Question about Bulova Men's Accutron Tahoe Watch
What is the value of a accutron swiss p2; quartz 82006; serial # 10632578.
4 Suggested Answers
SOURCE: Opening Bulova Casement
Take it to a local jewelery store and they will do it for about $15. Joe
Posted on Oct 03, 2007
slp11508
  • 43 Answers
SOURCE: can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Posted on Jan 05, 2009
  • 183 Answers
SOURCE: Fake or not
Generally you have to open the watch to see the movement but a lot of fakes are plain workmanship flaws.
A real Cartier will not be made from base metal. It will be made from stainless steel or precious metal.
A real Cartier will most likely be built with screws in the band instead of cotter pins.
When you pull the crown to set there will be no play in the set lever. In other words when you spin it, it will begin to turn the hand immediately and there will be a slight resistance. It will not feel loose.
As stated, the best way to tell is to look at the movement. Cartier uses a high grade Swiss movement most likely marked ETA.
Posted on Sep 17, 2009
Value/ year made
The year made cannot be determined from the SN. Since the '50s Bulova used a 2 character date code, usually below the SN. The letter is the decade, the number is the year. For example, M4 is 1964, N6 is 1976, O5 is 1985, etc. As to value, if it is from 1960 through 1976 (M0 thru N6) it is a "true" Accutron, with a tuning fork movement, is collecrible and valuable, and the actual value depends on which specific movement and which case. Some 1977 (N7) Accutrons are akso collectible rtuning fork watches, but some 1977s are Bulova's first quartz watches, and of no value. Bulova eventually went mostly automatic (self-winding mechanical movement) with their Accutron line. Those are well-made, mid to upper-mid level watches, and of no particular value beyond that of most any good used automatic. Note, however, that there have been numerous versions of the automatic Accutrons, some fancier and nmore expensive than others, and, s ith any good watch, original cost will have an effect on value as a used watch. For example, that retailed at, say, $500 new in 2009 will be worth more today than one that was $250 new in 2009 (assuming comparable condition). There are also now some Accutron IIs, which mimic, in looks and the sweep second hand, the original tuning fork Accutrons. However, while they are well-made watches, they are just another nice quartz watch.
Jun 02, 2014 | Accutron Swiss Watch by Bulova 26B44
Any idea what a Bulova watch, 14K white gold, number on back case 962158. Any idea what it is worth?
I'd need more info. First, is it a "real" Accutron, made from '60 to '77, or is it one of the things Bulova kept calling Accutrons after they stopped making the tuning fork movement watches? The quartz so-called Accutrons are just a nice old watch, not worth anything special. The self-wind "Accutrons", which Bulova is making now, are just a nice, mid-range aurtomatic watch. On the back of Bulova watches is a date code, usually right under the serial number (SNs themselves really mean nothing where Accutrons are concerned). The code is a letter and a number. If it begins with the letter M, or if it begins with the letter N and is followed with a 0, 1. 2. 3. 4. 5. or 6, it is a "real" Accutron, and is collectible. Some with N7 (1977) are also, but it depends on the actual watch. Bulova did make some quartz so-called Accutrons in '77. If it's a '60 thru '76, and SOME '77s, it has value beyond the scrap gold price. SOME Accutrons are even worth thousands of dollars. White gold Accutrons, compared o yellow gold or stainless, are rarer. Next, WHICH Accutron is it? is it a 214, a 218, a 219, a 220, a 224, or a 230? If it's a man's watch, it is very unlikely to be a 220 or 230 series, If it does not have a winding stem on the side, it is a 214. 214s are the most valuable. If it has a setting stem at 3 o'clock or 4 o'clock, it is either a 218 or 219 (I'd have to open the back and look at the movement to say which ine). If it says "Accuquartz" on the face, it's a 224 (NOT a quartz - the 224 Accuquartz is a hybrid of tuning fork and quartz crystal). Once we know the movement series, we need the case type. Certain cases are much more valuable than others. Then there are the Spaceview, the Astronaut, and the Deep Sea, 3 specific models they made, which are more valuable than most (but not all) of the other cases. The best I can say right now is that, being white gold, there's a good chance it's one of the more desireable specific models. If it's a 214, ESPECIALLY if it's a 1960 (M0), it's worth quite a bit more than just the gold content. To be more specific, I'd have to see a picture of the watch, which I don't think can be posted here. Try looking up "Accutron" on Ebay and see if you can find one that, if yours has a stem, has it in the same place as yours, with the exact same case - same shape, and exact same lugs (the things on either end where the band or strap is attached). Read the description. The description will probably say the movement (214, 218, etc - in fact, the movement may even be in the listing title) and if it is niot just a plain round case, probbly will say the case type (Alpha, Asymmetric, Butterfly, etc.). If it's an Astronaut, a Spaceview, or a Deep Sea, it will certainly say that. Also, look at the Accutron section of the Bulova entry in Wikipedia. (Yeah, I wrote it, but it has info that just might help you pin down exactly what you have) When you find out more about which Accutron it is, post another question under Axcutron watches here. I'll check every couple of days for the next week or so, and if I see your post, I'll narrow down the value some more.
Sep 17, 2013 | Accutron Swiss Watch by Bulova 26B44
BULOVA ACCUTRONE E66831 M8 14KT WIND STEM AT 4 OCLOCK NEED TO KNOW IF IT IS WORTH MORE THAN THE GOLD CASE THANKS
The M8 indicates this watch was produced in 1968 and probably sold for 250-350,this is a tuning fork watch and they are highly collectible and worth up to twice the value of the gold or more depending on the model and condition
Nov 20, 2011 | Accutron Swiss Watch by Bulova 26B44
How do I tell what model Accutron I own? I obtained it as a graduation present in 1972. The serial number is H233723.
The only people who are likely to be able to answer your question is accutron (assuming that they keep records that far back- which they might).
Go to http://www.bulova.com/brands/accutron/accutron.aspx?brand=accutron and scroll down to the bottom of the screen and click on "contact us"
Oct 31, 2010 | Accutron Extra Value 26R05 Watch
What is the worth of a bulova accutron 14kt gold mother of pearl face serial #59252 worth
mcdevito75 here, Bulova Accutron, nice watch, of course there are many, many factors that go into the value of any watch, depending on Maker, Model, Condition of the watch also. I would figure your Bulova Accutron is in the area of $125.00------- $200.00 range. Your best bet is to find a jeweler in your area or an appraiser, even online for the latest value of your watch.
Aug 15, 2010 | Bulova Wrist Accutron Lucerne White M. Of...
I have a bulova 18K gold men's wrist watch, which says 3063-5020 AO in a square on the back. Swiss A6 18K. And it is a battery watch, and is still running any idea? of year or price it is very heavy on the...
mcdevito75 here, The movement number tells all, but I would figure the yaer somewhere in the 80"s and value at $250----$350.-- Accutron very collectable watch. Look for a small watch repair shop in your area for more accurate info. Hope this hepls.
Aug 02, 2010 | Accutron Swiss Watch by Bulova 26B44
How do I find my serial number on my bulova watch
Serial numbers are generally on the back of the watch.
You may be able to find two or three numbers on the watch.
A case number, a movement number and a serial number.Alternatively you might find a style number (which in your case is 26B44) and a serial number.
Mar 05, 2010 | Accutron Swiss Watch by Bulova 26B44
Watch.....
Rolex is very fine watch if you maintain it properly. Is it more accurate for keeping time than a quartz watch? No, even specs tell you that. Hope that helps you.
May 30, 2009 | Rolex Daytona 116520 Wrist Watch
Bulova Men's Accutron Tahoe Watch Logo
435 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
