Question about LG Washing Machines
Stops and saids ( LE ) - LG Washing Machines
  • LG Master
  • 43,501 Answers
Here is a tip that will give you some ideas about why you are getting that LE code....
LG Washing Machine LE Error Code or Fault Code
heatman101
Posted on Sep 01, 2010
Samsung microwave CP1395 malfunction E-32 in manual. If I use oven function or a combo like microwave & grill it stops midway and will not work again!
Bonjour
nous avions une erreur 32 sur notre four
ce n'etait pas l'element damper ci-dessus (test? manuellement)
nous avons trouv? la cause un peu par hasard : en appuyant tres tres fort sur le plateau interieur l'erreur 32 disparaissait et le four refonctionnait qqles secondes
donc :
debrancher le four
demontage de la tole de dessous le four
demontage de la piece qui detecte la presence (ou qui mesure - tres mal - le poids) : 3 vis
Sans lui debrancher ses fils electriques
avec un petit boulon par exemple et un serre joint : ecraser doucement le centre du capteur
poser le capteur er le serre joint derriere le four et remonter le four
rebrancher
ca marche
sans l'option mesure de poids mais comme c'est une fonction qui ?est pas au point c'est pas grave
stephane
bretagne
contact@armorstudio.fr
Apr 24, 2013 | Microwave Ovens
LE error cam e on and I've drained the water, cleaned the filter, etc. I also unplugged it to reset it. It fills the water and starts to spin, but it suddenly stops and gives me the LE error once again...
If your washer is an LG (unfortunately you have not said) on most 'LE' stands for 'Lock Error'. If so there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor becoming apparent with the extra movement of spinning, requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 29, 2011 | Washing Machines
What does code LE mean? The washer stops and LE appears
Code LE signals an overload to the motor. Wait 30 minutes and restart the cycle. If the code is not released, you need to call a service technician.
Jan 07, 2011 | LG WM2487H Front Load Washer
Code "LE"
Here is a tip that will help you understand the LE code...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 21, 2010 | LG WM0642H Front Load
LE on display
I just had my LG dishwasher fixed. I told the repair man that LE light was comming on. Even over the phone the repairman said its probably broken wires on the door. Me being in construction for years looked around the door for wires. Anyway the repairman took off 6 screws around the door, took the cover off. You will see about 50 wires taped together. He pulled them aside and visually checked them one by one. Sure enough two were broken in two. He twisted them together put tape and he was gone. $87.50 Still Working!
Mar 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
Stops and flash le code
Le is a locked motor error.  Sometimes glass, or food gets stuck in the bottom of the sump jamming the motor.  Take it apart from the top to check for clogs.  When you get to the impeller the screw might be reverse thread.  If there is nothing stopping the motor, you will need to replace the motor.
Dec 19, 2009 | Washing Machines
LE sighn on NEC washing machine
Generally LE is as you said a load error. This can refer to an unbalanced load in the machine. You should try to redistribute the clothes to even the loadThe addition of a P.I error code indicates it is having problems loading the programmed wash instructions.
The fuzzy logic is a form of artificial intelligence that controls the preprogammed operations of the machine and warns of wring usage.
If redistribution of the load does not work unplug the machine from power and leave for a few hours. Then replug and turn on.load with a few items only and set the unit to wash ...
Aug 11, 2009 | Washing Machines
Lg front loading washer displays le
the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Apr 07, 2009 | LG WM1814CW Front Load Washer
LG WM0642HW washer gives error during spin cycle and stops.
I have this problem and you can find the solution on this same web page by searching. It is likely the Hall Sensor that needs to be replaced (see proflevy posting on Jul 16, 2008). According to the postings, it is from soap build up on the sensor and replacing it costs $18 for the part and is easy (many responses on this). I am waiting for the part and will try to fix mine soon.
Mar 06, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
141 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
