Question about Watches
I have a black athletic works watch that says ''WR 100ft''; model number AW60724W. I lost the instructions somewhere accidentally. I wanted to stop the hourly chimes it gives off, and have no clue about it. Appreciate any help to turn this feature off.
SOURCE: set the alarm
To turn the alarm off press and hold st/stop and then press lap/reset. To set, press the lower left hand corner button, you will see the option to set the alarm first and then the option to set the actual watch time.
Posted on Dec 30, 2009
  • 7 Answers
SOURCE: athletic works watch that is stuck on military time
With my old watch (from Walmart), all i had to do was go into the time settings and cycle through the hours until it went past the military time's midnight and it would start going through "normal" AM/PM times.
I hope this is enough information.
Posted on Feb 15, 2010
SOURCE: Instruction book for Athletic Works AW60724W?
Found watch directions, Thank you for your time.
Posted on Jun 17, 2009
gemineye61
  • 831 Answers
SOURCE: How do I get my
  1. Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  2. Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  3. Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  4. Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  5. Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
Posted on Aug 31, 2010
How do u change a wr 100ft watch?
Hi I bought this watch WR 100FT for my son and the alarm
keeps going off does anyone know how to make it stop going off ?
I have tried everything.
Mar 07, 2012 | Watches
How to set wr 100ft wrist watch
Thanks answer 1 it really helps
Dec 18, 2010 | Watches
I have a Timex I bought in 2007 on the back of the watch it says CR 2016 cell and WR 100m. The time started to catch on a certain time and stopped the date from working properly, I need to know how to...
You should probably replace the battery using a new CR2016 battery. Let the watch set a while without the battery to help it reset. WR 100m just means the watch is "Water Resistant to 100 Meters". Then use the following info.
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Sep 01, 2010 | Watches
Athletic works watch that is stuck on military time
Feb 15, 2010 | Watches
Set the alarm
Apr 10, 2009 | Watches
Athletic Works Watch
With time displayed:
Press lower right, then upper left.
Mar 12, 2009 | Oakley GMT OAK0531 Wrist Watch
I cant set the correct day on my digital watch ,The watch has CG onit and is WR 100FT
press mode 3 times to get to time set. then press reset to choose (hour, minute, seconds, day, month, date) and press start to change them. press mode again when finished.
Oct 16, 2008 | Freestyle Digital 79801 Watch
I just bought an Athletic Works watch at WalMart that is identical to the Aquatech watch I bought there some years ago. My band got hard and cracked so I needed to buy a new one as the band is not available. For $9 the entire watch is probably cheaper than a band. I used the instructions from my Aquatech to set the stuff on the AW. I found the instructions on the internet. Here is one site that has them.
http://www.ehow.com/how_4587869_set-aquatech-watch.html
Give it a try.
Clem S
Sep 23, 2008 | Watches
Watches Logo
1,394 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
