Question about Maytag Dryers
Dryer is binding wont turn when start the belt is working
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
This tip will also help you with that..
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 12, 2010
Drum does not spin. Belt appears to be ok
You have a bad tensioner or a bad motor. The tensioner for the belt can drag the motor. However, what you are describing sounds like the motor is shot. But make sure you are getting correct voltage to dryer and nothing is binding the motor.
Mar 03, 2015 | Maytag Dryers
My Maytag Performa Dryer model PYG3360AWW wont turn on it just buzzes when I push the start button. what do I do to fix it?
See if you can turn the drum by hand, there should be some resistance. If its locked you will need to disassembly the dryer and see what is binding. If everything(motor,rollers,pullys)spins freely they you most likely have a faulty motor winding and will need to replace it.
Dec 21, 2014 | Maytag Dryers
Belt le7680xsn2 whirlpool
Only thing that fixes itself after cooling is the main motor. Either motor is failing, or something is binding preventing tub from turning, or making tub hard to turn. Can have hair binding support rollers. Will need to turn tub by hand , counter clockwise to determine if it's hard to turn, if so remove tub and inspect rollers, if they don't turn freely replace rollers.
Aug 12, 2014 | Whirlpool Dryers
Just fitted a new belt to my dryer now it wont turn have checked for any loose wires
Are you sure you have the belt on correctly? When you start it does the motor run or try to run? Does it hum or buzz when trying to start? Take the belt off & start it see if the motor runs if it does check if drum, belt and idler pully are installed correctly.
Check the drum rollers and drum glides be sure the drum turns ok. Be sure everything is installed correctly & turns OK . Are you getting power? Hard to tell what is wrong without much information about what is going on. You might check the front panel & see if it is binding on the drum not letting it turn. Hope there's something here that will help you.
Jun 02, 2014 | Frigidaire Electric Dryer
Frigidaire Gallery Electric Dryer, model GLEQ2170KS.
Can you tell if the dryer is moving air? Is it getting Hot?
if yes, then it sounds like a belt issue. If it is moving air, then the motor is running. If no air, then the motor is NOT running. If this is the case, I would not leave it "Humming" for long. Motor could get pretty hot. Also, there is often a one time over temp switch in the motor. If this gets too hot, this will trigger, killing the motor.
If it seems like a belt issue, look online for instructions for opening the machine up, and check the belt status. Belt could have jumped off a pulley, and just needs to be put back on. Or, something could have failed. You will have to look inside to find out more.
Jul 02, 2012 | Frigidaire GLGQ2170K Dryer
Hotpoint dryer was moved, now only clicks, won't start
Rough handling may have the drum belt to get binded. Try turning the drum by hand to see if it turns free or is locked. This may align the belt to the motor or may just take off the belt altogether from the motor. You will have to get inside access to see whats up. Once inside realign the belt to the motor and pulley assembly. Then CHECK ALSO that no wire connections inside came apart during moving. Good luck
Jul 10, 2010 | Hotpoint NLL113EYWO Electric Dryer
Belt slipping / takes a minute to start tumbling
Before replacing belt check the space between the drum and the front AND rear seals with your fingers for foreign objects caught there. This may make the drum too tight to turn. Belt is usually broken before it needs replacing.
Also check idler pulley next to motor and motor itself with belt off both pulleys making sure they both turn freely. I think something is binding. Check all those BEFORE replacing belt.
Disconnect plug before opening unit.
Aug 21, 2009 | Maytag Dryers
Will not start consistently. Will make humming
This is a very hazardous condition and you should not use the dryer until it is repaired. First, unplug the dryer! Then, remove the front panel screws (if any), and gently pry it off of the cabinet, door and all. The panel is usually retained by steel clips. Next, check for foreign objects that may be causing the drum to bind. Whether you find anything or not, slide the drive belt to the rear and lift out the drum. Notice how the drive belt is routed through the motor drive pulley and belt tensioner.
Inspect the motor, drum suspension rollers, and belt tensioner for any binding or discoloration. However, if the motor was throwing sparks, replace it. Check wiring harness and connectors and repair or replace if damaged.
If any drum suspension rollers or the tensioner pulley binds, replace them. They're relatively cheap. Upon reassembly, make sure the drive belt is routed correctly around the tensioner before reinstalling the drum, being careful not to twist the belt. Upon reinstalling the front panel, turn drum by hand at least two revolutions -- it should turn smoothly. Plug it in and test the operation.
Jul 09, 2009 | Dryers
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore series 90 dryer
I hae to say it, but it sounds like the motor has already gone out. That loud humming noise is usually the start windings going out. There is no other way easily to tell if the motor is out, but taking the belt off and saying it doesnt look broke what work in this situation. I would imagine that you have a DOTT (Dryer Of Tommorrow, Today) dryer, because you said it had the front panel. The motor part number is 279787 if this the case. Good Luck, and let me know if you find out any new information or need further help.
Feb 12, 2008 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
