Question about Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0
The HD start with blincking the front led from red to blue, it has a soundclick and is not recognized by the PC as a unit disk. Until now it was running well. I have a very critial dat ainto it and the HelpDesk of TrekStor not attend my demnd support. Thanks
  • Paul J Jan 02, 2012
    I tried a different power source and it worked.
  • Michael Blatzheim Jul 15, 2012
    That's what I did and it's working :-)
  • 11,800 Answers
Sorry, what you hear is the so-called click of death - the reading head is no longer capable of reading the data on the disk. This in unfixable and all the data on the disk is lost.
Posted on Sep 01, 2010
Midland btx2
The red LED on the unit will start flashing when charging begins.
Allow the headset to charge until the unit stops flashing or the blue LED turns on.
When the charge is complete (the red LED is not flashing), release the headset
from the charger
Jul 30, 2012 | Radio Communications
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
I have problems configuring my new d2 Network 2 1.5 TB HD. Either using the LaCie Network Assistant or directly the IP address, I get a blank page with the message: Please wait while loading... and it...
Hello, I had similar problem with 2Big Network2 which was freezing the same way. I know the question is old but maybe someone will find this answer useful.
I solved the problem by updating the firmware. It may seem trivial but it took some time to figure out how to do it right.
My firmware was 1.3.7 and I was unable to easily get SSH access.
To upgrade the disk you have to
1. get it recognizable by Lacie Network Assistant. If you have a fixed IP it may not see the disk. To switch your device to DHCP assigned IP you have to reset it to factory settings (without losing data). Procedure from LaCie site works (http://manuals.lacie.com/en/manuals/d2-2big-5big-network2/reset)
  1. Make sure the product is turned OFF.
  2. Press and hold down the front button. Without releasing the front button, turn the product on by pressing the power switch on the rear of the product.
  3. Keep the front button pressed until the front LED becomes solid red, then release it. (The LED should become solid red about 10 seconds after you turn on the product.)
  4. The front LED will blink blue. When it becomes static blue, press the front button once within 5 seconds to confirm reset.
  5. If any of the steps are omitted, the product will boot normally without resetting.
2. you need the LaCie Network Assistant which you can download from here http://www.lacie.com/support/drivers/driver.htm?id=10138
I used 1.5.15 version for windows
3. Once you have the LNA installed it should recognize the disk. However if it doesn't start and says you are missing bonjour service just go to the installation directory and install bonjour.msi
4. At this point you should be able to start LNA which finds your drive. Now you need firmware (capsule file). You can't just load the newest firmware out there. Given fw version can be applied only to certain previous revisions. To check which version you need you have to check your current release. To get your current release open LNA and go to Configuration tab. The current system version is displayed in the bottom-left corner.
I updated mine to next release (from 1.3.7 to 2.0.5).
5. Now you should now to which release you should update. The question is where to get the firmware from if the LaCie support page (http://www.lacie.com/fi/support/drivers/driver.htm?id=10201) does not contain the one you need ? You can use and ftp service (it's not obvious).
Go to ftp://2bignetwork2-update.lacie.com/ (just put this address in files explorer address field) and login with 2bignetwork2 user and 2bignetwork2 password. Then browse for firmware.
6. now assuming you have successfully downloaded the firmware open LNA go to configuration tab and click "Update your NAS.." button. Authenticate with admin user and admin password then browse for the capsule file and begin updating
7. drive will need couple minutes to finish (blinking blue-red) then it will restart and when the light turns solid blue you should be able to get access to the web administration interface.
As other suggested - if you don't want to risk losing data get disk(s) (if in RAID0) and use some linux box or VM to backup data.
Jul 22, 2011 | LaCie d2 Network 2 NAS server (301505)...
PS3 Blueray drive,, Both blue and red LED's work, but it will not read a blueray disk, At first it spins fine and looks good,, but then the disk slows down and the eye jumps back down, at this piont it...
If this solution am providing you now did not solve the problem, i will advice you format or get a new drive.
Make sure PS3 is connected via correct cable.
Power Off the PS3 via the power switch in back and power back on with switch. Hold Power Button on the Front until you hear 3 beeps. Your ps3 should automatically reset.
Take care.
Jul 29, 2010 | Video Game Consoles & Games
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
I have a 3TB big disk quadra and the blue light in front started blinking between red and blue. What does that mean? I still saw the drive on the desktop and access to the files, but I shut down the...
If the drive front LED alternates between Red and Blue, whilst the rear LEDs are normal, then it is a tempertaure warning. Ensure that there is plenty of space around the drive and at the rear.
Mar 06, 2010 | LaCie (301082U) 250 GB Hard Drive Array
HD not recognized and front blue button blinks
best to try using a shorter usb cable, long cables tends to introduce signal loss which could cause your HDD not receiving sufficient signal from your PC. Also, if you are using a USB hub (usb extenders or a device that adds USB ports) make usre that you are not connecting the HDD there. If the HDD has a separate poer source, please check that it is plug-in properly and getting power from your mains.
Jun 25, 2009 | LaCie Big Disk Extreme with Triple...
Red light on power up. No image on monitor. Pc fans working.
On a computer mainboard there are usually a number of connecting pins right next to one another called RESET, POWER LED, HD LED etc.
The power led often leads to the green LED next your power button to show that the juice is available and on. The cable that leads to the red LED is usually the HD LED which shows that a disk drive is being accessed.
Since the red LED is active, one of your disks is probably being accessed and that's where the problem is. Either the disk is damaged, the cable is still not inserted properly or the bios is having problems identifying one of your disk drives.
1) Power the computer off. Take the power cable out. Make sure that you are grounded (have no static charge on your body). Take all of the cables between your mainboard and your disk drives off.
2) Plug in one of your disk drives, reconnect the power cable, switch the power on and watch the monitor. If all goes well you will see that the bios has recognized the disk drive and will simply display a message that the operating system for example isn't available or no harddisk drive is present (if you connected something other than a harddisk drive).
3) repeat this process with the other drives, powering the pc completely off each time and then adding a new disk drive.
4) once you've reached the point where the red LED drive is displayed but no message is available, you've found the culprit that is keeping your pc from booting properly. Hopefully the cable has just been stuck on improperly or the cable is damaged (Check it), rather than you having disk drive damage.
Mar 27, 2009 | Aspire Red X-Cruiser Mid Tower ATX Case...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0 Logo
707 people viewed this question
Top Trekstor Computers & Internet Experts
Marcin
vojvodabudva
Mohamed Ismail
Mohamed Ismail
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
