Question about Paragon 8145-20 Defrost Timer
What is the minimum power to run the clock for 8145-20
208- 230 volts
Posted on Dec 09, 2010
I want to buy forsa nvidia 620 gt 2gb ddr3 graphics card can it run hardcore games its gpu clock speed is 1400mhg plz rply
graphics wise this card does support the minimum system requirement but i am not sure about your processor. Can you please update your processor model.
Minimum system requirement for this game are: Core2duo 2.66ghz processor, 2 Gb ram and Gforce gt 545.
Nov 29, 2012 | Computers & Internet
Tip
How to increase processor speed of a rooted android phone
For most smartphones, the processors are clocked at speeds much lesser than their maximum supported speeds to improve battery life. That also means you are not enjoying all the juice your phone can give you.
Lets see how you can overclock your android phone to unleash its full potential.
Important: Overclocking requires super user permissions and so your phone needs to be rooted.
SetCpu is the best app out there to overclock your android phone. Its sheer simplicity and useful options sets its apart from its competitors. You can either download it as a paid app from the Android market or simply download the zipped apk from XDA forums.
Using SetCpu. Once you install and start SetCpu, it will first show you a screen with two options. Unless you have a specific reason to do otherwise, simply select "Autodetect Speeds Recommended".
A screen will come up where you can change the maximum and minimum clock speeds and select the scaling method. SetCpu will automatically detect the maximum clock speed your processor supports.
Max - maximum clock speed.
Now its a bad idea to rush and drag the slider to its maximum in one shot. Although there will be no problems for most phones, it could lead to instability for some. Instead, try increasing the clock speed in small steps, running some heavy apps like games and if you don't see any instability, go back and repeat with increasing the clock speed. In case you find your phone going unstable at any speed, just set the speed to slightly below that value.
Min - Minimum clock speed.
Minimum frequency is the speed at which your phone will run when it is idle or no heavy apps are running. Setting it to a too low value can cause your phone to go slow with incoming calls, alarms and any other app that runs while idle. Generally it is advisable to set it to at least one third of the maximum speed your phone processor supports.
Scaling.
The scaling option determines how aggressively the minimum and maximum clock speeds will be applied. The drop down menu gives 5 options as below -
  1. OnDemand - Automatically sets the minimum and maximum based on load. This is the recommended setting.
  2. Conservative - Very similar to OnDemad except that the scaling is less rapid.
  3. Powersaver - Makes your phone run at min speed always to give maximum battery life.
  4. Performance - Makes your phone run at max speed always.
  5. Userspace - This option is useless as of now and is kept as a future option for apps to change clock speed that SetCpu doesn't use.
Once your phone looks comfortable with the new frequencies, you can use the "Set on Boot" option to enable the settings permanently.
Tutorial Video:Overclock Your Android Phone to Unleash its Full Power
Download link: http://forum.xda-developers.com/attachment.php?attachmentid=648354&d=1310073004
on May 27, 2015 | Android Apps
I have a Philips clock radio. Will the radio come on during a power outage with a battery?
Friend,
I agree that there is a battery in the device. But, it is only to maintain the time during power outage. It is just a button cell good enough to run the clock internally. It does not even show time, despite the clock running. And when the power restores, the time is displayed.
So, the answer to your query is NO.
Feb 01, 2011 | Philips AJL30837 Clock Radio
I have a ten year old Proton Clock Radio RS-330, now Sangean RS-330. The flourescent display seems to be about half out, and the time display is barely visible in the dark. Can this be repaired, and by...
The display itself may not be the problem which may be related to the power supply for it instead. Some technical skills and a decent multimeter is the minimum you should have to determine the source of the problem.
If you are looking for a local service company, you should always post your ZIP code so a tech in your area is likely to respond.
Jun 28, 2010 | Proton R5A Clock Radio
My honda will not start it turns over however i have no power to fule pump or any dash lights colck bot the radio works
clock and radio draw continuous power. Everything else comes from relays that require minimum power *(volts AND amps) to turn on.
Check your battery and charging system. Also check your ground wire to the battery.
Jun 26, 2010 | 1994 Honda Accord
I'm sure I meet the minumun requirements but
Here's the minimums to run your game.
CPU
Minimum: Pentium 4 2.4GHz+
CPU Speed
Minimum: 2.4 GHz
RAM
Minimum: 1 GB
OS
Minimum: Windows XP or Vista
Video Card
Minimum: GeForce 6600 GT+ / ATI x1600+
Features: Minimum attributes of your Video Card
Minimum 3D: Yes
Minimum Pixel Shader version: 3.0
Minimum Vertex Shader version: 3.0
DirectX version
Minimum: 9.0c
Sound Card
Minimum: Yes
Free Disk Space
Minimum: 6 GB
DVD-ROM
Minimum: Yes
Dec 12, 2009 | Codemasters Clive Barker's Jericho for...
I have aquired a colossus pc the other day and it had WIN 98 on it so i tried to put XP on it but it just keeps re-booting by itself and then say's you need to reboot your comp?? it has an award bios...
These are the bare minimum specs you need to have in order to /install/run WinXP--not that it will run well on these but it will run
• PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
Jan 20, 2009 | Computers & Internet
Emerson Jumbo Display CKS2237 clock radio
Sorry it took so long to get back to you with a answer to your question. You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
Oct 05, 2008 | Emerson Smartset Clock Radio
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 08, 2008 | NEC VT47 Multimedia Projector
Rover 620ti
definately operated at 5400rpm, that should be minimum. Those all audio apps recommend recording at 7200rpm, ala 3.5 hard disks. It's the set standard for hard disk recording. The drive is spiining to slow to keep up with system clock speed.
Keep me posted.
Dec 10, 2007 | M-Audio FireWire 410 External Sound System
Paragon 8145-20 Defrost Timer Logo
20 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
