My toshiba data projector has somehow had the words and menus turned upside-down and backwards. I do not know what I pushed or selected to do this, but I have no idea how to get it back, please help me.
Greetings,
This is actually a feature. Most projectors, when mounted on a ceiling are turned upside down. You want to go into the menu and look for view. Then look for Vertical flip and Horizantal flip and make sure that they both say off. Let me know if you have any more questions.
-Take Care,
-WN
Posted on May 10, 2008
Words are spelt backwards
Your projector has been set up for rear projection mode (projecting the image from behind a translucent screen. You need to access the setup menus and reorientate it for front projection. Using a mirror to view the image whilst navigating through the menus may help :o)
Mar 27, 2014 | NEC VT465 Multimedia Projector
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
My dell 4610x projector is mounted on the ceiling; it is showing the image upside down. I went to setup>projector mode and it only has two icons not 4. and no matter which one i choose, it just flips...
There is usually a section for the orientation of the projector, maybe the ceiling/table mounted section is in a differnent place in the settings menu than the front/rear facing section.
Good luck
Aug 02, 2011 | Dell 4610X Wireless Plus Mainstream...
The images are upside down how do i change, i read somewhere that change the front ceiling on the menu how do i do that?
Your projector is in "ceiling mount" mode. I don't know all of the menus for your specific model, but if you navigate through the menus you will likely see an option for ceiling or table mount. This may be a picture rather than words. Also in the same menu list should be front or rear projection. A change to this will flip the picture to the correct orientation.
Dan
Apr 11, 2011 | Epson PowerLite 62c Multimedia Projector
My projector is projecting upside down and backwards
That is because it is set up for rear projection.
Enter the menu and select which ever view you require.
Mar 29, 2011 | Optoma EP721 Projector
My bulb was replaced. We reset the bulb hours and somehow flipped the screen upside down. The projector is mounted upside down. What do I do? In trying to fix it, the remote quit working. I may have...
I guess you used factory reset, then picture flips back to table/ front mode.
In setting menu choose for ceiling ( R upside down icon) and set this to ON.
Jan 08, 2011 | Eiki LC XNB4 LCD Projector
When we turned it on the picture was upside down. what do we do?
somehow you managed to change the orientation of the projected image. You do not mention if your projector is ceiling mounted or front. If select menu item + front or menu item + ceiling front. one of those two should help you
Jun 13, 2010 | SharpVision® XV-Z3100 DLP Projector
I mounted my In Focus Projector upside down because of the ceiling mount I bought for it. Now the picture is upside down. How do I fix this?
Go to the Setup menu and select Orientation. In here, you will want Ceiling Front or Ceiling Rear depending on how you are using the projector.
Some projectors won't let you into the menus unless there is a computer connected. I'm not sure if this is one, but keep it in mind if you have trouble.
Sep 28, 2009 | NEC VT465 Multimedia Projector
Icon medialab projector -upside down picture
I can not find the manual for this projector, but on most projectors in the menu you select the position of the projector. You will need to select front/ceiling. If there is not a installation tab on your menu, look under setup. Hope this helps.
Mar 12, 2009 | Office Equipment & Supplies
Data Projector projecting upside down
If you go onto your menu and click on "setup". Press orientation and select the right one for your projector. It allows you to choose whether your projector is on a table top or ceiling mounted etc.
Feb 10, 2009 | NEC VT47 Multimedia Projector
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
