CHANGE THE LAMP IS INSTALLED BACK ONTO THE TV AND IS SECURE.
Dec 17, 2010 | Sony KDF-50E2000 50" HDTV
FLASHING POWER RED BUTTON 7 TIMES
I believe that is a bad power supply board. You can unplug set ,open the back access panel and look for swollen electrolytic capacitors they will most likely be slightly rounded on top instead of flat top like the others.Not sure if just replacing caps is enough we mainly swap out whole board.Some models' replacement power supply is slightly different from original in that a couple of the plugs are in different spots and require an extension cable.
the tv dude
Apr 01, 2009 | Sony KDS-R50XBR1 50" HDTV
Help w/ the flashing green light
Good Day;
Cause #1 1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big IRISH.
Oct 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Power Up Problems
7 blink error is 8.6 volt error on that model. usually tied to y sustain board located on left side of set looking from back. disconnect y main from power supply and power on and if comes on verify power supply primary voltages located on label on pdp itself. if voltages present you would need to replace that board as not designed for component level repair. however if you find failed components like swollen caps or burnt ic's you could replace those. also when replacing the y main board there are two y buffer boards to left of main board that also would be recommended to be replaced at same time as they work as circuit and replacing one board without other could cause failure to other boards still in set
Aug 13, 2008 | Philips 42PF9431D/37 TV
Power Up Problem
You have a 8.6v supply error according to the 7 error code being displayed, what you can try is when the set goes to blinking disconnect the Y sustain board (if looking at the tv from the back the board on the left) from the upper left side of the power supply, if the error code stops then you know your Y sustain board is pulling down your power supply and causing the error, if the error code continues you have a probelm with your Logic Board (located under your Small Signal Board) disconnect this from the Y sustain board and see if the error code stops if it does you know that the Logic board is bad, if the error code is still blinking then the 8.6v supply line from the Power supply is faulty and the Power Supply needs to be replaced
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Philips 42PF7320A 42 in. Plasma HDTV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
