Question about Sony CDX-GT510 CD Player
Sony CDX-GT510 now flashes "offset" and gets no sound. Tried hitting reset and changing remote battery but nothing has worked. Any suggestions??? Thanks!
SOURCE: Sony CDX-MP40 only works after hitting reset button
If you dosn't find a solution, then I'am very interested in buying the faceplate for this unit. batman@galnet.dk
Posted on May 25, 2008
  • 55 Answers
SOURCE: sony cdx-m630
I have a few suggestions that may help. Have you checked the fuses?There is on on the stereo and one in the car's fuse box. Are all of theconnections from the wiring harness secure? Make sure these are tightand show no signs of damage, especially the ground connection. Also, ifthe face is detachable, check the connectors (on the face and thestereo) for damage or dirt or anything that would prevent a goodconnection. Pushing the reset button should not have prevented you fromoperation of the unit, so it has to be either an external fault (likewhat I described above) or an internal problem. How old is the CDplayer? If it is still under warranty, I would call Sony or go to theirwebsite and speak to one of their techs. You can go to the site byclicking on the blue link: Sony Support Hope this helps... Please take time to rate how helpful this was. Thanks and good luck!
Posted on Sep 10, 2008
smarthome2
  • 1114 Answers
SOURCE: Sony cdx m610 resets itself at half volume
You have a shorted speaker or speaker wire. If a wire is touching metal lightly it may not have full continuity (short) and will work until more voltage (volume) is sent to the speaker and causes the short. Disconnect all speakers at the radio then turn the unit back on. Turn up the volume and see if it cuts out. If it stays on, re-connect speakers one at a time and test. Once you find the problem speaker, disconnect the wire at the speaker then test again. This will eliminate the speaker itself as the problem. Test again. If it still shorts, trace the wire from dash to speaker and look for a cut in the sheathing exposing the wire. Repair or replace the wire and you should be good to go. If the unit cuts out with all speakers disconnected, the problem is internal and will need to be serviced. Before you repair/ or replace the unit either check all the wiring and the speakers or have someone do it for you so it does not give you a repeat performance. Hope this helps.
Posted on Oct 01, 2009
SOURCE: how do you change the time on a sony cdx-gt510
Push & hold down the volume knob until "clock adj" appears on the face (a couple of seconds). Then turn the volume knob, left or right, to adjust the time up or down
Posted on Dec 01, 2009
SOURCE: wiring diagram sony cdx-gt510
Wire colors
Posted on Feb 20, 2011
Sony cdx-gt610ui buttons won't work
Guys,
I have a CDX GT610, the issue is that is not possible to change stations, even if I try with the push buttons to record the stations, it remains on the same station (number 3 in my case), besides the volume gets high if I want increase the volume, any suggestion about it??? please let me know
Best Regards,
Marco Hernandez
Feb 26, 2013 | Sony CDX-M630 CD Player
How do i change the color from red to green?
This is a link to Sony for your CDXGT510 Owners Manual. Reference page 10 for changing the display illumination color.
http://www.docs.sony.com/release/CDXGT510.pdf
Mar 10, 2010 | Sony CDX-GT510 CD Player
How do you change the time on a sony cdx-gt510 stereo
Nov 28, 2009 | Sony CDX-GT510 CD Player
Can not figure out how to turn off ATT
On the front panel is the power button , which if held pressed for a min or so, switches it off.....................sodeep
Sep 04, 2009 | Sony CDX-GT510 CD Player
I need a wiring diagram for this stereo
Click Sony Support to download installation manual of CDX-GT510 CD Player.
Jun 03, 2009 | Sony CDX-GT510 CD Player
Mar 09, 2008 | Sony CDX-MP40 CD Player
Sony model #CDX-M630 car stereo reciever
you need to use the original remote to enter the code. Try these codes one of them should work...
You need to press reset after each attempt.
CODE 1: MODE SOUND OPEN ATT
CODE 2: ENTER OPEN MENU 6
CODE 3: OPEN DISC+ 1 LIST
CODE 4: SEEK- SEEK+ 3 OPEN
CODE 5: OFF 4 OPEN SOURCE
CODE 6: 2 OPEN DSPL SOUND
CODE 7: OPEN 5 ATT SEEK+
CODE 8: DISC- DSPL OFF OPEN
CODE 9: SEEK+ SOUND OPEN ENTER
CODE 10: DISC- LIST SEEK- OPEN
CODE 11: OPEN 4 LIST OFF
CODE 12: DSPL SOURCE OPEN 1
CODE 13: MENU 2 MODE OPEN
CODE 14: 5 DISC+ OPEN ATT
CODE 15: 3 MENU SEEK- OPEN
Sep 13, 2007 | Sony CDX-M630 CD Player
Sony CDX-GT510 CD Player Logo
135 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
