Question about Neff U1461 Double circotherm plus Electric Oven
Smell has started in our 8 month old Neff oven. No obvious reason for it - pretty clean and no unusual food cooked. Any ideas ?
  • Neff Expert
  • 414 Answers
There may be a problem with the cooling or extraction fan on the oven. All Neff appliances come with a two year manufacturers warranty, so I would advise you call them out on 0844 892 8999. If you attempt a repair yourself, you could invalidate the warranty.
All the best.
Posted on Sep 02, 2010
Hi got a NEFF B1691 oven. Thing is the oven light, element and fan keep switching off during cooking is this correct functionality - if not what could be wrong? The temperature display remains functioning...
There does seem to be a fault, as the fan should run continuously even when the element goes off at the required temperature setting, and the light should atay on as well.
It suggests to me that there is a fault with the oven thermostat, or it is wired incorrectly.
Dec 21, 2010 | Neff B1691 Single circotherm super...
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
Neff U1721 repeatedly trips RCD. Have replaced lower element 4 times in last 18 months am I likely to have an underlying earth fault, or are "cheap" elements more prone to failure
Sounds more like the power supplying the oven is at fault. Need to make sure that all power is correct from stove to box. Very unusual for that many elements to be going bad.
Feb 04, 2010 | Neff U1721 Double circotherm Electric Oven
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
NEFF OVEN PROBLEM - SMOKE AND FUMES COMING OUT OF OVEN
Take the cover off that is surrounding the fan and you will probably find food or something there or on the fan blades. If it is not a food smell, then there is probably some wiring that is burning. I suspect that there is food behind the housing of the fan.
Feb 02, 2009 | Ovens
Setting the oven to come on at a certain time
I have a neff u1722 but I think the settings are pretty much the same. To set a coming on time first press the button with side by side triangles on it until the symbol l->l flashes then rotate the plain button next to it to the length of time you want the food to cook for. After about 4 secs the normal time will come back on. Then press the side by side triangle button again until the symbol ->l flashes then with the plain button rotate again to set the time you want the food to be cooked for. Hope this works
Jan 16, 2009 | Neff U1421 Double circotherm Electric Oven
Neff oven U1661 shows fault code -5-
We have a similar Neff Oven - it is a child proof lock that you have activated. To deactivate - turn the left hand dial that selects the mode of cooking - three times to the left and back (turn it from 12 oclock to 11 oclock and back) in quick succession.
Sep 17, 2008 | Neff U1661 Double circotherm super...
Main oven tripping the fuse
probable fault to earth of circular element - gets worse when element hot. you will need a megga to confirm this.
May 22, 2008 | Neff U1721 Double circotherm Electric Oven
Neff U1461 Double circotherm plus Electric Oven Logo
146 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
