Question about Panasonic TH-37PE30 37 in. Plasma Television
When i insert an sd card it says 'no valid pictures' but the card is fine and contains pictures in jpeg format. I have erased, re-formatted the sd card and reloaded the pictures, but no change.
  • Rommel Cana
    Rommel Cana Sep 01, 2010
    what format does the SD card have? don't use NTFS format
  • 903 Answers
SOURCE: Format the SD Memory Card
Formatting erases all the data recorded on the SD Memory Card. If an SD Memory Card becomes unreadable, formatting may make it reusable.
Posted on Aug 31, 2005
  • 473 Answers
SOURCE: Formatting memory card.
Posted on Sep 06, 2005
SOURCE: SD card
I have the same camera, save the colour (black). As soon as I read your post, an alarm went off. I decided to re-check my User Guide (PDF Eng version, page16), for the Lumix DMC-FZ30:
•On this unit, you can use SD Memory Cards of the following capacity (from 8 MB to 2 GB). Please confirm the latest information on the following website:
http://panasonic.co.jp/pavc/global/cs
(This Site is English only.) • This unit supports SD Memory Cards formatted in FAT12 system and FAT16 system based on SD Memory Card Specifications. • This unit does not support MultiMediaCard for recording motion pictures. • The reading/writing speed of a MultiMediaCard is slower than an SD Memory Card. When a MultiMediaCard is used, the performance of certain features may be slightly slower than advertised. • After recording motion pictures using the MultiMediaCard, the card access indication may appear for a while, but this is not a malfunction. • Keep the Memory Card out of reach of children to prevent swallowing.
8MB, 16MB, 32MB, 64MB, 128MB, 256MB, 512MB, 1GB, 2GB (Maximum)
Posted on Oct 26, 2008
tuki190246nz
  • 5 Answers
SOURCE: sd card not recognized in my sd video camera
Have had this happen to myself, in my case the card was faulty. After getting a new card it went fine.
Posted on Jun 12, 2009
SOURCE: SD card - memeory card parameter error
The manual for the camera states that the memory card must be formatted in the camera and that cards formatted in a computer may not work properly. Use the format command in the camera.
Posted on Jul 05, 2009
When i turn my camera on it says i need to format the SD card so i hit okay then it deletes all my pictures and says unable to format
The contacts on the card are dirty. Insert and remove the card several times and try it again. You can recover pictures off an erased card. Google SD card file recovery software.
Apr 17, 2016 | HP Photosmart 735 Digital Camera
We have inserted sd-ms card onto our laptop to upload the photos onto FB.however the card when inserted back onto the camera, about 50 over images show, incompatible jpeg?how do we solve this issue?
The computer uses a small program to be able to upload pictures from the memory card once the pictures are safely on the computer hard drive hopefully you created a file folder for them then the memory card needs to be formatted in the camera. Formatting the memory card cleans the card and makes it compatible to the camera again. Every time you download images to the computer the memory needs formatting in the camera. Any new memory card needs formatting in the camera a card that has been formatted in the computer needs to be reformatted in the camera. Also please be aware that there is a protection lock on the side of the SD card and if placed in the incorrect orientation will actually lock the card from formatting or deleting files on the card. I'm going to include a diagram here to show you where this little switch need to be for the "unlock" position.
Switch needs to be towards the top of the card in the direction of the gold contacts
Jan 02, 2011 | Cameras
Picture is not storing in inbuilt memory or in the SD card.
1. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. 2. If your memory card contains pictures you want to save, download them to your computer...use a card reader if necessary. 3. Insert the card into the camera and do the "format" thing again.
Aug 24, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
I accidentally formatted my sd card and lost pictures also the ones that were locked how can i recover all of them
dont worry, pictures lost after reformatted sd card can be recovered with sd card photo recovery software, you can download the picture recovery software from
http://www.asoftech.com/apr/
May 10, 2010 | Kingston 2GB Secure Digital Memory Card
My Camrea tells me that the card is protected
Before inserting your SD memory card, slide the write-switch to unlock position. Insert the SD card, go to ‘setup menu’, then ‘format’ , format the SD card. All pictures will be erased. Refer your manual on page 87.
Apr 06, 2009 | Fuji Finepix Z20fd Digital Camera
SD Card in Nikon F10 not recognised by XP
It could be one of two problems. The most likely is that the card reader you are using cannot read SDHC cards, of which all 4GB and larger cards are. Try using the camera's cable to download to your computer directly to the USB port. I bet you'll find that it works that way. The other problem could be (but not likely) that you are shooting on the RAW file format, instead of the jpeg file format. Most software cannot recognize RAW files, but jpeg is pretty universal.
Mar 19, 2009 | Nikon Coolpix 8800 Digital Camera
SD card keeps popping up when inserted in cama. SD card will not stay down in camara Says it needs to be formatted. It will not format. Never has this problem before How can I fix this
The SD slot of the camera got damage somehow. The SD slot contains thin copper prongs that locks the card in place and comes in contact with the surface of the card. If these prongs are damaged, then it cause a read failure of the camera.
Sep 29, 2008 | HP Photosmart M525 Digital Camera
Some Pictures won't display
When this happened to me. I erased the pix from my sd card and copied it again to my sd card in the pix folder. Then it worked. Also make sure the picture is in the correct format. ie. jpeg vs. bitmap.
Sep 10, 2008 | LG enV VX9900 Cellular Phone
Decode error! JPEG datastream contains no image.
Kodak has software that should be able to make sure those pictures are in JPEG format. Id use that at first instead of a third party program. Picture It! does some funny things to pictures and Microsoft discontinued that product line several years ago.
Here is a link to download it
There is a firmware upgrade too on this page. You should install that into your camera as well.
Jul 13, 2008 | Kodak EasyShare Z1275 Digital Camera
Wont accept xd picture card
Hi, tecnil
Device cannot detect files on the memory card.
Cause
The memory card might be missing or inserted incorrectly. Verify that the memory card is inserted correctly.
The files might not be in the correct format. To print from the device control panel, the files must be in the sRGB JPEG format. To print other formats, you must use a software program on your computer.
You might have inserted more than one memory card. Only one card slot can be occupied for the device to detect JPEG files. Verify that only one card is inserted.
oke,
thx
cropp
Jan 08, 2008 | HP Photosmart 7450 InkJet Printer
Panasonic TH-37PE30 37 in. Plasma Television Logo
171 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
