Question about Samsung WF337AA Front Load Washer
We just purchased our Samsung front load washer and dryer and I tried it out for the first time last night and the washer never pulled the softener and the clothes were sopping wet when I was done. Any suggestions?
    President:
  • 3,773 Answers
Sounds like a kinked hose at the between drain and machine.
Don't move the machine before you look or you will straighten the kink and never know it.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 01, 2010
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
Samsung wf317aag stopped mid cycle now machine has no power
First, are you sure there is power to the unit? Check the breakers and post back.
Nov 03, 2012 | Samsung WF317AAG Front Load Washer / Dryer
When i came to the kitchen this morning my maytag neptune dryer was leaking some water from the front.i dryed it up thinking it was from the storm last night, and i,m running another load.it,s still...
i am assuming it is a front load washer, on the inside of the front gasket,in the middle, there is a drain hole. It is clogged, you will need to unclog it. It happened to us a few months back when a pillow exploded in the washer, I ended up pulling the front panel off and with pipe cleaner getting all the debris out. Good Luck Tim
Apr 17, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
Front of washer shows something inside the plastic on outside
It may just be spilled soap/softener the escapes from the tray when you load the dispenser. Happens here regularly. We just wipe it down from time to time.
Hope this helped. --W/D--
Jul 26, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Water spraying out of front panel
Hello, you should be able to remove the panel off the top and access the inside of the machine..from there you will see a rubber hose that goes from the detergent tray to the tub..remove this and clear the blockage to the tub, had same problem last week and found a sock blocking the entrance to the tub. Hope this helps..Good Luck!!!
Jul 13, 2009 | Samsung WF203ANW Front Load Washer
Bendix Washer/Dryer - softener dispenser not working
the softer dispenser is blocked, remove drawer wash it out with hot water ,clean out small hole in softer compartment close IRE bye
Aug 16, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Samsung WF337AA Front Load Washer Logo
109 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
