Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I keep getting a f1 signal on my cabrio washer...what does this mean?
  • 15,935 Answers
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 20, 2010
SearsTechToo
  • 261 Answers
SOURCE: Whirlpool cabrio washer keeps stopping
F1 means you need to replace the mcu which is about 100 dollars or more. Use part w10201186 and have the model and serial number in case there is a replacement, make sure it is revision B or later on any alternative boards.
Posted on Oct 05, 2008
SOURCE: I have a cabrio whirlpool washer and a F1 code
i just called on mine for the f1 code and they said its a defect and would fix it call 18002531301
Posted on Oct 04, 2009
  • 2510 Answers
SOURCE: F1 code whirlpool
whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
Posted on Dec 13, 2009
rylee_smith
  • 8619 Answers
SOURCE: Whirlpool Cabrio Washer : What is the F1 error
Hi
Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: display shows F1 top load cabrio whirlpool washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#*
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 signal what is the meaning
Pressure Signal Out-of-Range
F then 1 flashes when the control detects an out of range pressure signal.
* Check pressure hose connection from tub to machine/motor control. Is hose pinched or kinked?
* If F then 1 repeats numerous times after POWER is pressed and the pressure hose connection is not pinched or kinked, replace the machine/motor control.
Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2 Call Whirlpool or a repair center. The number for Whiripool is 1-800-253-1301
Hope helps.
Jul 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Keeps giving me the F1 signal. Whats the deal?
Fellow, Academy of Sublime Masters of Appliantology
Joined: Sun Oct 7th, 2007 Location: South Carolina USA Posts: 6784 Flavorite Brew: waffle house coffee Status: Offlinespacer.gif F1 usually means a communication or an electrical error.
Unpgug the machine for 1 minute and then power back up. If fault reoccurrs check all connectors.
How long have you had this machine? Has it always been plugged into the same outlet? Is is sharing an outlets with another device?
Read more: Whirlpool Cabrio F1 code - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/15527.html#ixzz1BPYo9agm
Get appliance parts at http://parts.fixitnow.com
Jan 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
F1(F68)-Pressure Signal Out-of-Range
I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does code f1 mean
Hello
Error code F1 means that the control of washer has either gone bad or about to go bad. This is a common issue with Whirlpool Cabrio washers. I have also seen them replacing the control without any charge, don't really know about the labor charges but they usually won't charge for the part. Please get back to me if you have any other questions.
Kevin
Nov 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I get an F1 signal when I start the washer. I can get it to go away by switching what kind of load it is but it keeps coming back?
F1 means communication error, Unplug washer for 2 mins.. What might have caused this problem is a power glitch of some kind.
Jan 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 code whirlpool
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a cabrio whirlpool washer and a F1 code keep's on coming up what doe's it mean
Oct 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
